Question about Kenwood DNX7100 Car Video Player
Xm? do you need an adapter to listen to xm radio, or do i just need to buy the xm service?
    Problem Solver:
  • 5 Answers
You will need to purchase the XM antenna ( GXM-30), and also purchase the service.
Posted on Jan 16, 2008
Xm check atenna connection
If you are getting the same "check antenna" message with two different antennas, it is likely that the tuner itself is the problem. You can get just the mini tuner here:
http://www.tss-radio.com/products/xm-mini-tuner-replacement-home-dock
As far as the two plug connection, there are adapters available. Its likely a dual fakra connection, though I don't know for sure. At any rate, this is one adapter available. (I would call to confirm)
http://www.tss-radio.com/products/sirius-dual-to-single-antenna-adapter
Jun 27, 2012 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
I have a XM delphi skyfi3 and I can record songs and listen to the radio portion fine. However, I cannot play my recorded music back on the my music mode, regardless of whether the xm is in the cradle or...
You must have a subscription and listen 'live' 8 hours a month, or it doesn't let you listen to recorded content anymore (thanks to the RIAA and their royalty fees to XM)
Jun 27, 2010 | Delphi SKYFi3 XM Radio Receiver with Car...
I don'tknow how to use the satellite radio...
Got this off the crutchfiel web site.
Item #700XMSON1 $129.98 This XM Direct 2 package includes everything you need to add XM Satellite Radio to your compatible Sony receiver: an XM Mini-Tuner, a CNP2000UC universal adapter, and a Sony connector cable. The Mini-Tuner connects to the universal adapter, then you use the connector cable to hook up the adapter to your Sony receiver.
Use your home computer to program the universal adapter for your Sony receiver — you can reprogram this adapter to work with another brand in the future. Once connected, you'll be able to change channels and see programming information on your stereo's display. You can also use the included XM Mini-Tuner with your XM-ready home receiver or in another vehicle with a compatible dock.
A computer running Windows XP and Internet Explorer is required. The unit is not compatible with Windows Vista.
Note: A subscription to XM is also required — learn about XM's programming. Satellite radio service is available only within Canada and the lower 48 states — not available in Hawaii or U.S. territories. Portable reception may vary by location. If you have questions about the proposed XM/SIRIUS merger, read the XM Customer Promise. To view this file, you will need the Adobe Acrobat PDF reader.
Apr 16, 2009 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
2005 Honda CR-V won't go to XM radio.
"XM Ready" means that you have to have a satelite radio installed in order to have XM service. I went through this when buying my 2005 CR-V and thought that all I needed was to set up the service. If you have an XM receiver installed you can controll it on your Honda factory radio. It is very misleading.
Feb 28, 2009 | 2005 Honda CR-V
XM Radio online use problem
Yeah use sirius radio service. Prolly a reason that it isn't running it anymore because Xm and Sirius merged company's. So Sirius is the same as Xm now.
Jan 09, 2009 | Audio Players & Recorders
XM Direct
Resetting the head unit will make it look for anything that is connected to it recently or even already is for a long time. Make sure your head unit's memory cable is constant power (direct to battery) to retain in its memory that the xmdirect2 unit is already connected. There must be a loose cable when it is not recognized as a source like the power cable from the adapter which should be on constant power. You should hear a click sound on the xmdirect2 module whenever you turn to xm source on the radio. The CC tech that was actually solved the problem by chance if he couldn't explain this to you. Loosing signal is different
Oct 07, 2008 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
Xm radio installation in house
hi there..this will be like a walk in a park...first, in your home kit you should be having the ff: antenna, rca cable(audio cables), power adapter & docking station. We just have to 'placed the radio into the docking station' then we just have to plug in the ff cables into the xm receiver..we can start plugging in the rca cable(one ended connector) into the ' audio out ' of your xm radio...the other ends of the rca cables should be plug in into the 'audio in'(at the back/infront of your sound system)...plug in the antenna in the 'antenna out' of your xm( the antenna should be placed into a south facing window and not being block by tall trees and buildings outside)....plug in the power source and turn on the radio....if you got it right you should now be getting the prev.channels/emergency allerts...u can call xm to send a refresh for you to get the complete channels..or you can do it online by logging into www.refresh.xmradio.com(if the radio was already activated) if not, you have to call xm radio to activate it..enjoy listening to xm..Godbless..
Sep 05, 2008 | Delphi Roady2 SA10085 XM Radio Receiver...
MyFi FM Modulator Stopped Working?
hi there..there are few ways on installing xm into your car..you can use the FM Modulation that you're doing before..it goes like this...make sure that you're xm radio is turn off( with all the wirings unplug).....then, you just have to go on a blank channel(e.g 90.1) on your car radio...afterwhich, turn on your xm radio and go to MENU....and look for FM settings...and select the same frequency you have into your car radio...and just have to wait for 5 to 8 secs and you should be getting the prev. channels.....
IF: you're only getting prev. channels such as 1, 130 etc...you just have to call xm to send a refresh signal OR you can go to www.refresh.xmradio.com if you want to save more time...just type in your 8 digit radio I.D....
IF:
you're not getting the FM settings.....you just have to click the MENU and select the 'default settings/factory settings' then turn off/on your radio to save the changes...
i'm sure it'll work nowq at this time....Godbless!
Aug 23, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Xm radio
mine does the same thing.
Nov 03, 2007 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT Quit Working
Chances are it's not picking up the XM signal. First, contact XM to resend your setup. if that doesn't work check your antenna connections.
Oct 31, 2006 | Delphi Roady XT XM Radio Receiver
Kenwood DNX7100 Car Video Player Logo
147 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
