Question about Video Game Consoles & Games
Gamecube won't boot up properly
When I turn on my gamecube all I see is a black screen and lots of lines of code or something. It won't even go to the menu screen. Any ideas?
Nope, just turned it on and I have gowling, cashing static for audio and a bunch of scrolling code on a black screen. However, I can get it to play 2 games. This is where it gets strange... You know that zelda game for the cube that has Ocarina of time, majora's Mask and NES zelda 1 and 2? It will paly zelda 1 and 2 with full audio. Nothing else will it recognize. I think it's demons...LOL
~Susan
Posted on Jan 28, 2008
    Problem Solver:
  • 17 Answers
Has the console been dropped or otherwise suffered a hard impact? It may have suffered internal damage. Odd though, considering that that little cube is the most durable console I've worked with! :P
Wii controller won't work with gamecube game in wii console
Gamecube games don't have the proper coding installed on the discs in order to receive commands from the Wiimote. You'll have to have a Gamecube controller to play Gamecube games even on the Wii console.
Nov 23, 2011 | Nintendo Wii Console
I plug it in and only the fan will turn on
Something might be wrong with your Nintendo Gamecube as a whole. I'm not totally sure. I've heard of Gamecubes working, but the fan is broken, but the other way around, that's a bit strange. If you can post some more information, can you tell me if the Gamecube actually turns on to the point where it says "No Disc", or it just doesn't even show a picture when you hit the power button.
Jul 01, 2011 | Nintendo GameCube Console
My gamecube is in black gray and white now.
Well most likely thats its the av cable or and the settings for the colour on the tv are turned to black gray and white or there is something wrong with the tv then not the console.
Apr 03, 2011 | Nintendo GameCube Console
My Nintendo Gamecube received a big powersurge and now it won't turn on. Is there any hope for it or is it fried ?
  • No Power
    1. Make sure that the words "Nintendo GameCube" are molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
    2. Make sure the Nintendo GameCube has good ventilation. For best results, make sure that the system rests on an open, flat surface. Avoid operating the Nintendo GameCube while it's on carpeting or inside an enclosed space.
    3. Check the vents on the sides of the Nintendo GameCube for a build-up of dust. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vaccum cleaner with a soft brush attachment.
    4. Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC adaptor (see below).
    5. Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
    6. Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Nintendo GameCube (the port is labeled DC 12V IN) and into a working wall outlet.
    7. Press the power button on the Nintendo GameCube and check to see that the red power light on the top of the Nintendo GameCube illuminates.
      If this fails, try resetting the AC adapter.
      1. Unplug/remove all accessories from the system (including game discs, memory cards, and all controllers), hookup cables, and the AC adapter from the outlet and Nintendo GameCube.
      2. Let the system rest for about 45 seconds. While you're waiting, check to see that the cords on the controllers, AC adaptor, and Stereo AV cables/Component Video cables (or RF Switch) are not frayed or have exposed wires (this can cause the system to shut off); if so, you should replace those parts.
      3. After the 45 seconds, Plug the AC Adapter into the system and wall outlet. Press the power button to see if the system works.
        • If the system works, turn the power off and plug ONE accessory into your system, then turn the system on to see if it still works. Repeat this process with ONE accessory at a time. If your system doesn't work once you put a particular accessory in (GameDisc, controller, Memory Card), there may be something defective with that accessory.
        • If the power does not come on, a repair will be necessary. Because it is not possible to determine which item (Control Deck or A/C Adapter) needs repair, please call our Consumer Service Department at 1-800-255-3700 to discuss available options.
    8. If the power is continually shutting off after aprox. 30 minutes, listen to hear if the fan is working while the system is powered on. If the fan is not running, the problem will continue (Nintendo GameCube is avoiding overheating) and the system will need repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair.
  • Jan 01, 2011 | Nintendo GameCube Console
    No power The light does not come on. The game does not turn. The fan does not blow.
    • No Power
    • Power Light Shuts Off
      If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
    Dec 21, 2009 | Nintendo GameCube Console
    Dosent read the game !!!!
    The disc is probably toast. But if there is a local Play N Trade store in the area they may be able to fix it
    Jan 26, 2009 | EA - Electronic Arts The Sims for GameCube
    How to start with
    Try this:
    ~Turn it on.
    ~Hold the game into the slot.
    ~Keep holding until the screen isn't black anymore.
    Nov 24, 2008 | Nintendo Pokemon Box: Ruby and Sapphire...
    Gamecube - blank screen, disc wont spin, power light and fan work.
    Troubleshooting - Power
    No Power
    Power Light Flashes
    Dec 07, 2007 | Nintendo GameCube Console
    Nintendo GameCube power loss after on for 20 mins
    Does the gamecube have proper venelation? Did you try buying a cooling fan to see if that prolongs the gametime? To me, it sounds like it is overheating and shutting off before any real damage can be done. Try this and see if you get any results: Put your gamecube in middle of the room, to give it plenty of air and turn it on and see how long you can play it. If it doesn't shut off, the place where you usually have it probably doesn't have enough venelation to keep the cube cool. If that doesn't seem to do anything, check and make sure all the connections are snug (i.e. gamecube to power strip...etc.)
    Aug 19, 2007 | Nintendo GameCube Console
    Video Game Consoles & Games Logo
    142 people viewed this question
    Top Video Game Consoles & Games Experts
    Marvin
    Marvin
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
