Question about Akai PT4298HD Rear Projection Television
THE COLOR ON THE TV IS STARTING TO GET ORANGE
  • 488 Answers
The picture is formed from three lamps in the base of the TV. These lamps have a fluid filled lens on each of them and the Glycol in this fluid degrades after time. This fluid can also have a mold or algae growing in it. Check the lamps visually first BUT DON'T touch the driver circuits ( this would be very bad for you) with them turned on and off. If you need to change the fluid, be very careful as leaks happen very easily. If you get any of this fluid onto the driver board it will damage the tracks etc VERY QUICKLY. You must replace the fluid with the correct fluid at the correct level and amount and wash your hands afterwards as Glycol is a poison. I do not think that this is an electronic fault as the orange tinting leads me towards a fluid issue.
Posted on Nov 30, 2009
SOURCE:
Tv powers on, see three birds in color then flickers and fades to white
The problem must be with its main digital processor board. It will be best to make it confirm. Contact any service technician. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 20, 2013 | ViewSonic N1930W 19 in. LCD TV
When i turned on my Hc-p4241w i smelled a burning smell then the color started looking 3d, i took a flashlight & looked through the left side of the tv and saw a orange glowing inside and i shut the tv...
Your Convergence output is burnt.DONT turn that TV on until convergence IC's are replaced,orange glowing inside that you see it is resistors that overheating and burning.Unplug TV from outlet before more damage is done
Aug 23, 2011 | Samsung HC-P4241W 42" Rear Projection...
The tv is all orange tv works well just that everything looks orange
Check ur signal input,u lost one color is green.Change all the signal input conections.still same problem,one ur CRT colors gun is dead green.
Jan 14, 2010 | Philips Magnavox 51MP392H Rear Projection...
Philips projection tv
sounds like your cooling fluids in the tubes needs to be changed. Repairman told me it was common on the philips.
Sep 09, 2008 | Philips Magnavox 9P6034C 60" Rear...
My red is gone
there is color tracking problem in the tv. probably the tv is loosing the drive for one color, I will say the blue color
Aug 06, 2008 | JVC AV-27D303 27" TV
Color
replace the converge ic's
Jun 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Orange glow on screen, Colors messed up
Your light engine is going out. You may be able to get a rebuilt one from www.vancebaldwin.com
Jan 28, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Philips model 50p8341a projection
color is off. Faces are orange sometimes, all orange, or red? Tried the remote to fix however did not work.
Nov 22, 2007 | Philips 60P8341 60" Rear Projection...
The black color on my tv is orange
If it is new then it should be coverd by the warranty,get the tv changed as it sounds like the .ideo processing i.c. is at fault.
Sep 04, 2007 | Maxent MX-42HPM20 42 in. Plasma HDTV
Screen Color Looks Like a Rainbow
Good day.
The problem includes malfunctioning of you units deflection yoke, color circuit and failures in the chroma system.
Have it check by a repairman.
chris
Aug 04, 2006 | Toshiba 36A40 36" TV
Akai PT4298HD Rear Projection Television Logo
109 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
