Question about Hotpoint WMA40 Front Load Washer
Washer has been moved due to new fitted kitchen and now not working
Hi, wonder if anyone could please help, I have tried all day to do a load of washing, but as soon as it gets to the rinse cycle it just stops, when I go to the ! on the cycle it does not drain as it used to but just makes a rattling noise. the drum is moving around and making the normal sounds but the rattling sound is constant. I can't even get the load out to wash in the sink as the water is not going down.
Any help greatly appreciated.
ps. I've searched all over for the pump and cant find one anywhere, I have removed the front plate, and all that is underneath is a solid silver peice with holes for the kickplate to fix.
  • 1 more comment
  • Lynsey Kr?l Jan 15, 2008
    thanks for your very quick reply, I have taken the said panel off and there is pump in the back, but im not sure which bit I should take off. There is a large black rubber pipe coming from the washer drum attached to it with a clip which then attaches to the waste hose, I'm not sure which one to unclip though
    you are excellent, and have just saved me a good amount of cash on a call out fee, thank you ever so much, I did what you said (my partner drained off the water using the waste hose and a mop bucket) and found my daughters small toy in the filter. THANK YOU
  • robert samples May 11, 2010
    look in the back to see if there is aremoveable panel there i beleive some foreign object in the pump is your promblem and let me know
  • 1,314 Answers
Well first off ther is still a lot of water in that machine the big one is the one you pull but if you do its gonna dump water everywhere now if you have a wet dry vac you can remove the water by pulling the water out of the drain hose by removing it from the stand pipe of go to the auto parts store and purchase a pair of radiator hose clamps and clamp the large hose to the tub as close as you can get it now if you do go to auto store also buy a crew clamp large enough to put the hose back on its a lot easier that war and put some towels check the sump in the big hose with your ginger and look in the pump for any broken are jamming things and let me know
Posted on Jan 15, 2008
  • robert samples Jan 15, 2008
    thanks for the rating lol check your pockets its the number one cause of failures
My stackable GE Washer Model #GFAN1000L2WW start button is blinking. When I press it to start the load nothing happens. Does anyone have any idea why this is happening?
Hello Claude, let's see if we can figure this out. Have you ever put your machine into service mode before? It's not difficult and if you're comfortable trying, we can see what error codes come up.
Mar 07, 2015 | GE Washing Machines
Code F11 appears about 10 minutes into cycle or at the end when the door should open. Kitchen aid front load washer six years old
F11 is a motor control unit error which means that the motor control unit has repeating under or over voltage or over current conditions due to internal failure. You can check the wire harness connections between the motor and the MCU (motor control unit) and also between the central control unit & MCU. If the motor is working then replace the motor control unit. Hope this helps...please post back for further assistance.
Aug 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi i have an hotpoint ultima its 2years old, it was working fine untill the council fitted new kitchens. then it started not draining right then when it was draining water was comming up the sink now no...
Sounds to me like therte is a problem with the draining of the washer due to the way it
is connected to your sink waste.
Get that sorted, and you will probably find that the other problem will disappear.
Jan 26, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hi could anyone help me please..My Hotpoint WMA52 keeps flooding
It is not draining properly, or overfilling due faulty pressure switch.
Try cleaning the filter first.
Remove lower rear cover of washer.
Remove large black hose onto bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for obstruction here and in the pump.
Hope this helps.
Dec 07, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
My washer does not empty
i had the same prob when i had a new kitchen fitted. . all i did was put the pipe that goes to the sink part in the shape of a n , that will solve it.......
Jun 17, 2009 | Creda W100FW Front Load Washer
Schematic for AP3105889
What is it you are trying to do? Are you trying to repair the one you have so as to not purchase a new one? Do you need help hooking up the correct wires? Your question is unclear so any additional detail would be helpful.
Mar 29, 2017 | KitchenAid KWCU265HSS Kitchen Hood
This is worth posting in case anyone else has the problem. The mechanic was stumped and then around 3 days later a Zanussi gave the same problem - steam emitting from the drum. He changed the valve - the entire unit. Problem solved. Zanussi and AEG have identical internals. He changed our valve - problem solved.
Jul 22, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Replacement For Whirlpool AWG329 washer/dryer
Not sure if this will help, but Whirlpool has a pretty neat tool that can help you configure your laundry-room layout: LAUNDRY-ROOM LAYOUT
Nov 18, 2007 | Whirlpool AWG329 Front Load Washer/Dryer
Hotpoint WMA40 Front Load Washer Logo
61 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
