Question about Sony KDF-E42A10 42 in. LCD Television
Sony KDF-E42A10 The TV's light comes on when you power up, but there is no sound, and the screen only displays a bunch of colored vertical lines. Any idea on what this might be? I'm pretty good at fixing stuff, and I have the service manual for this TV.
  • 1 more comment
  • dmathewsii Feb 13, 2008
    Multicolored lines in front of picture. If no video source all you get are the lines.
  • Anonymous Feb 19, 2008
    I have the same issue only i have the Sony KDF-55E200. The tv is only a year old, problem occurs intermittently. When powering on, the flashing green light flickers on and off for about a minute, then the black screen turns into a bunch of multicoloured vertical lines. You cannot change video inputs or channels, only can turn off. Ive tried unplugging the power source, this fixes the problem sometimes. Ive unplugged all the input cables such as hdmi and component cables, this didnt work. There is a clicking sound when you unplug power and replug. Not sure waht else to do from this point apart from having some repair guy come in which i dont really want as the problem occurs intermittently. A little help please anyone?
Correct, no video source, whether it be on a video input or cable, still the colored lines
Posted on Feb 19, 2008
6ya staff
SOURCE:
How to fix vertical lines in a grand wega lcd projection model kdf-e42a10?
this does not sound good---model indicated is a lcd which means it may have a bad optical light engine and unless under warranty too much to repair as part alone over one thousand retail.
Mar 18, 2012 | Sony KDF-E42A10 42 in. LCD Television
My Sony KDF-E42A10 turns on and then after a min the picture and sound will go away and the light "Power/Standby" will flash green. after a little bit the TV sound and video will come back on for a...
It is symptom of weak lamp that reaches at end of its working life, replace lamp in tv to fix the issue.
Lamp replacement procedure is easy and written in user manual.
Thanks.
Aug 31, 2010 | Sony KDF-E42A10 42 in. LCD Television
How do i reset the lamp life for sony KDF-E42A10 ?
1) In standby mode, press the buttons on the Remote Commander sequentially, in rapid succession:
[Display] , Channel [5] , Sound Volume [+] , Power [ON]
2)To enter BE-micro service mode menu, press JUMP 2 times.
3) To display the lamp time, press Channel[4]
The screen displays:
“ Total lamp time is 14 hours”
4) To display the lamp time clear, press Channel[5]
7 times and Channel[1].
To reset the lamp time press Channel[3] > [MUTE] > [ENTER].
WRITE (Character color is red) is momentarily displayed and the lamp time is reset to “0”.
This worsk for other Somy retroprojection TVs as well, eg. KDF-E50A10 , KDF-E50A11 etc.
If you goto eserviceinfo.com you'll get the whole service manual
HTH!
zioanza
Dec 01, 2009 | Sony KDF-E42A10 42 in. LCD Television
Green line running vertically along the edge of picture
If its a LCD projection TV (such as Sony Wega, Hitachi, Epson, Philips, and some Panasonic, some Mitsubishi), and the green image is in the whole screen or just one part as a blob or a line. Is most probably that one of your LCD Color Filters is damaged (burned out or starting to get busted), I don’t know if you can just replace the color filter, I believe you need to change the whole light engine system or the optical block. There are some places around, I found some on ebay but you should definitely try on discountdashmerchantdotcom their price range $260.00 - $330.00
Jun 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a Sony KDF-E42A10 42" LCD TV that has probably 100 vert
Its a b-block assy that causes the vertical lines b- block is out
Mar 31, 2009 | Sony KDF-E42A10 42 in. LCD Television
Crack in the screen 42" sony kdf-e42a10
You can find a new Sony replacement lenticular screen and fresnal screen for a model # KDF-E42A10 from a major Sony distributor at the following links:
Sony KDF-E42A10 Replacement Part Lenticular Screen
Sony KDF-E42A10 Replacement Part Fresnal Screen
Feb 16, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KDF-E42A10 video problems
Your Sony TV probably is suffering from old age.
Jul 11, 2017 | Televison & Video
Sony LCD KDF-E42A10 Television
Please count flashes on Sony KDF-E42A10 tv and let me know.
Its error signal and shows problem with particular area in your tv.
Sep 29, 2008 | Sony KDF-E42A10 42 in. LCD Television
Sony KDF-E42A10 42 in. LCD Television Logo
193 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
