Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
GE Profile Harmony 4.0 -Broken Clutch Coupling
My washer had a Notice: A problem has been detected with this unit. When I pushed and held "my cycles" and "back" buttons, a message came on that said I had a "broken clutch coupling" and had some other information: "Main: MV 2.032" "INVT: V01 11" Anyone know anything about replacing the clutch coupling? I have a warranty on it, but if it's easy to replace, no need to call a repairman, right?
  • 3 more comments
  • Vicki Rathburn Jan 15, 2008
    Good tip! I actually bought it from a used appliance dealer that offered 1 year warranty. I've only had it a few months, I just hope I don't have to "haul it in there!"
    Thanks again!
  • Anonymous Feb 04, 2008
    Have broken clutch coupling issue as well. I reset the machine and appears to be ok now. To be continued ...
    Had the same problem. Reset machine and appears to work now. Could be a false reading for you. As far as my issue, to be continued ...
  • gogin Mar 26, 2008
    Hello I had the same symtons with my GE Profile, Where in the machine is this Clutch coupling located?
  • kimw123 Apr 10, 2008
    I had the same problem, but after the washer ran through it's self-diagnostic mode it seems to be working fine. I'll re-post if I have additional problems.
I had this same EXACT problem as well with my GE Harmony. I purchased a warranty from Home Depot so I called them about it. I wasn't home at the time because I had to work so my wife handled it. According to her, the repairman came out and somehow reset the machine by unplugging it for 30 seconds and plugging it back in. That was about an hour ago and the washer appears to be okay now. I will repost if the problem continues.
Posted on Apr 27, 2010
    President:
  • 1,314 Answers
If your under warrenty always call for service repairing it yourself voids your warrenty
Posted on Jan 15, 2008
Have a message on GE Profile Harmony washer that say " a problem has been detected with the unit" help?
Washers - Harmony Washer Error Message or Code
The Harmony washer electronics can automatically determine if problems exist with the machine. Sometimes an error code can also be present because of things the machine cannot control: like changes in house voltage, water pressure, or temperature.
"A problem has been detected with this unit" will be displayed on the screen.
The most common solution for this message is to turn the machine OFF and then ON. However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
Solution:
1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Jan 15, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
Broken clutch coupling. The main screen said "There has been a problem detected with this unit" I went into the help screen and it said I have a broken clutch coupling. What the heck is this thing? Where...
It's not really very hard to get at, it just sounds hard. You have to lay the washer on it's side and take the motor rotor off to get to it. It is made of white nylon plastic.
Jul 07, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Won't continue cycle the message is ''Notice'' a problem has been detected with this unit.
Press and hold the my cycles button and the back button simultaneously for 3 seconds. This will reset the control panel and let you see any stored errors.
Mar 13, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
I have a GE Profile Harmony washing machine,when I go to turn it on a notice pops up ther is a problem with this unit,what do I do?
What does the notice say? Also, it's important to enter the Field Service Mode:
1. Press the POWER key to turn the dryer on.
2. Press HELP. The main help screen is displayed.
3. Press and hold MY CYCLES and BACK simultaneously for 3 seconds. Press EXIT to return to the HOME screen.
This will tell you what exactly is going on with your washer. Good luck!
Mar 07, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Harmony washer will not move from problem notification screen.
Press and hold the my cycles button and the back button simultaneously for 3 seconds. This will reset the control panel and allow you to see any stored errors.
Feb 28, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Ge profile notice: a problem has been detected with this unit
hello: I have a its a GE PROFILE WPGT9350 washer and i have that pop up when i push power button what can i do if you can help this missg "Notice A problem has been detected with this unit if you can tell me how to get to Service Mode Diagnostics" thanks my email is mnunocortes@hotmail.com Actually I have tried unplugging it and letting it rest and plugging it back in, same message. Thanks anything can help
Feb 20, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Notice a problem has detected with this unit
If the home screen is not displayed press home then help. Then press my cycles and back together for 3 seconds.  Read what its says and then turn the power off then back on. It should be ready to go!
Nov 13, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
A problem has been detected with this unit i need know how to enter my Service Mode Diagnostics
I'll email you a few pages out of a service manual for a WPGT9360 (closest I could find to your model number) hope this helps.
Nov 12, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
2,227 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
