Question about Electronics - Others
Base mp3 i have a base mp3 player. when i plug it in the usb port nothing happens. it is though the computer does not reconise it. it used to work on an old computer we had but doesn't on the new one. please help
  • smoglies Feb 10, 2008
    thanks for trying but i think the MP3 is broken
  • John Goncalves
    John Goncalves May 11, 2010
    What is the make and model of the MP3 player?
    Are you running Vista on your new computer?
    Scholar:
  • 193 Answers
That no big problem..u go 2 controll panel,administrating tools somthing like that and take the icon that have a computer symbole..click on the 2cnd option and then the lest option in it...u will see it probably..so format it and try again...
if it didnt work try it on another computer in many system operations..lik mac or vista...cos mac have a difrent format..and dont loose the idea that it might be broken..but i might be gd 2..so gd luck
Posted on Feb 07, 2008
6ya staff
SOURCE:
Can't turn on my mp3 player. I have tried to hold the volume buttom but it does not turn on at all.
what type of mp3 player ?
Charge your MP3 player.
The battery might just be dead, in which case letting it charge for a few hours corrects the problem.
Plug the USB data cable into the USB port on the MP3 player and insert the other end into one of the USB ports on your computer.
In a moment, the computer states that it has detected the removable device.
Sometimes the MP3 player needs to update itself, and it can only do so while connected to a computer.
When the MP3 player detects the computer, it attempts to connect to the Internet and retrieve any system updates available for the device.
Replace the battery.
The battery is usually the first part of the MP3 player to go (especially after excessive use). Although you can manually change the battery on most MP3 players, you need to send your
Apple products (iPod, iPod Nano, iPod Touch, iPhone) into the company so they can change the battery for you.
Purchase a new MP3 player.
If your MP3 player has received any sort ofwater damage, it is not going to turn on at all and there is nothing you can do to fix the issue.
hope this helps
Sep 27, 2012 | Audio Players & Recorders
My zune wont turn on can u help me
Does it do anything at all? Like when you plug it into your computer? If it does nothing on your computer, try plugging it into another USB port on your computer, or try a USB port on another computer. If possible, try another Sync cable, again on mutiple computers/USB ports if necessary. If you have a walll charger try that as well.
What happened whe it stopped working? Was it dropped? Was it working fine, then you plugged it in one night and got up the next morning and it was dead? Was it abducted by aliens? The more info you can give the higher your chances of getting a useful response.
Aug 04, 2011 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My ipod won't work with my computer.
Probably you might need to reinstall the ipod drivers using the installation manual carefully following the guides and steps.
Also check your manual for the hardware and operating system requirements if it matches your computer spec.
But if you're sure the installation was properly done then make sure the ipod suite (PC SUITE) is installed.
Lastly plug in the ipod into other USB ports to ascertain if the USB ports on your PC is faulty.
May 21, 2009 | Apple iPod classic MP3 Player
Trekstor 74412 i.Beat emo 2 GB MP3 Player
I opened Media Player and plugged the mp3 player into the usb port and used the feature called Sync and it started downloading my music onto the mp3 player. I also checked the function in my computer under device manager to make sure the usb port was working correctly.. Hope this helps!
Jan 05, 2009 | Trekstor 74412 i.Beat emo MP3 Player
Phillips go gear SA5125 mp3 player
Make sure you are using the original USB cable that came supplied with the GoGear, and then try the volume + method again. If the volume + method doesn't work, then there is a problem with the USB port recognziing the device being plugged in - or, the player was physically damaged.
May 29, 2008 | Philips SA5125/37 MP3 Player
XP Computer does not detect
Here are some suggestions:
Try using a new/different USB cable. The ones that come with these players are known to be defective at times.
Try using a different USB port on your computer.
Try it on a different computer.
Mar 14, 2008 | iLO (2 GB) MP3 Player
Computer doesn't recognize player
Could be faulty usb port or cable try other computers/ports/cable
Aug 31, 2007 | iLO (2 GB) MP3 Player
Computer won't recognize player
might be dust in your usb port or your connector I had that happen to me before Ii cleaned it with that pressured air stuff and works great. ~Grim
May 29, 2007 | SanDisk Sansa m240 MP3 Player
Electronics - Others Logo
48 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Ekse
Are you an Electronics - Other Expert? Answer questions, earn points and help others
