Question about Sony CDX-M800 CD Player
Front panel wont come down
I have just bought a m800 and the front panel wont come down i have checked the ribbon and it looks fine with no brakes or marks on it in fact it looks like it has not long been replaced any idea what else it could be thanks lisa xx
I had the same problem. i took my radio in and they opened it up and the flexible pcb was snapped in half...
Posted on Jan 17, 2008
I have a maytag dishwasher with a touch panel and all lights work but the power button will not turn on. Any ideas?
Might need a new panel -- on mine I found that the ribbon that went from the panel to the circuit board was either shorted out or unseated. try disconnecting the power to the unit (circuit breaker) taking the panel off the inside of the door and inspecting the ribbon for short (looks like a burn mark) disconnect it from the circuit board and putting it back together. if that does not work then a new front panel is needed since the ribbon is attached to that panel.
Jan 20, 2011 | Maytag 24 in. MDB9750AW Dishwasher
Brakes are going to the floor most of the way checked rear brakes and they are still good bleed them and problem still there
Normally when the brake pedal goes almos to the floor it is an indication of low brake fluid. Low brake fluid is an indication that front and/or rear brakes are wearing. As the brake pads wear down more brake fluid will be required in the wheel cylinders or calipers. Hint, the front brakes usually wear much faster than the rear due to the fact that the fronts due a much greater braking function that the rear. Check the front pads. Don't let them get down to the metal scraping metal stage before you change them out. This causes unnessary damage to the rotors. Look at your master cylinder on the firewall under the hood in front of the steering wheel. If the fluid level is belowhte "max" mark add fluid. Low fliud should also show as a red "brake" light on your dash, but not always.
Sep 08, 2010 | 1994 Honda Civic
Black out
this is a coincedence. The CDX-M800 had a HUGE problem with the ribbon cable on the face going bad, causing this exact problem.
$14.00 and some time will put it back into perfect condition.
http://cgi.ebay.com/ebaymotors/Fix-your-Sony-CDX-M800-flexible-ribbon-cable-CDX-M800_W0QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247QQcategoryZ43947QQihZ020QQitemZ300287945333QQrdZ1QQsspagenameZWD1V#ht_2258wt_1213
Jan 21, 2009 | Sony CDX-M800 CD Player
Front brakes waering out excessively
1. Check your front rotors for being silk smooth
2. Take your truck to a lightly dusty area where you can force a slide without leaving marks and see if your rear brakes are working at all
3. Check fluid level in your mater cylinder for improper levels
4. Anything further...email me
Jan 07, 2009 | 1997 Chevrolet Suburban
Face
Look for a ribbon cable that connects the flip down face back to the main circuit board. It may have a lead that has broken. This is a common problem.
Jul 16, 2008 | Sony CDX-M800 CD Player
Lost function of remote and front panel buttons
it seems like the ribbon cable,the one connects the face to the main board is damage.
I don't know if you can replace it by your self,because you need a little bit of experience on stereo repair,but you can try.you can order the part from pacparts.com
Part number 168795211
Dec 03, 2007 | Sony CDX-M800 CD Player
Can you help me?
That ribbon wire is called as "data cable or IDE cable" You can find it at any computer store..Should cost you around 3$
Dec 01, 2007 | Sony CDX-M800 CD Player
Please help
you can buy these from ebay just type in sony cdx m800 ribbon theres loads on there pretty cheap aswell hope this helps
Pioneer deh-p850mp problem
Check the ribbon cable on the inside that connects the two parts.
You will need to remove the faceplate and open up the Rear of the unit.
If you bought it used, theres a good chance that the ribbon is in fact broken. If its new, check the connections on the ribbon cable.
It is a chronic problem with most all PIONEER units that fold down / out.
Best of Luck.
Please RATE my solution BELOW.
Nov 22, 2007 | Pioneer DEH-P850MP CD Player
Inside buttons do not function at all.
The problem with you radio is the ribbon cable,this part connects the face to the main board.you get it from pacparts.com
parts number is 168795211
you can try to replace it by you own,just becareful with the front button because they may fall dow when you open the face.
Nov 17, 2007 | Sony CDX-M800 CD Player
Sony CDX-M800 CD Player Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
