Question about Whirlpool LER5636P Electric Dryer
Lint screen caked up
I took the lint screen out to clean it and noticed after I cleaned it that it was kind of ruined. The lint seems to accumulate in center. I washed it with soap and water with a toothbrush trying to lean the screen. I thought I did a really good job but it is still caking up. I don't think the clothes are drying well now. Any thoughts as to how to get this residue off of the lint screen?
  • robert samples May 11, 2010
    check your vent from the back of your drier to the out side must be 4"all the way and behind the drier should not be mashed folded or look like a snake laying there if lint is caking on the screen then moisture is not escaping the drier the lint should be easy to peel off not caked if the vent from your house then take it loose from the drier and let me know if the airflow there is Strong also if the vent is running like a rollercoaster under your house water can collect in the low spots and block air flow
  • 30 Answers
Take the vent hose lose at the back of your drier, and clean your lint screen off or replace it, then try drying some clothes. If this technique minimize or eliminate the caking of your lint screen, then the problem is in your vent hose. Clearly, there is an obstruction, or an improper installation of your vent hose.
good luck
Posted on Aug 11, 2008
Lint all over Clothing after rinse.
My washer accumulates lint between the wash tub and the outer chamber. Whenever you wash a load, all the past dried up lint gets reactivated into the new wash water.
If you get a refrigerator or dryer lint brush, you can reach this area and brush out the accumulation. Also the area above the wash tub can get clogged with lint. If you look under the lip between the tub, you can see the fabric softener/bleach channel dispenser, a lot of lint can accumulate there as well.
Clean both areas after a recent wash load when the lint has softened and is easy to scrub off. For safety's sake, unplug the washer. Be ready to be grossed out! I clean my washer every now and then to keep the lint down.
The washer will smell nice and clean after getting this lint/dirtball out. To maintain this lint free environment, see below.
If this fails and is not the problem, go to a thrift store and purchase the cheapest 100% pure wool clothing, some dark colors, and some white. The wool acts like a magnet for lint and will attach itself to the wool before it attaches to your clothes. It can be used over and over if you hang it out to dry. It will get felted and covered with lint.
Mar 15, 2014 | Roper Washing Machines
My dryers smells like its burning and inside when drying gets really too hot. The air vent going outside is clean. I took off the casing and cleaned the inside of the dryer. The belt seems like its ok....
Lint burns quickly and rarely holds a flame long enough to cause a fire hazard. Metal burning would probably indicate friction on spinning metal, like the motor shaft, or the drum rollers. Plastic/rubber are usually parts that are intended to wear, and can usually be replaced.
Along with the belt, you should also check the idler pulley that takes up the slack in the belt, as well as any drum rollers or nylon glides on the top of the dryer door where the drum rides. Metal, plastic, and lint have distinct smells, and you should be able to determine which one(s) you have by smell.
Lint is a common burner in dryers, and it seems you've looked in some of the obvious places it can accumulate. When you have the cover off, pay special attention to the burner area, and any ducts from the lint screen area. Also, any gaps in insulation where air flows could cause hot spots in the unit. If you can see the flame while its running, make sure its size is not excessive. Flames should not be too low or too high, and should not escape the burner housing.
If you notice soot buildup, your gas/air mixture is off. If you've switched from natural to bottled gas or vice-versa, you may need to swap the burner orifices to match the different pressures of the gas fuel.
May 18, 2011 | Kenmore 74632 Gas Dryer
The washing machine does not filter out lint. It
I have the same problem. There's a plastic piece top back of tub that says "Clean lint filter after each load", but where is it ?
Mar 14, 2010 | Frigidaire FEX831CS Top Load Stacked...
Toothbrush used to clean lint out of the screen area dropped
Does it matter if its there?
If you dropped it in without opening up anything you should be able to get it out (With a hassle)
Kind Regards,
J Howard
FixYa Operator
Feb 06, 2009 | Whirlpool LTE5243D Top Load Stacked...
Accumulation of pet hair inside dryer
easiest thing to do ,, if you have a vaccum ,,just vaccum off lint and debris ,,,,
Jan 02, 2009 | Kenmore 63942 Dryer
Back panel removal
it is..remove bottom panel ..after unplugging from wall..remove lint screen next remove 3 screws holding the lint screen/blower housing in place ..clean out housing clean blower wheel with long brush or a long arm clean lint from base and on element housing on right side especially on top of the housing..that is the most important location if lint gets too thick on element housing ..fire hazard....ckd vent behind dryer and to outside if you find a large amount of lint .that is good indication of a restricted vent
Aug 22, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer screen
No. The accumulation of lint in the dryer screen generally doesn't have anything to do the amount that ends up INSIDE your dryer. Too little lint is not a bad sign. It's dependent upon the type of clothing you are drying as well. If the clothes are not "lint givers" (like cottons and wools), you generally won't see a lot of lint in the dryer screen. Dryer screens are not perfect, either and some lint always gets through. As long as there are no holes in the screen and you have it seated correctly, and you clean it after each use, you shouldn't have any problems.
What affects dryer performance the most, is your vent hose and routine cleaning. The simple rule of thumb is: The SHORTER and STRAIGHTER the vent hose the BETTER. The vent hose should also be cleaned thoroughly periodically. I recommend once per season. That's about 4 times per year. What causes the lint to back up into a dryer is when the vent hose becomes kinked or clogged. The lint is mixed with moist air when it leaves the dryer. If it has no where to go, it starts to accumulate and stick in areas of the vent hose that are sagging, or at tight bends. Eventually, the vent becomes so restricted that the lint ends up inside your dryer. This causes the heating circuits to overheat to eventual failure. Not to mention, accumulations of lint inside a dryer can cause a fire. I have personally inspected dryers that were so full of lint that the dryer hose contained about a gallon of water from condensation and the inside showed evidence of multiple fires. If you need further info, I have an article I wrote up explaining all of this under "Tips and Tricks" under my profile. I hope this helps you.
Apr 06, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
101 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
