Question about GE JVM1630 Microwave Oven
Hello Guru, I have a GE JVM1631WB004 microwave and the two lights underneath do not work. I have replaced the bulbs but it still doesn't work. Everything else on the microwave works. What do you think the problem is? Thanks, Troy
  • GE Master
  • 9,098 Answers
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 03, 2008
I have replaced the bulbs underneath the microwave, but the lights are still not working.
HELLO.
This is the solution to the problem as detailed below.
instruments needed
* Appliance bulb
* Screwdriver.
Unplug the microwave. Remove the lamp cover by unscrewing the mounting screws. Turn the bulb to tightly screw it in. Then plug the microwave back in to test the light. If the bulb still will not illuminate, it is likely broken or defective. Replace it with another 20 to 40 watt appliance bulb.
Sep 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing surface light
That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
Cooktop Light/
Night Light
Replace the burned-out
bulb with a 40-watt
incandescent bulb
(WB36X10003), available
from your GE supplier.
1 To replace the bulb(s),
first disconnect the power
at the main fuse or circuit
breaker panel or pull the
plug.
2 Remove the screw from
light cover and lower
the cover.
3 Be sure the bulb(s) to be
replaced are cool before
removing. After breaking
the adhesive seal, remove
the bulb by gently turning.
4 Replace the screw.
Connect electrical power
to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
1 To replace the oven light,
plug.
2 Remove the top grille by
taking out the 2 screws
that hold it in place.
3 Next, remove the screw
located above the door
near the center of the
oven that secures the
light housing.
to the oven.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
CAN'T GET BULB ACCESS DOOR OFF TO REPLACE UNDERNEATH BULBS
Hello there:
first you need to remove the screws from the back of the microwave that hold on the casing and there might be some on the bottom too. then remove the outer casing
the bulb is under the casing towards the front right corner as you are looking at the front of the microwave
Sep 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Crack in GE jvm1631wb004 Door
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
For most models, you can order just the part that's damaged.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Jun 07, 2009 | GE JVM1631 Microwave Oven
GE Spacemaker Moldel # JVM1631WB004 Night Light not working
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Model No. JVM1650AB 003
Hello Diana,
Here is a link to the GE User manual for your microwave oven.. Once you download it.. You will find a section on light bulb replacement that details how to install and which particular bulbs to use..Hope this helps you..
http://genet.geappliances.com/DocSearch/pdf/49400821.PDF
Good Luck !
Sep 14, 2008 | Microwave Ovens
Ge profile spacemaker XL 1800 undercabnet microwave
Remove the light cover /filter opening.Its very easy to remove.The filter will be removed by hand and may give you the best reach.
Please rate this !!
Sep 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1630 Microwave Oven Logo
102 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
