Hp psc 1410v all in one printer
toshiba satellite notebook w/vista home premium
changed out ink cartridge(brand new), quality sheet prints out with instructions to place it on the glass and hit the "Scan" button
Scan button does nothing, power light flashes, each time I turn the printer on it prints this sheet again.
tried scanning it using HP Solution Center, scanned fine but still prints the sheet every time.
SOURCE: HP PSC 1315 Scanning problems
If you're using windows try using window's built in scanning camera wizard (this worked perfectly for my psc 1315). Go to Start -> settings -> control panel -> Scanners and Cameras
SOURCE: Sharing HP PSC 1410V All-In-One
Yes, you can and it is pretty easy.
You should get the HP Wireless Printing Upgrade Kit
(Q6236A#A2L)
Price: $69.99
Here is there product description from HP.
Get everything you need to print wirelessly in this simple upgrade kit! It includes a printer receiver and PC receiver for a wired desktop or notebook PC, and it's easy to both install and use.
Works with most HP printers and All-in-Ones, plus all PCs, wired or wireless.
* Print from virtually anywhere in your home or office via the wireless 802.11g connectivity
* Eliminate ugly cable clutter but still get the same print speeds as via USB
* Retain full all-in-one wireless functionality: print, fax from your PC, scan, and access photo memory cards access and PC status
* Set up fast: just plug the receivers into your printer and PC; there's no configuration
* Protect your signal from interception with the secure wireless connection
* Use with a network, or just one PC
* Compatibility: most HP printers, all PCs (wired or wireless)
** I checked and your HP is on the compatibility list - it is ok***
What's in the box?
1 printer receiver
1 PC receiver
William
SOURCE: Ink Cartridge Alignment
On alignment sheet, do you see a line of yellow blocks?
And on next line do you see alternate block and yellow blocks?
(Without these, alignment fails)
If not, change the colour cartridge, re-print the page and repeat alignment.
Good luck...
SOURCE: Scanner
Check the power and the data (USB) cables in the printer...check both ends...
Check :-
# The printer powers on properly
# There also can be problems with the printer driver
# and also internal printers....
Try reinstalling the printer driver...
<PLEASE RATE ME AS FIXYA>for my help......................
