Question about Hitachi 65SWX20B 65" Rear Projection Television
Hitachi 65SWX20B 65 in. Rear... Problem
My set is a little over 4 years old and just developed "convergence" problem where the colors are separated and the lines are not vertical and horizontal when I select "magic focus" in the manual mode. I am able to combine the different colored lines to produce white lines (and a better picture) but the lines are curved and I lose a curved portion of display from top of the screen. I have to use "magic focus" in the manual mode to "converge" the three colors every time I power on the set.
Hitachi tells me that I must contact a local independent repair shop. If anyone has fixed a similar problem (e.g., replaced a chip), I would like to hear from them.
Thanks.
  • 1 more comment
  • harishw Jan 15, 2008
    Guru Draude,
    Thanks a lot. It sounds very helpful. Now I have to open the unit and find the convergence amplifier module. Any help with that will be further appreciated.
    Thanks,
    Harish
  • StevenJH Jun 29, 2008
    I have the exact same problem. My set is also a little over 4 years old and just developed "convergence" problem where the colors are separated and the lines are not vertical and horizontal when I select "magic focus" in the manual mode. I am able to combine the different colored lines to produce white lines (and a better picture) but the lines are curved and I lose a curved portion of display from top of the screen. I have to use "magic focus" in the manual mode to "converge" the three colors every time I power on the set. My chips though are STK392-110 & the back one is STK392-150. It looks like I will have to take the board out as they are probably soldered in. It looks like I can just remove the four screws, then disconnect the board from the one next to it, and lift it out, right? Any special trick to seperating it from the next board? Where exactly will I find the resistor burned in the output of the IC's? I'm not sure where to look for the output of the IC's. The chips were right where you said. I found the chips for less than $7 a piece, I'll really be a happy camper if I can fix this myself! Thanks!
  • xentro Dec 06, 2008
    I have the same problem, last night the green lines curved on the top side of my screen and I tried to use magic focus but it did not work. how can I fix it? I need step by step please since I am not a TV guru but I do follow directions very well.
    Problem Solver:
  • 11 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are baHitachi 65SWX20B 65 in. Rear... Problem - 2c07611.pngd be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on May 07, 2009
  • 71 Answers
You have to replace 2 IC's STK 392-120 in convergence amplifier module. If you're a good handyman you can do it by yourself, if not call a tech. Also you can find one resistor burned in the output of the IC's. Replace that too.
Posted on Jan 15, 2008
  • Eduard P Jan 15, 2008
    How you open it (unplugged first) is in your right hand. You'll see 2 aluminium radiators with 2 black IC's. Got it!
Image is showing double on the screen. The entire screen's images are doubled and overlapping over themselves. Some color distortion obviously as well. Images basically aren't lining up. The red color...
On Rear Projection TVs there is a thing called "convergence" in which the color bands are lined up so that they can mix to make the colors that we see on the screen. When a TV of this type is moved or bumped around, or even near a source of electrical interference it can throw this out of alignment. Many TVs have options in their menus to set convergence.
I believe it is under Menu > Picture > Convergence I'm having trouble finding the exact process used for this, but it will be noted in your user guide as well.
If this does not resolve the issue you may need to purchase a convergence repair kit which requires a considerable amount of electrical knowledge and can take several hours to repair.
Feb 28, 2011 | Hitachi 65SWX20B 65" Rear Projection...
Convergence issue. lost about an inch on right side of screen model 65SWX20B after i manually adjusted convergence grid.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 16, 2011 | Hitachi 65SWX20B 65" Rear Projection...
Separated picture, one bright pink, the other bright lime green. The top and bottom of picture is distorted. The center of the picture is the best in all respects.
Please replace convergence output chips in tv to solve this issue, tv has two big black ICs at right side and number is STK392-110, replace both ICs to fix picture problem
Thanks.
Jan 25, 2011 | Hitachi 65SWX20B 65" Rear Projection...
My Hitachi 65" rear projection TV screen looks like 3D. I read somewhere that it is a convergence problem, but I don't know how to fix it myself. Can someone help me?
I would really like to know how the information I gave you was rated as not helpful. I would hope you will change it and rate it at what i should be as i gave you all the information you requested.
Thanks,
Lee
Aug 13, 2010 | Hitachi 65SWX20B 65" Rear Projection...
Getting a 3d image
The tv have a problems known as a convergence problems,it dead.The tv convergence board require 2 STK convergence ICS and some or all it resistors to be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 20, 2010 | Hitachi 65SWX20B 65" Rear Projection...
65SWX20B 65 in. Rear Projection Television: how do i clean my Hitachi 65SWX20B 65 in. Rear Pro...
Remove the upper back cover of the television and clean the back of the screen, the mirror which reflects the image onto the screen, the focusing lenses (do not loosen or remove the wingnuts).
May 05, 2010 | Hitachi 65SWX20B 65" Rear Projection...
Top of the screen looks like its melting and the picture has double vision as if you were watching a 3d movie with no glasses
Your TV most likely has a convergence failure. ( common problem )
  • Screen looks 3D
Here are some photos of convergence problems.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 01, 2009 | Hitachi 65SWX20B 65" Rear Projection...
Cracked Screen
Screen Assy. part number #KR02553 cost $664.99 plus shipping.
Apr 30, 2009 | Hitachi 65SWX20B 65" Rear Projection...
My hitachi 65swx20b
Hi, convergence circuit has failed, unless you have electronic knowledge and soldering equipment you`ll need a tech for that one, questions? email me back, BMW Rider
Feb 26, 2008 | Hitachi 57F500 57" Rear Projection...
My Hitachi 65SWX20B Model, made in 02, just developed Picture disturbance
Can you post a picture of the set. This might be a convergence problem. seeing the set will confirm this.
Thank you,
shuttle83
Oct 28, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
Hitachi 65SWX20B 65" Rear Projection Television Logo
907 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
