Question about Fisher Paykel EcoSmart GWL15
Fisher & Paykal washing machine, Mod:GHL10US
My Fisher & Paykal washing machine stop in mid cycle. Using the diognostic mode I got (00XX0 0X0). According to the sheet this mean that "Hot and/or cold water valve faulty". I don't have a service manual. Does this mean that I should replace the hot and cold water valve?
I was told by a service guy that I should replace the motor control board. This does not make sense to me and it is really expensive.
What do you suggest?
  • Anonymous Jun 30, 2008
    My machine takes forever to fill and more than often will error out before it reaches the firt wash cycle. I have well water and assumed that there was
    sidime in the hose. Several times when I disconnected the cold water hose cleaned it out then reconnected it the problem went away - this doesn't work anymore -- could I need to have the cold water valve replaced?
  • Gary Davd
    Gary Davd May 11, 2010
    the valve is cheap the motor ctrl board is Expensive I would say the valve isbad by what you have said..the mtr ctrl board does just that controls the motor not the water
I have a Fisher Paykal model GWL11 washer. After doing a successful load my wife tried another 15 minuts later and the power won't go on. There's power at the plug and she also unpluged the machine and tried later but no power
Posted on Jun 16, 2008
  • 770 Answers
If you want to find out for sure post your email here and i will send you the service manual
Posted on Feb 17, 2008
  • Betty Apr 19, 2013
    Fisher and Paykel EcoSmart GWL15 console is dead. How do I replace it?
Why would it stop mid cycle? You can hear the engine trying to start.
It is not the engine but the motor that makes the noise. perhaps it can be a mechanical issue that stops the machine at mid cycle due to friction on the drive or it can be due to faulty control panel or even a dirty/ clogged drain pump.
Sep 07, 2012 | Fisher and Paykel Washing Machines
F & P MW511 Washing Machine ... Driving me Mad ... Please Help!
Size setting
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size.
The cold water temperature LED identifies 5kg.
The low water level LED identifies 6kg.
The hold spin speed LED identifies 7kg.
If the product has not been setup before all 3 LEDs will be on.
To set the size for 5kg push the wash temp up button then
the power button.
To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button.
This locks the size
into memory. To check the size is set, start a cycle.
Aug 16, 2012 | Fisher and Paykel Fisher & Paykel Washer
I have a Fisher and Paykal Smart Drive 053 washine machine. It has just started doing the following: Start load - Cold, warm or Hot and any size Fills intermittent. will fill for a couple of seconds...
Hi just read your posting.When the machine stops and starts does it beep and show an error code.This error code will be a series of lights that light up and the machine will beep.On the wash progress line of lights which lights are lit when the machine beeps,Is it the 1st and 6th or the 4th and 8th etc.Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Jun 05, 2011 | Fisher and Paykel (IWL12)
Hi i have a fisher & Paykal IW812 Intuitive Eco washing machine it gets to the rinse drains a little water then nothing happens time still counts down but nothing happening gets to the spin cycle then...
Hi just read your posting.Unless the machine shows an error code the diagnostic mode will not help.Does the machine agitate in the wash cycle?Does the machine drain the water completely?Does the machine spin the clothes dry.Please reply with additional information on the questions I have posted and I am sure I can help you rectify this fault.Looking forward to your reply.
May 21, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykal GWL 10 US - Stops before rinse
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
Stops mid cycle
CHECK DRAIN PUMP AND DRAIN HOSE FOR RESTRICTION
Jun 01, 2008 | Fisher and Paykel GWL11 Top Load Washer
...most likely the balance sensor, a small contact switch behind the main control panel that is telling the machine it is out of balance, more likely the switch and/or contacts have corroded...
Aug 06, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel EcoSmart GWL15 Logo
340 people viewed this question
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
