Question about Radio Shack Pro-95 Handheld Scanner
Pro-95 locking out channels
I have the Radio Shack Pro-95 hand held scanner and was wondering why I can not lock out channels on the 0 bank? It will alow me to lock out channels on all other banks but not "0". All of the frequencies on this bank are in 800mhz as well as the other banks. Does anyone have any suggestions for me?
  • 204 Answers
Hi, I would check out this site. These people eat and sleep scanners and should be able to steer you the right direction. They also have a huge database of info,,, good luck with it. Mechanic
http://www.radioreference.com/forums/forumdisplay.php?f=6
Posted on Jan 16, 2008
Pro-95 scanner can't unlock key pad can't reset can't initialize
my pro-95 has a locked number on the key pad--says=mooo**adl+*30375=bank 0 ch 00 ed: none can you help me get it unlocked ?
Jul 24, 2012 | Radio Shack Pro-95 Handheld Scanner
I have a pro 95 dual trunk scanner & it says all
  • Hi, I can help.
  • You probably have all frequencies in that bank locked out and all other banks locket out as well so you are seeing "All Ranges Locked Out."
  • You should be able to just push the number of the bank you want to have active again and activate it. If you have locked out some frequencies just press "MAN" for manual and scroll up and down through all the frequencies and hit "L/O" and the L/O will change to l/o (lower case letters) indicating the frequency is no longer locked. This has to be done manually for every frequency as there is no "master unlock" function on this scanner.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 27, 2011 | Radio Shack Pro-95 Handheld Scanner
My pro-95 scanner screen reads all channels locked out! How do I get it back to working mode.
hello firstly select the mode and bank number ,press and hold L/o button this will unlock all channels and ready for programming you will notice that the L/O button is now removed from the screen
goodluck
Apr 19, 2011 | Radio Shack Pro-95 Handheld Scanner
Pro-96 Scanner: My pro 96 scanner says all channels locked and it ...
If there is no frequencies on your scanner it will lock all channels out. if all your frequencies are on one bank and you accidentally hit that bank number and turn it off it will lock out all channels. If that's the case just hit that bank no. back on and they will unlock.
May 17, 2010 | Radio Shack Pro-96 Scanner
Pro-96 ,channels 1 thru 9 are locked out ,only 0 is
You are referring to banks, not channels. When bank 0 is active, then you push 0 to de-activate it, you have now removed all your banks from the scan list. To re-activate any bank, just press any number. This is confusing because locking out a channel and removing a bank from the scan list are two very different operations but use the same terminology.
For more information and some tutorials to help with various functions, visit this site: http://support.radioshack.com/support_tutorials/communications/20-526.htm
Feb 11, 2010 | Radio Shack Pro-96 Scanner
I have a Radio Shack Pro-96 Digital Handheld scanner with at least three channels locked out. My fault but would like to get them to work again as I have a $500 scanner and it is locked out on these...
Are you talking about banks? (0-9) If so, choose one sole bank (i.e. 7) and press MAN, then PGM, then TRUNK. Once here, Press the FUNC key on the left hand side and I believe you press "1" on the keypad afterwards. This will unlock the specified bank. If it is no "1", try the other numbers. Hope this helps...
Jun 05, 2009 | Radio Shack Pro-96 Scanner
All Channels lock out
This happened to me and i reprogrammed the frequencies with programming software and all is well.
Apr 05, 2009 | Radio Shack Pro-94 Scanner
Bank are locked out
Simple, some Radio Shack models respond to their preset lock out override control protocol. Try holding the lock out button and the scanner should override the lock out on the banks. If that doesn't work, you may need to un-lock them one by one, which may be time consuming. Or, you could reprogram the scanner all together.
Hope this helps!
Jun 30, 2008 | Radio Shack Pro-2096 Base Scanner
Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Jan 02, 2008 | Radio Shack Pro-95 Handheld Scanner
All channels locked out pro-2055
I hope this will help. It shows locking and unlocking ids while scanning and while in a bank.
Locking/Unlocking IDs Contents You can lock out IDs you don't want to hear such as telemetry, MDT's, dog catcher, etc. To Lock out an ID while scanning, quickly press L/OUT while the ID is displayed. To Lock or Unlock an ID manually: 1. In Manual mode select any channel of the bank you want to lock or unlock an ID in by entering the bank number and channel number (Ex: 001) then press MAN to advance to the channel. 2. Press PGM then TRUNK to put the scanner in program and trunk modes. You will see the bank number (0-9), list number (0-4), and the list status (ON or OFF) on the 1st line, the ID# in the list (0-29) on the 2nd line, the ID on the 3rd line, and bank tag on the 4th line (if programmed). 3. Press TRUNK (each time) to select the ID list (0-4). 4. Select the ID# (0-29) by pressing up.jpg or dn.jpg (or press and hold; faster) then press L/OUT to lock or unlock the ID. An L will appear to the right of the ID# if the ID is locked out. 5. Press MAN to exit programming. To Unlock IDs in a bank: 1. In Manual mode select any channel of the bank you want to view the locked out IDs in by entering the bank number and channel number (Ex: 001) then press MAN to advance to the channel. 2. Press PGM then TRUNK to put the scanner in program and trunk modes. You will see the ID list. 3. Press FUNC then L/OUT (each time) to view the locked IDs. Press L/OUT to unlock the ID. The next locked out ID will appear. 4. Press MAN to exit programming. Note: You cannot unlock all IDs at one time.
Nov 18, 2007 | Radio Shack Pro-2055 Base Scanner
Radio Shack Pro-95 Handheld Scanner Logo
132 people viewed this question
Top Radio Shack Radio Communications Experts
john milligan
Steve
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
