Question about Rainbow E series Canister Wet/Dry Vacuum
Rainbow SE I turned the vacuum on and it worked to do one room Then I shut it off to wait until my husband got of his call. I realized that their was cloggage in the vacuum part that vacuums the carpet and unclogged it. I then tried to turn on and it was dead. I have the water filled just above the stick.
    President:
  • 1,673 Answers
The clog may have over heated the motor, usually if you unplug it then after little while, try it again. If it still won't go, does the separator turn easily or is it bound up and won't turn. Take it off and see if the motor will run(without water) You didn't say which model you have, but some of the newer ones have a small shaft, on the water tank, to activate a switch when you put the water tank on. If it is gone, or didnot seat right, then it won't turn on.
Posted on Jan 15, 2008
Rainbow turns on for a second or two then quits and won't turn back on.
If you have the model Rainbow E-2 eSERIES then the Motor Rainbow 120v could be going bad. This will trip the auto reset until it cools down.
If you have an E2 Type 12 Rainbow, then the Controller Asm 120v e2 Silver Gold could be going bad.
Our technical support team is available if you need... Contact Us
RainVac
Mar 24, 2016 | Rainbow E series Canister Wet/Dry Vacuum
My rainbow stop working.no red lights.3 times try to start and then switch off by itself.what should I do?
PDF]3 - Rainbow
rainbowsystem.com/.../Rainbow_e2_2011_R14449A-1_English_P...
RexairAs part of Rexair's Customer Care program, each Rainbow and Power Nozzle receives a ... If the Rainbow is not working ... Do not clean the unit or unclog the hose until theRainbow is switched off and the plug is removed from the wall ..... alone or with the Jet Brush attached. ..... The Power Nozzle brush is stopped and.
My Rainbow Vacuum Cleaner Won't Turn On ' eHow
Rainbow keeps shutting off Vacuums Questions & Answers ...www.fixya.com > Forum > Tags > keeps shutting off > VacuumsRainbow vacuums keeps shutting off related questions and answers. ... My Rainbowstopped running I was using the Rainbow and it stopped running. ... the switch . my electrolux has the same problem but wont always turn on.so it probably is ...Three common problems with Power Nozzles and how to fix ...
Dec 03, 2015 | Rainbow Vacuums
Rainbow power head works but canister dont model d4
Chances are the motor died or went bad.
You would have to get a new motor.
You can find one here:
Rainbow D4 SE motor 120V
Or a more cost effective refurbished D4 motor unit here:
Rainbow D3 D4 SE motor unit
GoodVac.com
800-775-6586
Jul 04, 2014 | Rainbow E series Canister Wet/Dry Vacuum
How does Aqua Mate attach to Rainbow SE vacuum?
You can download the manual here...
Rainbow Vacuum Manuals
We are also available if needed at Contact Us
RainVac
Jun 18, 2014 | Rainbow E series Canister Wet/Dry Vacuum
How to get to the rainbow SE vacuum off/on switch.
Hi, here is a walkthrough on how to get to that part here. Steps 1 - 14 on how to access it, you will need to take apart the housing to get at it. If you need a new switch you can find that here. Rainbow did redesign this switch, so you will need to look at the wiring diagram if you are installing a new switch.
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
May 18, 2014 | Rainbow Vacuum Cleaner Power Switch D3,...
I bought my rainbow se vacum 4 years ago and I was using it and suddendly stoped working, I try to on no power I on and off not working at all. what shall i do is there posibility to work again.pls.help...
Hi, there is no reset button on a Rainbow vacuum.
All SE series vacuums have a built in thermal and load fuse on the motor, and if it blew, it has to be replaced, or wired directly, with out it on there.
Motor brushes are usually the source of a non working Rainbow D4 and SE and all model Rainbow vacuums and when they burn out, they usually take the motor armature with them, from excessive heat and flare electrical arking to the armature. It is probably the thermal and load fuse, that is your problem, if you did not smell any electric burning type of smell, before it quit. It could be the power switch, but not as likely as the fuse. If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Feb 13, 2010 | Rainbow 75th Anniversary Canister Vacuum
My Husband put a cleaner in the water when turning the vaccum on.
If nozzle works but the main unit does not then it leaves only few things - motor is "kaput" or some wire got loose somewhere. When motor burns it usually stinks pretty bad.
You have to open it up to see and test. We can do it for you but you'd have to ship it here.Se instructions
Feb 01, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow SE makes Squealing Noise when switching it On/Off
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=528929
Rainbow SE makes Squealing Noise when switching it...
Posted by ray_s51 on Apr 20, 2008
My Rainbow SE works and runs strong but when I switch it on and off for approx. 20 to 30 seconds the motor makes a loud squealing noise. Do I need to oil something or what? Nothing smells, it does not make the noise all the time, but it does more often than not. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum.
The Rainbow has 3 fans in the bottom of the motor and if they are weak they will make noise from the motor unit. Watch out… the repair of the Rainbow may exceed the cost of a new motor of which will solve your problem of noise and separator --- compare the cost and the labor and make a decision. The separator is part of the armature, the separator should be able to be removed and that might be one of the things making noise. As normal maintenance the separator should be removed and cleaned after every use and re-installed, then place a newspaper or towel under the motor unit and turn on the Rainbow and spin the moisture out of the motor unit. This should be done every time you use it. If you have further questions please feel free to contact your local vacuum cleaner dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 20, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Open Questions:
See all Rainbow E series Canister Wet/Dry Vacuum Questions
Rainbow E series Canister Wet/Dry Vacuum Logo
186 people viewed this question
Top Rainbow Vacuums Experts
Doris Wittkamm
Level 1 Expert
Jim Parker
Jim Parker
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
