Question about MSI K8N Neo4-F Motherboard
Front pannel pin
Hi mate i have put motherboard in i know silly question but i can get all the buttons to work the reset button works but not the power can u help ?
    Champion:
  • 207 Answers
Your'e on the right track dude:
click on this page to solve your problem..
http://www.hardwarezone.com/guides/intel-socketT/index.php?pg=21 and http://www.hardwarezone.com/img/data/articles/2004/1215/11-fp_power_led.jpg
Goodluck dude, i hope i've help you with this =)
Posted on Jan 15, 2008
How do i connect the front panel (Powerbutton etc.) with my acer m7721 motherboard (FP1 Pins)? Thanks!
Look onto motherboard there is marked as a name of pw btn--power button and plug in front pannel pwr cable pin here
Sep 23, 2014 | Acer Aspire 7720 Notebook
I have asrock agp8x p4i65g and don`t know how connect fron power/reset buttons and fron lights. There`re 5 lines power sw, reset sw, H.D.D. led and 2 ampty
yea there are 5 lines one is power switch other is reset the power led then hdd led then in older motherboard there is provision for speaker The power switch is in the front pannel of the motherboard if you have multitester the power which will indicate 5v the power switch is to be conected to the 5v and the ground normally the front pannels details will be given in the motherboard
Mar 28, 2011 | Computers & Internet
Dear sir...greetings... i have a ibm fw82801db motherboard which is working fine... the main problem what i am facing is i have a 20 pin front panel jack like FDD jack as unable to connect my front...
Because of the many configuration of motherboard, I can possibly know how to help you with this problem without the keyboard in front of me. The best advice to you is to go back to the manual to find the proper connection of those jumpers.
Feb 26, 2011 | Intel Desktop Board D845HV Motherboard
Problem with panel front conector in Dell Dimension 2200 motherbo
The following information is to assist you in performing the right connections. You should take precautionary measures such as grounding yourself and completely disconnecting the PC form any source of power.
This picture shows the connector for the front panel power button, reset button, and power and hard disk lights: an 8x2 pin connector with 1 pin missing:
The table below lists the pinouts for the connector. The orientation of this table is the same as the picture above, this shows the top part of the connector. All the pins below pin 8 appear to be non-connected.
Each pair of pins labeled Power and Reset goes to the 2 wires for the corresponding button. The hard disk and power LED wires connect to the corresponding LEDs, you need to ensure the proper polarity of the + and - wires for each LED or it will not illuminate.
The above information is for your information only.
Mar 01, 2010 | Dell (2M502) Motherboard
I need the pin cinfig, for the front pannel
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 01, 2009 | MSI MS-6580 Motherboard
Power reset pin connection problem.
Here is the manual that will definitely sort out your query mate :-)
http://www.adrive.com/home/downloadfile/136114849
Lemme know if the solution works mate
Feb 12, 2009 | Biostar M7VKG Motherboard
Gigabyte GA-8INXP Motherboard Problem- front connector pins
If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
Sep 19, 2008 | Gigabyte GA-8INXP Motherboard
RCA DRC8030N
Hi. I recenlty fixed a unit with the same problem and I had to replace the motherboard. I could not get the remote to do a darn thing and the front pannel buttons would not do a thing either. Before going to the extreme, and if you still have functionality via the front pannel buttons, try to reset/format the unit. Keep in mind that this will erase everything on the hard drive. While in the main menu and with no DVD disk inside, press and hold the play and open buttons for about 7 seconds until you get the FORMAT message on the LCD. If this does nothing to leviate your problem, then replacing parts will be needed. I do have plenty of mother boards and hard drives left and would not mind selling them. Thanks.
Aug 20, 2008 | RCA DRC8030N
How to connect front pannel
How about a picture? Pg. 46 in your manual.
Need manual, download from Intel. (Click on link).
http://www.intel.com/support/motherboards/desktop/RC440BX/sb/CS-013608.htm
Intel RC440BX Specification
Pg. 46
Basic rules case wiring. The color black is considered ground -. Power wires + can be any other color including stripped wires. (This is standard but case Mfg change to their own specification).
Pin 1 is + power for LED Hard drive green LED, Pin 2 is -/ground for Hard drive LED.
(Pin 3 is + power for LED Hard drive yellow LED, Pin 4 is -/ground for Hard drive LED).(See more options on pg. 47).
Pin 5 is + power for case On/off button, Pin 6 is -/ground On/off button.
Pin 7 is + power for Reset Switch, Pin 8 is -/ground for Reset Switch.
Once positive & negative pins has been located each connector follows in suit.
The Intel RC440BX front case connector is in an odd location.
The user will find it hard to connect front case LED connectors while the board in installed into the case.
Good Luck!
Mike
Apr 25, 2008 | Intel Desktop Board RC440BX...
MSI K8N Neo4-F Motherboard Logo
173 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
