Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
TV screen behave like power is cycled from On-OFF-On when channels, volume or any remote menu button changes.
While Tv is On, changing volume, channel or any button press on the remote control will trigger the TV screen into a power cycle (On>Off>On).
  • VC777 Jan 18, 2008
    Reply:
    What does CFLs stand for?
    Sergeant:
  • 395 Answers
Do you have CFLs on in the room or adjoining rooms?
Posted on Jan 17, 2008
  • Robert Johnson Jan 22, 2008
    CFL's are "compact fluorescent lights" these are the funny looking energy saving lights. the trouble with these are that they send infra red signals that can be interpeted by the set as a command. they have been known to phfantomly turn off and on TVs or other commands. so remove them and see if it happens agian.
I do not have the remote to my Hitachi TV and need to change the channel to get picture. How do I manually change the channel if the screen is black.
Look on the TV for buttons for power, volume up and down, channel up and down and menu.You can get a new factory remote from here :
Jan 22, 2017 | Hitachi Televison & Video
How can I change to channel 3 to view cable?
The TV has no manual channel change buttons on it? I have never seen this on any TV ever.
Mar 19, 2016 | Sylvania 6513DF 13" TV/DVD
Cant use menu
You may need a different remote. Is this a universal remote? Some of them have these common problems. Mine, for instance, doesn't use the OK button at all; instead, the Menu button counts as the OK button.
Try navigating the menu with the TV's volume / channel buttons (the ones on the TV itself, not on the remote). This usually works. Try that until you get a different remote.
Jan 29, 2018 | Vizio VX32LHDTV10A 32 in. LCD HDTV
SDTV CONVERTER BOX BLACK SCREEN MENU WONT COME UP
Maybe pressing the SETUP button the remote will get results.
Nov 28, 2013 | Magnavox TB110MW9
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
RCA TV picture bigger than screen
if the tv width is ok try entering to service menu (do not use remote control) as follow:
1) turn the set on.
2) press the menu button and hold it down while pressing the power button.
3) while holding down the menu button release the power button and press
the volume + button.
4) The screen will display a one line menu, on the left the parameter P00,
and on the right the value of the parameter V00
5) release buttons.
6) using the volume + button change the right parameter until 76
7) using the channel down button change the left parameter until 06 (vertical size)
8) whith the volume + or volume - adjust the screen size.
9) when your tv is OK back to parameter 00 using the channel up button.
10) press menu button.
and trouble solved.
Mar 05, 2010 | RCA F32650 32" TV
Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Jan 11, 2010 | DISH Network DVR-625 DTV Receiver /...
Tv channel is automatically changing
sounds like it need some cleaning , or main board might be disaligned , open it and take a look at the plastic buttons that touches the main board switches , good luck , AJ
Oct 24, 2009 | Televison & Video
Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
Sylvania SST4272
I had the same problem with a Sylvania SRT2227S. I kept trying to fix it using the remote but after reading your posting I pressed the Volume (down) button, which cycled through the same menus you mentioned. Then I pressed the Power button on the TV and that fixed it.
The problem started for me when pressed PIP, CC, and Guide buttons on a Philips universal remote control. My TV does not support these functions and it seems to put it in this "service mode". Now I can fix it by pressing Volume (down) or Menu then the Power button on the TV (do not use the remote as it is useless when the TV is in this mode). I hope this works for you too.
Nov 25, 2007 | Sylvania 6419TC 19" TV
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
129 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
