Question about Hitachi 53FDX20B 53" Rear Projection Television
Woke up to watch tv this morning and I had a distorted picture. Everything seemed to be bury and not in focus. After researching for awhile, it became obvious to me it was the two convergence IC's. My question is I unhooked the board to take a look at the bottom of it to see if any resistors were discolored. Then i noticed a green wire sodered between the chips was discolored where it meet the board. My question does this wire need to be replaced and be re attached in the same location or just the chips. Thank you! Hitachi Ultravision Model # 53FDX20B
    New Friend:
  • 21 Answers
Replace both convergence amps(probably STK devices) and resolder wire.
Posted on Dec 20, 2009
SOURCE:
The picture on our Sony TV Model KP-43HT20 recently became distorted, concaving at top and bottom. If I use reset the Flash Focus, the picture will return to full screen side for awhile but the colors do...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergene board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 15, 2011 | Sony KP-43HT20 43" Rear Projection...
Must have blown something...all of a sudden after 9 yrs of use...picture is distorted. seems to arch toward the middle and mostly red and blue. Can watch it but very very distorted. sup?
I had the same kind of problem with a projection tv I had it was as simple as removing the front panel to expose the lightbulbs where there are 6 screws two for each color one for focus and one for power if after adjusting theese and going into the setup and adjust the color calibration it still does not work you want to make sure the three light bulbs on the bottom are alll working as missing one light can cause tints and the distortion your talking about
Mar 30, 2010 | Sony KP-53HS30 53" Rear Projection...
I have a sony kp 48s and there seems to be a blue shadow on the picture?? i've tried everything in the settings to fix it but it just seems like a manufacture malfunction?
You probably need to get a Sony TV Convergence Kit. More information can be found using the link below.
Convergence Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 28, 2010 | Sony Televison & Video
Picture looks concave ,mostly yellow,and double vision on words
Remove unshielded speakers or other metallic objects near the TV. It can cause picture distortion.
  1. Tune the TV to channel or cable program.
  2. Run the TV for at least 30 minutes.
  3. Press FLASH FOCUS on the front panel of the TV.
  4. A cross pattern appears and FLASH FOCUS begins to
    work. The adjustment is completed when the cross pattern becomes white and you are returned to the program you were watching.
You cannot perform any other functions until FLASH FOCUS has
completed its cycle. If you perform any other operation while FLASH FOCUS is in progress, FLASH FOCUS operation is canceled.
Oct 30, 2009 | Sony KP-57HW40 57" Rear Projection...
Have sound but no picture on RCA
Resolder all the Pinns on FBT flyback transfomer, CK capacitors cp114,120,150 if ANY OF THEM IS PUFFED UP ON TOP REPLACE ALL 3 OF THEM 2200UF 16V (2) 220UF 35V.
Feb 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Distorted picture,After power loss
Replace both STKs covergence chips 392-56or 570s use same STK numbers.
Dec 12, 2008 | Mitsubishi VS-50805 50" Rear Projection...
One half of picture is distorted
to create the total geometry in the tv is needed a system called Convergence.Convergence amplifiers are damaged in this unit, magic focus cannot work because magic focus works to level computer and controls the amplifiers damaged. this repair is for a technician because an adjustment is needed after the amplifier's replacement.
Oct 09, 2008 | Hitachi 61SBX59B 61" Rear Projection...
50" Plasma HDTV
Hello ndulgebeauty,
This sounds like a power supply problem. I would advise that you get a qualified TV technician to troubleshoot this problem. The reason being is that the TV does not come on at all. The problem might be the main power board (AC to DC) or the secondary power board (Switching Power Supply and distribution board). Have these checked first.
I hope this helps,
Thank you,
Shuttle83
Aug 21, 2008 | Televison & Video
Crashing sound on Protron 32 TV
no sound, everything was working fine the night before. woke up the next morning, and turned the tv on, and there was no sound at all. nothing from the TV, DVD, and nothing from the Computer. Please help. [email protected].
Dec 26, 2007 | Protron PLTV-32 Television
Dvd playback
Maybe it's something with picture settings, i.e. NTSC/PAL or INTERLACE/PROGRESSIVE SCAN.
Oct 07, 2007 | Bose 3·2·1 Entertainment System...
Hitachi 53FDX20B 53" Rear Projection Television Logo
142 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
