Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Washer no draining
We have a Whirlpool Calyso Washer, teh lights come on but is stopped moving and the water will not drain out, we had to drain the water out by hand. I can not find anyone that works on these in our area.
  • 3 more comments
  • bpalmer66 Jan 20, 2008
    I seem to have the same problem. I ran the diagnostic test that you mentioned. The timer went to 90 seconds, it ran its test and shut off after the countdown. I did not get a code.
  • Anonymous Jan 28, 2008
    I ran the test as discussed and got no codes. I then tried to run a spin cycle as it had water in it. It spins but doesn't seem to drain. After some time it gave an Ob code and stopped. Thing is there was not anything in the machine except the water, the clothes were removed when the unit failed last week.
  • SOSICKOFTHIS Jun 09, 2008
    I'M SO SICK OF THIS HEAD-ACHE MACHINE. 8-7-8-7 MINUTE, NO DRAIN .PLEASE HELP,PAID ALOT OF MONEY FOR THIS HUNK OF ****.
  • bpalmer66 May 11, 2010
    I have ran the test. It ran for 99 seconds and did not post a code. I tried a spin cycle and got an Ob code. There was nothing in the washer except water.
  • robert samples May 11, 2010
    ok i will try to help first we are going to run it in auto diagnoses mode get a pencil and a pieceof paper so you can write any codes or failures press,soak-soil level-soak-soil level, that should put in auto diagnose mode then watch it run the tests will take 5 minutes and make sure the lid is closed will not operate with the lid open
  • 770 Answers
Did you get the tests done??
Posted on Jan 27, 2008
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
I have a whirlpool calyso washer that will not drain and is giving me the LD code. How do I check for blackages in the draining hose?
Pull the name tag off on front panel take screw off pull top forward and lift two more screws to take front panel off your pump will be on the right hand side close to the base of the washer
Jun 05, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso error code
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 31, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer stops when Ld comes up on display before final spin, but washer drains fine.
ld flashes if it takes longer than 5 min to pump out water to the point where the operating pressure switch resets.check the drain line for kinks,check drain for blockage,check pump operation.
Jan 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
Jan 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Won't fillCalypso whirlpool washer model#GVW9959KQ1 LD on display
LD is long drain error, the machine does not fill because it is in fault mode, but error is on drain system.
If there is a drain problem, the parts that must be checked are drain hose, pressure switch, drain pump assembly, timer control.
Check if the drain hose at the back is kinked or blocked.
Test the pressure switch, blow into the small hose, and use a multimeter to check if switch has continuity.
Remove access panel and get to the drain pump hose to check for ablockage. You will need to disconnect the hose and collect the water.
Keep a container ready to collect water when you undo pump hose.
Ifall the rest is OK, test and eventually replace timer board.Problemwith water pump are far more commonly causing this problemsthenfaulty timer board.
Parts and diagrams available here.
Oct 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Water pump out??
The washer filled with too much water, causing a switch to trip. Then everything stops. It tries to drain during FL but if it can't drain, the washer powers down.Choose Drain & Spin to let the washer drain. Then you have to take the washer apart. Fix the problem. I personally can't tell you what to do because I don't own a Calypso.
POSSIBLE CAUSES:
Bad Pump
High Water Flow
Other Causes
Jul 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso washing machine
WP HAS HAD A ON GOING ISSUE WITH THIS THAT IS THE REASON WHY THEY REDIGNED THE DRAIN PUMP. YOU NEED TO 1ST DRAIN OUT AS MUCH WATER MANUALLY AS YOU CAN THEN DISCONNECT ALL YOUR HOSES FROM WALL TAKE THE WM OUTSIDE TO DRAIN THE OTHER 3 GALLONS OF WATER YOU CANNOT SEE. TURN THE MACHINE ON ITS BACK THEN USING A 5/16 NUT DRIVER REMOVE 4 SCREWS ON THE BOTTOM PANEL. REMOVE PANEL AND YOUR DRAIN MTR IN ASSESSIBLE. THE PART CAN BE ORDERED AT WWW.REPAIRCLINIC.COM
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
May 30, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
189 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
