Question about BenQ FP92G 19" Monitor
Brightness button malfunction
My brightness function on the monitor keeps popping up without being touched, and is automatically going up to 100% if it is any lower. Please help!
0 characters
1 Points
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
Apr 17, 2016 | Princeton Digital VL173 Monitor
Front panel switch malfunction
chek buttons if possible can remove buttons cable
Sep 01, 2012 | Samsung SyncMaster 740N 17" LCD Monitor
Brightness incresed to 100% automatically
It is aproblem with menu can clean these buttons from service centers.
Apr 30, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Contrest & brightness menu always pops up and
there is a problem in micro controller chip in the monitor replace that biggest chip in the monitor problem will be solved
Feb 28, 2010 | ViewSonic VP920b 19" LCD Monitor
Probably not only because I found several forums and the same claim as is my case .. initially function to adjust the brightness automatically .. 100% ... like I keep the button pressed continuously .....
Check out this link below for a PDF manual for your monitor. You can also update your drivers. There is a support here also. Just copy and paste into your browser.
Hope this helps. Let me know if I can help you with anything else.
Oct 04, 2009 | Samsung SyncMaster 720N Monitor
Brightness menu keeps popping up
This problem is usually caused due to a faulty microswitch in the brightness button. To rectify this, you'll have to change this switch.
Get your monitor serviced by a qualified service personnel.
Hope this solves your problem. For more help or clarifications, please reply. Thanks.
Aug 09, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Monitor will not turn off and keeps flashing the words Auto processing
it is not a bad rom. if it was a rom it would constantly act up but it only acts up upon overheating. The solution is difficult but if you open the monitor you can find all of the heatsinks take them of and replace them with bigger ones. or have a fan blowing on it at all time it is active i added bigger heatsinks to my emachine le1799 and it solved this problem of pulling up menu and changing setting by itself and the lack of the ability to turn power of.
Sep 15, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
BenQ FP92G 19" Monitor Logo
74 people viewed this question
Top BenQ Computer Monitors Experts
Matthew Spark
Matthew Spark
Are you a BenQ Computer Monitor Expert? Answer questions, earn points and help others
