I have a GE JVM141H microwave oven that I want to remove. I have the user's manual but not the installation manual. How do I remove it? There aren't any screws holding it from above or the sides.
Hello Allyman,
In order to uninstall your over the range microwave, you'll need the assistance of another person to hold and support it, while you remove the fasteners holding it in place.
If you open up the cabinet above the microwave, you should find two (2) large headed screws/bolts near the front edge of the cabinet. These are what hold the micro in place on the rear wall mounting plate. Unplug the cord from the outlet first, and clear out anything in the cabinet, so you can check to see if there are other screws holding the micro onto the cabinet.
While someone holds the microwave up, so it won't drop onto your range, remove those screws and once you have them out, the micro will be able to be pivoted down from the cabinet and then you'll be able to lift the back edge off the wall mounting bracket. When you do that, feed/pull the power cord out of the hole and you should be all set. Just remove the screws holding the wall mounting bracket onto the back wall and you're all set.
If you're not sure you can handle removing the micro easily, be sure to pull your range out of the way, so you can more easily stand under it and remove it without damaging the stove top, etc.
Here's the installation instructions that will help you locate all the fasteners you need to get at to remove the microwave.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=003675895.PDF
FYI, Here's an owners manual: http://genet.geappliances.com/DocSearch/pdf/49-8082.PDF
I hope you find this Very Helpful and best regards!
Testimonial: "You are 100% correct! It took a while to figure out. Thanks for your quick reply! "
GE isn't listing an installation manual for that old of a model. Checkout the closest one I could find that will give you a good idea of how it may be attached.
click below
Hope this Helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Testimonial: "Thanks. I truly appreciate your speedy reply! There were two long bolts running from the front of the unit all the way to the back mounting plate. "
Hi
Thanks for using FixYa. You can click on the link to download the user manual
for your Microwave:
Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
