Question about HP Compaq Presario V2000 Notebook
Usb ports don't work
On my laptop i had a virus and my usb ports stopped working. did a pc recovery and usb ports still don't work. i checked device manager and they are to be working properly. is there a solution?
  • 6 more comments
  • Anonymous Jan 15, 2008
    ok i will try. any other suggestions?
    it didn't work
    still not
    where is that located
  • Anonymous Jan 20, 2008
    its actually a hp pavillion dv6000. the problem still exists. Any help anyone? I can't get the usb ports to work at all.
  • IWUSkittles Apr 19, 2008
    I have the same problem with my Compaq Presario V2000. I tried all these tips and nothing worked. :( None of my USB ports work.
  • Anonymous May 11, 2010
    I took apart the laptop can I can not visually tell if one of the pins has been broken. When i plug in a usb light it does glow so the power connection is working is there any other way visually to tell what is wrong with the usb?
  • Anonymous Mar 28, 2014
    virus caused me ti clean install my laptop and some usb ports are not working
On both the compaq laptops owned by my daughters, one or more USB ports have gone dead. The fix has required dissassembly of the unit and really careful resoldering of the pins from the USB ports to the motherboard. It apparently takes very little torque on the USB connector to break the solder joints and as my daughters tend to use their laptops in a manners that stress the connectors ( on the couch or bed for example) the internal connectors just plain break. Cheap *****if you ask me.
Posted on Mar 10, 2008
    Genius:
  • 1,601 Answers
Reinstall your USB drivers:
Navigate to Device manager, find a branch named "USB Controllers" or similar
Right click the one thats the problem (or all of them if you dont know which), select Uninstall
Reboot your machine and windows will autodetect the USBs and reinstall their drivers.
Posted on Jan 15, 2008
  • 4 more comments
  • Thomas Christopher
    Thomas Christopher Jan 15, 2008
    that should work, if not let me know,
    thanks.
    Check the BIOS and see if they are enabled...
    when you start up your laptop. it will tell you what to press to run setup
    Disable power management on the USB hub
    To preserve power, Microsoft Window XP tries to disable USB when a device is not used. Under certain circumstances this function does not work and may cause USB devices to fail to respond when called. To resolve this issue, disable power management on the USB hub by doing the following:
    1. Click Start , and right-click My Computer .
    2. Click Properties , then click Hardware .
    3. Click Device Manager .
    4. Double-click the Universal Serial Bus Controllers branch to expand it.
    5. Right-click USB Root Hub , and then click Properties .
    6. Click Power Management .
    7. Deselect Allow the computer to turn off this device to save power .
    8. Repeat Steps 5 through 7 for each USB Root Hub.
    9. Click OK , and close Device Manager .
    Related support
    I am glad it worked for you. thanks for the update and rating!!
6ya staff
SOURCE:
Usb device doesn't work on my Laptop and anti-virus didn't scan on pc laptop automatically
Hey, for the USB device your port may not support the USB device itself due to one may be USB 2.0 and the port isn't. Make sure you check on all the USB port on your pc
Aug 09, 2013 | Microsoft Computers & Internet
I have an Acer Aspire 5253/BZ815 that is only 7 months old. 2 of 3 USB ports don't work, webcam stopped working and sound is going out. How do I get these things fixed?
From your description the motherboard is failing or windows device drivers are corrupted, if it is the device drivers you can attempt a system recovery from the hard drive or DVD disc which will reset everything back to factory default with a fresh install of windows. But if you find there is no change your manual should list aurthorized service centre's closest to you, or go online for customer and technical support.
Mar 03, 2012 | Computers & Internet
My USB Ports don't work. Is this just a plug and play to replace or do I need to purchase a new CPU.
is it only one or all usb ports that doesn't work. Check your device manager and see if the Usb device are still working or the computer is able to detect it. If it is, and is able to detect and display your Usb ports then they should be working alright. There has been a virus that been going on lately that cause the computer not to read device detected to the usb ports since I had this same promblem before and it wasn't a hardware issue, but a viral issue. Had to run the latest definition and then formated my laptop to factory default.
Jan 14, 2011 | Gateway GT5404 PC Desktop
Power light comes on but no accessories will work when plugged into USB ports
Steps:------
1.Plug in a different USB device in that USB port and check if it is working or not. If the 2nd device is working then the 1st USB device has gone bad. If none is working then try the steps mentioned below.
2.Unplug the powercable from the laptop and also unplug the battery. Press and hold the power button for 30-40 secs and then plug in the power cable and the battery and check.
3.click on START->right click on COMPUTER->click on MANAGE->click on DEVICE MANAGER->click on the symbol beside Universal Serial Bus Controller and uninstall all the USB ROOT HUB's and then restart the computer.
4.Run System Recovery from the Recovery Partion or Using the Recovery Disk.
Still if it remains then it is surely a hardware issue
Oct 19, 2010 | HEWLETT-PACKARD Compaq Presario CQ5302F...
My USB port dont work. Please help me
1. check if your drivers are ok.
2. reinstall all the usb drivers and devices.
3. some virus causes the system refuse the usb devices.
4. if comes to worse, you will need to reinstall your system using your recovery cds.
May 19, 2010 | Packard Bell Easy One Silver 2101 Notebook
HP Compaq Presario V6030 usb ports don't work, is this something I can fix with drivers or can they be replaced.
First try these steps
1.Remove all the usb devices connected, then go to device manager and under Universal Serial Bus controlers uninstall all the usb root hub and then restart the computer
2. If it still doesnt work do a bios update from hp.com for your notebook and then restart and do a bios default too.
3. If these steps doesnt resolve the problem do a recovery and even after recovery the NBs usb ports doesnt work then mother board needs to be replaced as the usb ports are fixed in it.
Apr 15, 2010 | HP Compaq Presario V6030US (EZ503UA) PC...
The usb port won't work on my acer extensa 4630z laptop
Did you install any Anti virus . Check the USB port for any physical damage. Try connecting a mouse with USB port to check if its working. After all this then the issue remain the same then the USB port needs an replacement.
Regards.
Feb 08, 2010 | Computers & Internet
All usb ports stoped working
.There are a lot of virus' that will disable your USB ports. You can change the settings in the registry to enable them again.
Open registry (START > RUN> type regedit) and navigate to the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet \Services\UsbStor
Now in the right pane, double-click Start and type 3 in the Value data box (Hexadecimal) and quite the registry editor.
Apr 17, 2009 | Computers & Internet
USB ports not working Acer Aspire laptop
Two solutions would be to either restore your pc to before the problem started,using system restore on accesories menu, or use the recovery cd or the recovery folder Acer laptops usually have on the 'D' drive and re-install usb controllers and drivers.
Nov 24, 2006 | Acer Aspire 3000 Notebook
HP Compaq Presario V2000 Notebook Logo
1,961 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
