Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
Maytag Neptune MAH4000AWW
My neptune wont lock and it fills but wont wash or spin just rince is this my interlock on my door
  • 3 more comments
  • SHABBYROBB Jan 15, 2008
    it spins one rotation then pauses till it gets to the rinse cycle
  • mcintoshjr Feb 27, 2008
    Just no spin here and the water stands at the bottom , slightly visable, I would like to know if the timer fix worked?
    How can I troubleshoot the board?
    mine is a MAH 4000 AWW as well
  • dboatz Aug 25, 2008
    My washer will not spin because the door locking mechanism quit working. How do I fix that?
  • flukeman Aug 27, 2008
    I set it to regular wash. Washer fill with water and that's it. No door lock light either.
  • Anonymous Mar 16, 2014
    light flashes and finishes but wont wash or spin
    Genius:
  • 1,003 Answers
I SAY REPLACE TIMER (POWER CONTROL BOARD)
Posted on Jan 24, 2008
Door won't lock
If the interlock isn't working it may not allow the machine to start. If you can open the door when it should be locked it's probably a faulty interlock.......Nomess
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
No spin
If anyhow the drain pump is blocked the spinning will be blocked. Check for a forrign object in the drain pump. If you can feel/hear it buzz (very quietly) while it should be pumping out it might be jammed up with something. That however is kind of rare with the angled tub the Neptune uses.
Are you sure the machine is actually not pumping out, or is it possible its just turning off in the rinses?
Reason I'm asking is the control will shut the machine down if its taking too long to fill up. Many times it will fill fine for the wash fill, but because the rinse takes twice the ammount of water it activates the system and shuts down while its half way filled. Look for a slow cold water fill for that problem.
Is the door locking in the spin? One very common problem on the older 3000 and 4000 series machines is the R11 resistor on the machine control board bruning out leaving the door lock inoperative. If the door won't lock, it won't spin. I do believe, however, the machine will still pump out. But many times what happens is the pump removes all the standing water, but without spinning everything in the tub stays soaked. The saturated clothing drains the water out and then leaves a few inches in the bottom of the tub.
If you have the newer style Neptune (with the control panel on the front of the machine) only the top paragraph applies.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Neptune washer front load may4000awq
Check your washer belt has not slipped off.
Just so you know thats not the problem.. Ours went ga ga and it was only the belt!
:o)
Aug 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing machine door wont open
well, Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Jul 19, 2008 | Washing Machines
My Hotpoint Aqaurius WD62 is filling but wont drain or spin
try replacing the interlock first then check the the continuity in the interlock lead
Mar 06, 2008 | Hotpoint Aquarius WD63 Front Load...
Maytag door wont lock and go into spin cycle
You will need to replace the door interlocking device.
Oct 26, 2007 | Maytag MAH6500 Neptune Front Loading...
Washer stopped midcyle-error code do, then FL
The door interlock could be faulty. The only way to open the door if the door interlock is faulty is to remove the top of the machine, after turning it off at the wall and pulling the plug out of the socket, and locate the door interlock from the inside. There should be a metal "slide" which can moved back to release the door catch. The interlock could be warped from getting hot, which will make the slide almost impossible to move. Remove screws holding the interlock from the front panel and from the inside pry the interlock from the catch. Replace interlock.
Oct 21, 2007 | Maytag Neptune MAH5500B Front Load Washer
2000 neptune stack
the micro switch which is part of the door interlock may be at fault, & need replacing. Or a wire may be broken/burned off
 in the interlock. Or it may just be stiff, try spraying it with WD40 (not whilst the power is on!!)
Oct 19, 2007 | Neptune MLG2000A Front Load Stacked Washer...
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
444 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
