Question about ASUS A8N32-SLI Deluxe Motherboard
Windows won't start
During the process of adding another hard drive I disconnected the sata cable from my main hard drive and forgot to hook it back up before rebooting. After realizing my moronic blunder, I shut the power off, hooked the cable back-up and rebooted. Now windows dosn't start. The "PCI device listing..." screen just hangs there with the flashing cursor at the bottom. Unplugging the the new drive dosn't help.
The hard drive is recognised in the set-up sceen e.g. first sata master disk.
  • brian c
    brian c May 11, 2010
    Is the new drive also a SATA?
  • 53 Answers
Hi Moons,
First you will need to boot up. When you do this you need to go into bios and then go to boot and disable the hard drive floppy and any other drivers. You must make sure you keep the cd driver as 'able', save setting and exit out of bios. This will let you reboot. After it`s done, the partition in the computer will reboot the computer. Make sure to go back into bios and able the hard drive, floppy etc...
I had the same problem, and solved it this way.
Posted on Jan 15, 2008
Try your jumper settings on the new drive. Should be set to "slave".
Also your bios settings, make sure your booting the right drive first..
Hope this helps.
http://datasip.net
mimi...
Pavillion P6000 won't recognize any drives
If you are trying to install Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jun 15, 2012 | HP Computers & Internet
Dear sir i'm unable to install xp on my compaq presari cq57. setup don't detect hard disk.. i'm facing blue screen error please help me..
hello,
  • Turn off the laptop.
  • Unplug from power if connected
  • Disconnect the hard disk power supply and re-connect after a while.
  • Now start the PC and run set up.
thanks!
Sep 24, 2011 | Computers & Internet
How do you connect two hard drives to a computer?
1. For SATA, you just need a second SATA cable to plug it in and a power cable from the power supply.
2. For IDE, you will need a second IDE cable to plug the second hard drive, AND you will have to set both hard drives jumpers either to cable select or one Master and the other one Slave, based on which one you have the operating system.
Nov 12, 2010 | Maxtor Hard Drive
Forgot password
During the boot up process you will see on the screen press delete to enter set up
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there
hope this helps
Oct 06, 2010 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
Remove vista and install XP on HCL laptop
Your laptop probably has SATA hard disk installed in it. You will need to install from an XP SP2 or later CD for native SATA support. Otherwise you will need to get the SATA drivers for the chipset being used on the laptop and slipstream them onto a new bootable CD or go through the process of adding the drivers manually during the initial phase of the installation.
Apr 07, 2009 | Microsoft Windows XP Professional With...
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
Installing a new harddrive
Uses a SATA cable. If you're using an IDE harddrive that uses a 40 pin connector, there are IDE to SATA adaptors available.
The power connector is also different on SATA Harddrives.
Jun 18, 2008 | Dell Dimension XPS 400 PC Desktop
Bad SATA data cable connector or drive?
Hi miss, is you're new SATA being seen in you're bios?
To check this. At boot up press the Delete key every two seconds until the bios main menu loads.
You should see the new SATA listed here. If you do not see you're new drive listed than shut down the PC & unplug the power cord. Remove the data cable & clean it with a cotton swab & some house hold alcohol. (no dripping). Wipe off both ends of
the data cable & the drive's connector. ( Allow time to dry).
Re-connect every thing & again check you're bios. If you're drive is listed than you can use you're current windows to format the drive. I gather you're current windows is running correctly.
If you get a error message from windows during format, do not worry, yet!
I suggest you download the drive's Mfg's software tools & use this to test & setup the SATA drive. Locate the white sticker on the new SATA drive. There you'll find the model number & serial number. Write the drives information down on paprer for later. You can register you're SATA drive later at the Mfg's site.
Most Mfg's have bootable software for a floppy disk & the same to creat a bootable CD-ROM disk so you can setup & test you're new drive which is what I am suggesting you do. You will need to disconnect you're other SATA drives while using the bootable software. (Just unplug their data cable). No need to unplug the power to the drive - (s).
I am sure you will be able to setup and test you're new drive. Once finished, reconnect everything. Double check everything before closing up the case. Boot you're system. Windows should see you're new drive.
Good Luck!
If I can be of more service, just ask.
Mike
Apr 15, 2008 | ASUS A8N-SLI Motherboard
How to format SATA drive
Hi, the setting will be in the BIOS menu. switch on and hit F2 or whatever it is for your motherboard (it should say on screen). then go to the HDD settings and enable SATA
Feb 20, 2008 | ASUS P4V8X-X Motherboard
ASUS A8N32-SLI Deluxe Motherboard Logo
61 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
