Question about Aerocool CoolView ATX Mid-Tower Case
Connecting Power Button
Hi, I'm trying to connect the exterior power button to my motherboard so I can actually switch the unit on, however I do not know where the long cuboid connectors that go from the power button connect to on the motherboard.
Any ideas or if anyone has a cable map that would be great.
  • 207 Answers
How to wire front panal
You will need to open the computer case and check that the cables that run from the actual power button to the motherboard are plugged into the proper spot on the motherboard. Sometimes reseating the cable can fix this issue.
I think this is the link to your motherboard documentation:
Check the page 2-14 or 2-15 and see if that helps you to identify the actual connection for your power switch.
Nov 14, 2011 | VIA P4MA Pro Motherboard
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
There is no power switch on the enhance atx 1123b that I have . What actually powers it up?
Just about every power supply I've owned doesn't have a power switch. The power supply is turned on by one of the wires in the 24 pin connector. According to this it looks to be pin 16 and how to turn it on:
"Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF."
Hope this helps
Mar 01, 2011 | Enhance Technology ATX-1123B, Enhance...
Pc will not come on no power , have checked power outlet, as well as power cable, to no avail ...........still will not come on
Have you checked the toggle switch on the back of the power supply? Make sure it is turned to the correct voltage (110 in the US). Still no power? Check the connection on the motherboard. Make sure the power supply lead from the front panel switch to the motherboard is connected. Then check all power connections to the motherboard. Secure or correct as needed. (follow the motherboard manual's diagram as to where each lead should go)
Jan 01, 2010 | E-Machines eMachines Desktop PC
Not powering on at all - I have been built a new computer from scratch with all brand new components. After hooking all of them up and plugging in the power source. Nothing is happening when the power...
1. Could be as simple as not having the Power Switch on the right jumper...double check.
2. The board will power up with nothing hooked to it... just power, CPU, MEM... disconect everything to just to get the board up to the bios.
3. Make sure PS is securly connected to the MB.
4. Check Jumper on the Board to make sure the Test Jumpers are not set
5. Memory is seated correctly... if you pull them out the board will start and beep...
Dec 31, 2009 | Gigabyte GA-G41M-ES2L Motherboard
I'm connecting everything but the motherboard does want to start
Some power-supplies have a rocker-switch, with a '|' and an 'O' icon, which acts as a "master" power-switch. Be sure that you have pushed down on the '|' side of the rocker. As you do so, look at the motherboard -- it may have a small green lamp on it, to indicate that the motherboard is receiving power from the power-supply. Also, look at the fans -- they may slightly "rock" (twist back and forth) for a moment as you move the switch.
Most of the connections to the front-panel can be ignored while "trouble-shooting" your problem. As long as the two "power" pins on the motherboard are connected to the "power" button on the front panel, pressing the "power" button should work as expected.
Oct 26, 2009 | Asrock AM2NF6G-VSTA Motherboard
P4sd socket 478 motherboard is not booting up at all !!!
1st check if the voltage from the plug has correct groung , neutral phase set .then
try a new smps , with minimum 400W output.
before connecting the same.
please remove all the parts out of the cabinet please connect only motherboard and smps and check its getting switched on , if not then your board is burnt you will have to replace it , if there is power indication then connect the RAM and check , if its also fine then connect the rest and try.
all this u have tried and no use , please post me a msg with full detail of your PC configuration , I can try a resolution
Aug 02, 2009 | HP Asus Motherboard P4SD-LA Socket 478...
Mobo power
There are jumpers on the motherboard,
check all jumpers are set correctly, as from the user manual, this could be a problem.
check all your front lights are wired properly
power button, reset switch, must be correct too.
double/treble check them before building it.
Apr 20, 2009 | Asrock 845GV (P4I45GV) Motherboard
Power switch notworking ( ASUS P4PE-X Motherboard)
Please refer your motherboard manual and fix the front panel cable including power button. After this if power button is not working than swap the power button cable and reset button cable.
And then start your PC by pressing the reset button.
Else you just recheck all the cable + RAM + CPU.
Mar 09, 2009 | ASUS P4PE-X Motherboard
Aerocool CoolView ATX Mid-Tower Case Logo
150 people viewed this question
Top Aerocool Computers & Internet Experts
David Payne
David Payne
Are you an Aerocool Computer and Internet Expert? Answer questions, earn points and help others
