Question about JVC AV-48WP30 48" Rear Projection Television
Vertical color lines
My av48wp30 only shows vertical colored lines across the entire screen,still has sound. does anyone know if this is going to be an expencive fix?
  • 1 more comment
  • lsmithwyo Mar 28, 2008
    My sons TV is doing the same thing. Vertical lines and a picture behind it.
  • CIRRUS17 May 04, 2008
  • Carl Manaloto
    Carl Manaloto May 11, 2010
    Take a picture of it via digital camera or cell phone with camera and then post it on this site. I will get a better understanding of where your problem is.
My father's TV is doing the same thing, however the picture is still working. You can see the picture but there are vertical green/red lines going through the entire screen. I tried an alternate source (DVD) instead of the digital cable box and go the same thing. Can anyone help???
Posted on Feb 25, 2008
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.vertical color lines - 4d2ca33.jpg
Posted on Feb 11, 2008
What part is needed to fix colored vertical lines across entire screen of Samsung tv
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 06, 2016 | Samsung UN60ES8000 60" 1080p LED 3D TV...
I have multi colored vertical lines across the entire screen. The menu screen is perfectly legible when selected on the remote and will go on and off like it is suppose to.
If this tv vertical colors lines problems happen by itself,tv problems not causes by u or an object by hitting forces to the tv LCD screen panel itself.The tv board that call the T-CON board it is dead,this board sit in the bottom in the middle of the LCD screen panel.Must be replaced the T-CON board to solve tv vertical colored vertical lines.Tries websites like, to buy a whole new refurbish T-CON board for the replacement.If causing by u or an object by hitting forces it to the LCD screen panel itself.The tv not worth a whole tv anymore,because by replacing the tv LCD screen panel will cost the same as a new tv.
Jul 28, 2011 | JVC LT37XM48 LCD TV
Vertical Line started on left side of HDTV, and now
This problem is down to the actual LCD or plasma screen, if this shows as the screen warms up and stays on then the screen will need to be replaced, you should go back to your retailer (not manufacturer) and report this problem, depending on the store and how long you have had the tv, the tv can be replaced for a like for like tv at store as this is not a cheap standard repair.
Sep 13, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
I have a horizontal color line across the screen...have sound .This is on Video 1
If you are comfortable working inside the set and can solder, try resoldering both the vertical IC and the input jack connections. The vertical IC will be a small flat IC attached to a heatsink with about 9-11 pins. It will be marked LA7837 or something similar.
Let me know the results.
Apr 15, 2009 | Televison & Video
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
are the colored lines all the way across the screen? with no video even menu does not show up i would say you have a bad panel take it back to the store
Oct 22, 2007 | Samsung LN-T4671F 46 in. LCD Television
Verticle lines following the color spectrum across the screen.
Had Sony KDF-E50A10 that had the same line problems after 16 months. Was fine at lunch time and when got home from work and turned it on, they were the lines. Want over $800 to fix it. Told me it was the B-Board assembly. Sony was no help. They have exteneded the warrenty on another part that works along with the B-Board but not just the B-Board itself, so probably not any more Sonys. I'm going with LCD now.
Oct 03, 2007 | Sony KDF-E50A10 50 in. LCD HDTV
JVC AV-48WP30 48" Rear Projection Television Logo
666 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
