my acer 5630 touch pad has almost stoped working, the cursor works but when you tap it to highlight or click on something it won't do anything, any suggestions please!my acer 5630 touch pad has almost stoped working, the cursor works but when you tap it to highlight or click on something it won't do anything, any suggestions please!
You can't post conmments that contain an email address.
go to control panel, mouse &pointing devices check advavced settings if all are ok go to system, hardware, device manager,mice & other pointing devices check that there no conflicts click on troubleshoot if you still have a problem buy a corded or cordless mouse that will connect to usb
Sounds like the touch pad is not working anymore. try using a USB mouse and see if that works. also, see if you can reinstall the touch pad software to fix that.
You need a pc tech to reattach the cables to the motherboard inside the unit. they have worked loose and are not going to work until serviced or replaced.
try installing the touch pad driver from www.acer.comnormally it is synaptics touch pad which acer use just re install the driver and everything will be ok pls vote me if it woks , or if u want anthing else lemme know
