Question about Sony Network Walkman NW-A3000 MP3 Player
Error code: 82040008
My NW-A3000 has no music even when the computer says it does
  • claire2003 Jan 16, 2008
    I have the same problem as this. Ive had my mp3 for about a year and its not had any major drops or anything that i would say 'broke' it.
    Suddenly when i next tried plugging it in it can up with the error code 82040008 and then when i tried the player the next day it said that there was no compatable data and i would need to connect it to compliant software.
    Ive tried plugging it back into the computer several times and the code comes back up again. I have also tried resterting the device which has madde no difference.
    I would rather not have to restart the whole thing because i have only just dont this and now i have 1000 songs on there and it would be a nightmare trying to find them all again because they are no longer on my computer.
    Any suggestions would be helpful!
    Thanks
Found a solution, I have the NW-A3000 also and have just had this problem.
solution do not use the connect player software, connect the player to your pc and open up as a removable disk, eg my computer/removable disk (f:). then drag and drop everything you see into a folder on your desk top, call it back up or some thing.
when you have done this enitialise the walkman disk in its own menu not using the connect software.
when it is done connect the player back up and drag the contents of your backup folder back to the player it may take a bit of time depending on how much music you have on it, make sure all the files are coppied back accross.
when it is done you should be able to use the player as normal again and update the files using the connect player software.
thanks.
Posted on May 04, 2008
  1. my mp4player
Posted on Feb 02, 2008
I plug NWA3000 into the computer to change music,
Try resetting the device it?s usually a small pinhole on the back or side of the device try holding that in for about 10 seconds or Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings. then us: If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Oct 24, 2009 | Sony Network Walkman NW-A3000 MP3 Player
Getting stuck on the initial, splash, load up screen
have u charged the batteries fully and try, evenif the problem persists go for a battery replacement.
Jun 03, 2009 | Sony Network Walkman NW-A3000 MP3 Player
Sony walkman NW A3000 20GB
i've posted a solution here.
It was posted for another model, but i think it also works for your walkman
May 23, 2008 | Sony Network Walkman NW-A3000 MP3 Player
A3000 is still locked on the connection screen.
Pressing the reset button will not scrub your a3000 memory.
I have just tried it on mine to make sure I dont give you wrong info.
It just switches it off.
Dec 03, 2007 | Sony Network Walkman NW-A3000 MP3 Player
Erasing music
if u want to completely clear your mp3, there is in the lower a botton which sayes "RESET".. its near the charginf inpout.. press that and everything in the mp3 should be cleared
wish i helped
stratos
Nov 18, 2007 | Sony Network Walkman NW-A3000 MP3 Player
When i plug in usb cable for my a3000 player, the error code 82040008 appears,saying that a3000 canĀ“t work
All I can suggest is that you go to the sony website and first go to the download page for sonicstage cp. There is a link to update your firmware to 3.0. After doing that, if you arent already using it, download sonicstage cp from there and use that instead of connect or old sonicstage. That will probably sort you out.
Oct 09, 2006 | Sony Network Walkman NW-A3000 MP3 Player
Sony NW A3000 Walkman
Follow these steps- - Open the Sony Walkman from "My Computer". - Open the folder inside, then delete all the "DAT" files. - Open the second foler which is inside the first foler and delete all these files. - Close that and then open up "SonicStage" - Now delete all the files from your library, but, DO NOT delete them from your computer. - Now import all the songs again and it should pick up the device and start to transfer with no problems. I have done this with my Sony Walkman and it now works. If you experiance more problems contact me at mckinley2006@hotmail.co.uk
Sep 04, 2006 | Sony Network Walkman NW-A3000 MP3 Player
Error code 82040008
Ive searched but can't find anything on your error code. It seems Sony made a real lemon with this unit and made many thousands of people very unhappy. Most of the trouble seems to originate with the lousy software. The latest downloads can be found at http://www.sonydigital-link.com/DNA/WM/NWH/NWH.asp?l=en Personally if I owned it and had the chance I'd be going for a more reliable unit. Check out this site for unhappy customers. http://www.kanai.net/weblog/archive/2006/01/24/08h35m18s BMW
Jul 24, 2006 | Sony Network Walkman NW-A3000 MP3 Player
Sony Network Walkman NW-A3000 MP3 Player Logo
122 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
