Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Frigidaire SBS MDL FRS26FCDB6 Some time ago, 3 months, we raised the ice maker lever to the Horiz or up position as we did not want any more ice til we corrected our smelly water problem. Anyway, today, i cut the supply tube and attached a water filter to one end and then i lowered the ice maker arm and waited for water to flow thru the filter, and WAITED WAITED. ? please, no water is running thru the tube or filter. Can you help THANK YOU
  • ladyralph Jan 16, 2008
    Thank you your help was VERY timely and accurate. Thanks again
    President:
  • 1,314 Answers
Reach into the ice maker hook the ejector blades with a finger and pull them up a little you will hear a ratchet sound then watch them go around and listen for the fill valve before they stop let me know what happens
Posted on Jan 15, 2008
  • robert samples Jan 16, 2008
    thanks for the rating but there may be another problem if it acts up again start a new thread and ill tell you how to fix it if it stops again push on the wire arm all the way down even though it may look like its down just touch it if it starts working again then start your thread this is for tech 17 im not sure you have a problem because you shut the unit off manually ill be watching ok
WHY DOES ICE MAKER NOT HAVE WATER, BUT WATER DISPENSER HAS WATER?
Good Morning Friend, thank you for your post!
From what you have described it sounds like your ice maker is not making ice but your dispenser is dispensing water. If your ice maker has stopped producing ice completely, here are a few simple troubleshooting tips that may help you resolve your issue:
    1.It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
    2.Also make sure that the temperature is 8 degrees Fahrenheit or lower. If your freezer is too warm, the ice maker won't cycle properly.
    3.When was the last time the filter was changed? Most filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency.
    4. The ice maker fill tube may be blocked with ice or have a clogged water filter. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
    5.Also the water shut-off valve or water-inlet valve, or both, may need replacing if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, then more than likely it will need to be replaced.
    Hope this helps! - Z
Aug 29, 2014 | Frigidaire Refrigerators
Not making ice
Hello locket_mba, I am happy to assist you!
If your ice maker has stopped producing ice completely, here are a few simple troubleshooting tips that may help resolve your issue:
·It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
·Make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
·When was the last time the filter was changed? Water filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency.
·The ice maker fill tube may be blocked with ice or have a clogged water filter. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
·The water shut-off valve or water-inlet valve, or both, may need replacing. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Hope this helps!
Jan 29, 2014 | Frigidaire Refrigerators
Ffhs2611lw doesnt create ice
Good Morning Tom, thank you for allowing me to assist you!
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
  • Make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • When was the last time the filter was changed? Water filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency.
  • The ice maker fill tube may be blocked with ice or have a clogged water filter. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
  • The water shut-off valve or water-inlet valve, or both, may need replacing. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Hope this proves helpful!
Jan 24, 2014 | Frigidaire / FFHS2611LW
FRS20WNFWQ ice maker not working, is getting water
Hello - If your ice maker has stopped producing ice completely, try checking the following:
· It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
· Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
· When was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. The ice maker fill tube may be blocked with ice or have a clogged water filter. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
· Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Should these suggestions prove to be ineffective, contact a professional to move forward accurately.
Nov 23, 2012 | Frigidaire FRS3R5EMB Side by Side...
Ice maker not working
Hello anjcarr - If your ice maker has stopped producing ice completely, you can try checking the following:
If any proves to be ineffective, contact a professional to move forward accurately.
Nov 20, 2012 | Frigidaire Refrigerators
Frigidaire side by side water line clog
Hi -I understand that your unit is still not producing any ice or dispensing water. Some of the following steps you have already confirmed. I suggest confirmed the steps below and see if any is helpful :
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. When was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. The ice maker fill tube may be blocked with ice or have a clogged water filter. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Oct 10, 2012 | Refrigerators
Oct 08, 2012 | Frigidaire FRS23W3A Side by Side...
Frigidaire french door refrigerator not making ice
Hello jcwilson2929 - If your ice maker has stopped producing ice completely, you can check the following:
Sep 26, 2012 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
Ice maker will not dipense ice
Hello, Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If these wire is in the raised position, the ice maker is turn off.On some unit you simply lowered the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in proper position, check the freezer temperature, it should be between 0-8 degrees Fahrenheit.If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seal and thermostat, repair/replace as necessary.
Thanks
Jun 21, 2010 | Frigidaire FRS3R5EMB Side by Side...
Ice maker stopped making ice. Repairman replaced water valve yesterday-said bin would fill overnight-still no ice cant get repairman on phone Frigidaire FRS26znhD2
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Mar 27, 2010 | Frigidaire FRS266ZDSB Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
157 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
