Question about Gateway FPD2275W LCD Monitor
ViewSonic Monitor A75S
Hi!
My ViewSonic monitor now displays the screen image as if "tilted" back over the top half of the screen. If I hit the top of the monitor gently, sometimes it recovers. Also, this problem seems to go away once the monitor is in use for a while. This monitor is almost seven years old and has not been mistreated --- except when I hit it now!
Any help is appreciated, especially if I can fix it myself.
Thank you!
Karen
    Scholar:
  • 198 Answers
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
How do I adjust the screen tilt and height? HELP!!!!!!
Hi, Here is what I was able to find out about your monitor from ViewSonic. There is no manual available on their website.
I have two ViewSonic monitors that are very similar to the one you have.
Here is what I can tell you. The monitor, although it does not seem like it can, be tilted front to back.
If you grip the monitor screen on the side edges (left and right) and 1/3rd the way up and twist it either away or toward you, it should tilt. It is a little stiff, just go ahead and tilt it. As far as adjusting the high. That, I'm sorry to say cannot be done.
I hope this helps you.
Best Regards,
Mark
Feb 15, 2011 | ViewSonic VA1912wb 19" LCD Monitor
Screen jumps back to prior screen
If you mean to say that the computer-generated displayed image on your screen changes, it's a function of the computer, not the monitor. If you mean to say that some monitor-generated displayed image is appearing (such as a setup/configuration menu or a splash screen), please tell us more so we can diagnose further.
Sep 12, 2009 | ViewSonic VP201b 20.1" LCD Monitor
Bottom half of monitor displays top half of desktop
You could try a different resolution for the monitor.It's possible the monitor cant support the resolution your trying to display your desktop at.
Jun 01, 2009 | ViewSonic GS773 (White) 17" CRT Monitor
ViewSonic VA912 half screen dead after 30 minutes
first i confirmed that the problem was in lcd.then i predicted that some display chip on the motherboard are getting heat.due to which the display was performing irregular then i switch on A/C of my room.and the temperature was cool. and the monitor was working fine.
Apr 29, 2009 | IBM E54 (Pearl, White) 15 in.CRT...
Our viewsonic monitor tilts forward. how do we tilt it back?
Hello again.
The ViewSonic VG1930wm has a height adjustment range of 3.2", TILT capabilities, and a swivel range of 360 degrees.
So yes your monitor should be able to tilt back and forth.  Most likely if you hold the base of the monitor, and press somewhere on the front at the top or bottom (do not press on the screen itself) then it should easily tilt back and forth.  Occassionally there is a switch you may have to hold while you push on the front-top/bottom of the monitor which acts as a lock for the tilt angle.
Hope that helps, and don't forget to vote/rate!
Height adjustment range 3.2", tilt, swivel range 360º
Mar 12, 2009 | ViewSonic VG1930WM LCD Monitor
Half monitor display and other half will be some different color.
Click -Start then Ctrl Panel - then Display - then Settings...
make sure you have 1280 x 800 (32 bit) .
or just hit the default tab .
Jan 15, 2009 | ViewSonic VA1703wb Monitor
ViewSonic va903b problem
Hi...there,
Well, it's seems you got a busted backlight inverter. If you still under warranty send it back for replacement of a new inverter.
Happy Holidays!
Dec 15, 2008 | ViewSonic VA903B Monitor
Monitor display image
press control+alt+down(arrow key)
May 14, 2008 | AOC A15X221 15 in. LCD Television
Wide screen problems
I guess the video board or logic board is having problem.
Apr 24, 2008 | ViewSonic VX1935wm LCD Monitor
Gateway FPD2275W LCD Monitor Logo
114 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
