Question about Sony Cyber-Shot DSC-S500 Digital Camera
Battery door broken
Anyone know where i can find replacement parts? Specifically the battery door.
  • 6 more comments
  • gpacanada Jan 19, 2008
    same problem here. it happend when i chnged the batteries and shut the door. I must have put too much pressure and small piece of plastic broke off. Where can i find a replacement door without having to pay too much.
  • Anonymous Jan 26, 2008
    how do you replace the door?
  • ShellSort Jan 30, 2008
    It was a little rough but i just used a little flat head screw driver to work the old door off. The new on just slid on real easy.
  • ShellSort Feb 08, 2008
    Thank you for contacting Sony's Direct Accessories and Parts Center (DAPC USA).
    Model: DSCS500
    Your question was: I am seeking a replacement for the battery door. Where can I purchase it. Please advise.
    The items you requested are listed below.
    Item - ( LID, BATTERY CASE ), 269948301, $4.99 ea.
    You may place your order using the link below or call 1-800-488-7669.
    Shipping charges and local taxes will be added to your order at checkout.
    Sony Direct Accessories & Parts Center web site - http://servicesales.sel.sony.com/ecom/ac...
  • ShellSort Feb 11, 2008
    The battery door removal seems harder than it is. If you look at the new door you will see in the middle there is a locking tab. You have to keep that piece in mind when removing the old one. I used a very small flat head to pry the plastic part of the old door away from the metal part. Take care to preserve the metal part. After bending and breaking the old plastic piece a bit it eventually popped off. The old plastic door will be mangled but it is useless anyway. The new door slides on to the metal piece and locks into place. It requires a bit of force to remove the old door. I was so worried because I was sure I was going to do more damage but the plastic piece gives long before the metal if you go slow but firm. I hope this helps.
  • hollieneweso Nov 23, 2008
    where can i find this on the sony site
  • Anonymous Jan 05, 2009
    Hi There,
    I have the same problem. Can you send me a link to wear I can purchase a new battery door for my sony cyber-shot DSC-S500? Thanks
  • Patty Elliott Mar 14, 2009
    I have the same problem. Purchase a new battery door for my sony cyber-shot DSC-S500? Cost 4.99 for part & 3.00 for shipping. http://servicesales.sel.sony.com/ecom/ac...( LID, BATTERY CASE ), 269948301, $4.99 ea.
    Replacing battery door, see the small hole in the middle betwen the negative and positive sign. Insert a small screwdriver place under the gold strip and pry up to release the lock and slide it off.
You're making it harder than it has to be. Simply hold the camera in your left hand, and open the battery door so it is standing up. Look closely at the lower left corner of the batterry door. Notice the notch shape. The door plastic door is locked in place by the mating little "L" shape on the hinged door of your camera. Thats all that keeps it from sliding off when you put in batteries. Simply insert a small screwdriver or knife blade in that slot, twist it counterclockwise to push the battery door lock to the left, and slide the door off with no force at all. It's a snap.
Posted on Feb 15, 2008
I just bought the battery door replacement part from the Sony parts website listed in the 1stposting above (http://www.sony.com/accessories or 800-488-7669). Order part number 269948301 for the battery door. They didn't charge all of the shipping listed on the website because it's such a smallpart. It ended up being $7.74 total, including shipping. Nice surprise!
As for replacing the part, I had success with first using a plastic strip cut out ofa shopper club card to disengage the center snap (see coke bottleposting & pic above). While that was in, I had to push out the little plastic piece witha small screwdriver in order to be able to slide off the door (seepic below).
Posted on Nov 29, 2008
Folks,
Just a note - that if you call Sony Replacement Parts you will be quoted a different part# that costs $33+. I hung up on them and ordered the part listed above, which was indeed $4.99, and it worked perfectly.
RONTOONS was perfectly correct in replacement directions.
Solution #4 is a perfect picture of the process.
Posted on Jan 23, 2009
I took a plastic coke bottle and cut a piece about half inch wide and 4 inches long. i wiggled it between the metal and the plastic door. you have to close the door a little to disengauge the lock mechanism. it slides right off after. no broken pieces and no aggravation. Battery door broken - 8245360.jpg
Posted on May 07, 2008
This guy was absolutely correct with the source, price, and replacement instructions:
Mar 14, 2009 - I have the same problem. Purchase a new battery door for my sony cyber-shot DSC-S500? Cost 4.99 for part & 3.00 for shipping.http://servicesales.sel.sony.com/ecom/accessories/web/index.jsp( LID, BATTERY CASE ), 269948301, $4.99 ea.
- elliottjp
Posted on Feb 27, 2010
I dropped the camera on a tough floor right where battery door is at. The hard plastic base (runs around the corners) that supports holding the door are all broken into small pieces. So for a new door there is no support. The lid thing totally came off of the camera right when it broke. Is there a solution for this? I have metals, and small rod with its grooves with detoriated plastics.
Posted on Feb 11, 2010
Yes, solution # 9 was the easiest method i did. Just poke and use your finger. Thanks a lot Mexican Dude.. That was really easy...
miss V from Rockville, MD
Posted on Dec 22, 2009
Hi, all the methods above did not work except one. Use a small screw driver and poke it in the small hole between the positive and the negative terminals. This will release the snap fit. Then the door should slide through. Please donot try putting in plastic pieces in between the metal and the door. its a waste of time
Posted on Dec 17, 2009
  • robert angelora Oct 02, 2012
    N.Y. ****** Rob
    ramyacusat is definately RIGHT. Use the screw driver method. Easy to R&R door!
Thanks guys, the Coke strip worked with a wiggle and without the screwdriver. Walter {UK}
Posted on Feb 15, 2009
Hey, removing the old door is as simple as learning to speak spanish!! here is how a got it away......do you see the small hole in the middle ? is right betwen the negative and positive sign. insert a small screwdriver and push...at the very same moment use one finger nail to pull the small plastic lock, at the right inferior corner of the lid, it will come off right away. no force needed or else.
good look. from: one Mexican Dude, from Hermosillo.
Posted on Jul 06, 2008
I had the same problem as everyone else. There are several sellers on ebay. Pick one. Mine was $9.95 including shipping. A lot cheaper than the $175 the local camera store was gonna charge to fix this. The key is to follow previous info left to remove the old door. Once you have that done the new door just slides right on the metal piece that was left after removal of the old door.
Posted on Feb 22, 2008
Any instructions on how to remove/replace the battery door?
Posted on Feb 10, 2008
Mine is also broken, this is a brutally bad design and Sony should be standing behind this with a better fix than another door with less then a half a square millimeter of thin plastic holding the door shut against the batteries which are spring loaded to push against it.
Does anyone have appropriate contacts at Sony to discuss the options for getting a replacement CAMERA for this model??
Posted on Feb 08, 2008
Go to sony.com and i only paid $4 for the door and the total including shipping was about $10... no i'm trying to find out how to get the old one off so i can get this one on!
Posted on Jan 30, 2008
Went on www.camcor.com site and typed in item# 137990017 and nothing came up???
AA
Posted on Jan 22, 2008
This would be item # 137990017 - www.camcor.com - Sony battery door/cover f/DSCS500
Battery door latch broken
look for a Canon eos 300D battery door (they are the same camera just came out in different countries) or buy of ebay a cheap broken 300D and salvage the parts that way.
Mar 21, 2013 | Canon Eos Digital Rebel Ds6041 6.3 Mp...
My batterry door is broken I don't know how to put
KODAK doesn't sell battery doors for any of their models.
A repair for this fault is 24,47 pounds + shipping to the repair centre.
If you already have the battery door; I suggest you will have a local camera TECH to attach the door to the unit.
Dec 14, 2009 | Kodak EasyShare C315 Digital Camera
Battery door on minolta dimage Z2 is broken
Part number is 2724-0207-01. Search in google.
Thanks
Aug 17, 2009 | Konica Minolta DiMAGE Z2 Digital Camera
Battery door latch broke off body of Canan A590
The same thing happened to me this week. I called Canon Canada directly and asked to order the part (The battery compartment door). They gave me a phone number to call and I was able to order the replacement door for about $8.00 + $10-$12 shipping. Hope this helps!
Jul 10, 2009 | Canon PowerShot A590 IS Digital Camera
Maxxum 5 broken battery door
I use US Camera on the internet.  They have a huge inventory of parts and work pretty well with the do-it-yourselfer. For the Maxxum 5: www.uscamera.com/1min003.htm
Greg Portland, OR
Jun 03, 2009 | Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
Battery Door Broken
So far, I was able to find a camera like mine on Ebay that was being sold cheap for parts only, because the LCD was broken. I figure that this amounts to probably what I'd be paying if Kodak offered to sell me a replacement battery door (which they do not). Kodak only considers the wrist strap a "user-serviceable item." Maybe so, but I intend to try to fix this myself. If anyone has done this successfully before, please write. Otherwise, will let you know how it goes.
May 06, 2008 | Kodak EasyShare C643 Digital Camera
Panasonic Lumix DMC-TZI - broken battery tab and battery/card door
well there is no easy way. You will have to open the machine up when you have ordered the parts you needed. Not to hard but make sure you keep you eye on the sequence how you pull it apart.
Apr 24, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Broken battery door
They are WAY out of business - parts no longer available
Jun 09, 2007 | Verge DFP-200 MP3 Player
Sony Cyber-Shot DSC-S500 Digital Camera Logo
6,415 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
