Question about HP 1220 Plain Paper Inkjet Fax
Replaced Ink Cartridge
Replaced the ink cartridge and can now receive faxes but when trying to send fax, receive an error message stating: Failed align cartridge. When we align the cartridge, the machine continues to display the same error message when attempting to fax out.
  • 3 more comments
  • sarsy Jan 17, 2008
    Hi I have the same problem in my hp officeJet K80 Does anyone know how to fix it
  • Anonymous Mar 12, 2014
    New ink cartridge only works a short time then fax message states change ink catridge before ink is really out. Will not print with this error displayed.
  • Anonymous Mar 18, 2014
    It won't print or copy in black. The black ink cartridge was replaced. It still won't work. The printer alignment won't work, it aborted.
    I just changed my black ink cartridge and now I can't Align and get a failure message
  • Anonymous Mar 31, 2014
    Cannot figure out how to get ink cartridge holder out
    Genius:
  • 1,003 Answers
Turn fax machine off open cover and put 3 drops of 3 in 1 oil on the the big silver bar the ink cartridges ride along perform alignment and try to recieve fax if this doesnt work clean all the rubber feed rollers with isopropanol alcohol (rubbing alcohol) applied to a microfiber towel then try.
Posted on Jan 17, 2008
Dont used alcohol just distilled water and lint-free cloth. dont ever put oil on ur printer
Posted on Jun 11, 2008
6ya staff
SOURCE:
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
We purchased a new cartridge because it said install new ink cartridge,we installed new cartridge it still says install new ink cartridge and will not receive or send faxes
it will not send or receive a fax if the error is still there. Clear the error by trying these steps:
-open cartridge door and remove the cartridge
-unplug the power cord at the back of printer
-after 30 seconds, plug the cord and turn on the printer. It will ask for the cartridge.
-Open the cartridge door and insert the cartridge
-close the access door
-if the error is cleared, try faxing again.
I hope this helps.
Regards,
Mar 02, 2009 | HP 640 Inkjet Fax Machine
Message: Intall new ink cartridge. Ink Low
When you hear the fax ringing, press the start button. It sounds like you are not set to AUTO RECEIVE
Jan 20, 2009 | HP 1040 Plain Paper Inkjet Fax
CHECK CARTRIDGE
when trying to copy or receive a fax machine will flash printer error and send out blank page i replaced the ink cartridge and blue air tho it but nothing seems to help
Oct 03, 2008 | Sharp INKJET FAX UX-A1000
Samung Sf-330 fax.
probably you did not fix properly the ink cartridge.check the cartridge for proper seating.
Jun 02, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
Check Cartridge Error - Sharp UX-B700 Plain Paper Inkjet Fax
I replaced my new $40 cartridge with another new cartridge and it worked.
Feb 23, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Message: Remove and check ink cartridge
hi just fixed my 6110 hp by pulling out spring wire that is on right hand side where black ink cartridge gets inserted i think it was preventing a good contact
i did this after following all other help hints including cleaning heads etc and replacing with new ink now it works perfect hope this works for you too
Oct 14, 2007 | HP OfficeJet 6110 All-In-One InkJet...
"printer error - check paper" after cartridge replacement
First remove all paper from fax machine and unplug fax machine from the wall socket for 12 seconds then replug fax machine into wall socket replace paper and try printing
Oct 03, 2007 | Sharp UX B700 Plain Paper Inkjet Fax
ERROR MESSAGE
please check and clean the unit where ink cartridges are located
Sep 21, 2007 | HP 920 Plain Paper Fax
HP 1220 Plain Paper Inkjet Fax Logo
227 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
