Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Screen is bowed (top and bottom) Color has a green and purple tint?
My JVC AV-56WP74 has the screen bowed on the top and bottom. The color has a green and purple tint. The picture on the top and bottom is doubled with green and purple, i can see the picture in the middle of the screen (not clear). Someone said that i have a convergence problem. I will have to replace or repair the ic to solve it. What is ic? Where do i get this part? Should i just have a repair store fix this problem or just buy a new tv?
  • Amy_Fisher23 Jan 15, 2008
    I also tried to adjust the color convergence (Auto and Manual) with no success. Adjusting manual will only allow me to change the red ( no other color).
  • Anonymous Mar 31, 2008
    the top corner is bowed and i can only move red covergence the yellow one is bowed
    Filmmaker:
    Uploaded 5 video answers.
  • 162 Answers
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Here is an example video
Screen is bowed (top and bottom) Color has a green - utube.png You-Tube video "9oI1Nzq7CR8" placeholder (do not delete) utube.png
Posted on Apr 19, 2012
    President:
  • 4,402 Answers
Read these
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 15, 2008
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: I have a JVC AV-56WP74
You need to replace both convergence ICs they are STK392-110 you may want to get the resistor kit as your model will usually have a couple open resistors. You can get replacement ICs and resistors at the following link and they provide free instructions with pictures so you can easially do the repair your self.
Heres the link.
http://servicemanuals.vstore.ca/
Posted on Aug 13, 2008
My red color on the color convergence does not match the blue and green color
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | JVC AV-56WP74 56" Rear Projection...
Double vision on tv with purple and green colors
This television set, as well as most rear-projections, is prone to convergence driver problems. There are two large chips (STK392-110's) in the TV that need to be replaced, as well as some resistors that are likely damaged as well. Any competent TV repair shops should be able to repair this TV for 200-300 dollars. It is important to note that if the back of the TV is taken off without the proper prep., the Digital input (DVI) will be disabled permanently.
Hope this helps you...
Dec 30, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC 56 inch projection AV-56WP74 red color not aligned
I have the same tv set and about 4months ago Ihad the IC STK392-110 replaced. I was told that it was the most common problem with proj. tvs. It did solve the probem until last night when I went into the menu to change a audio setting and stupiditely accesed the convergence setting and decided to do an auto adjustment which mesed up my beutiful HD picture. Now I have the red out of alignment ad even after I did a reset and multiple manual adjustmets it is still off at the top and bottom af my screen.
Dec 27, 2008 | JVC AV-56WP74 56" Rear Projection...
Green color convergence
make sure you hooked everything up properly and that all connections are tight
Aug 26, 2008 | JVC AV-56WP74 56" Rear Projection...
I have a JVC AV-56WP74 that all of the sudden has a bow screen on top and bottom with green and purple tint with double picture. I have tried to fix the problem working with the convergence troubble...
Heres the link.
Aug 13, 2008 | JVC Televison & Video
JVC AV-56WP74 56 in. Rear projection blurred image
Check that the 3 output plugs are in the right sockets (Red, Blue, Green) There is usually a felt pen colored mark on a white tape on the plug in wires. The Board sockets are marked Red, Green, Blue.
Easyab
Jun 20, 2008 | JVC AV-56WP74 56" Rear Projection...
65 in.JVC bad picture
You may have a convergence problem that means, there may be convergence ic's bad or related components.
If you know something about tv's, try checking things out.
You can get a repair manual from websites to download.
If you do not normally fix tv's the best thing is to call a tv repair technician.
Feb 22, 2008 | JVC AV-65WP55 65" Rear Projection...
RED AND GREEN DOUBLE AND BLUR PICTURE HELP PLEASE
You have a convergence problem. Components are shorted out and must be replaced. Unless you're a technician, there's really nothing you can do at this point.
C-Dog
Feb 03, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC AV-27230
pam hit menu and turn captions off this should fix your set John
Sep 11, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
341 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
