Question about Relisys TL 766 Monitor
Relisys tl 766 monitor
Menu keeps popping up in middle of screen and I can't get it off.bought 2nd hand but only 3 months old, no manual with it.
  • Hawkeye44 Jan 24, 2008
    I have turned the monitor on and off. I have shut down and restarted the computer. I then connected the monitor to the output from my laptop and the problem persisted. I have managed to increase the transparency of the menu so that I can use my computer. I would appreciate some assistance in solving this problem.
  • saturnone Mar 19, 2008
    Same problem too menu popes up and is like the clockwise button stuck menu goes round and around !!
    Problem Solver:
  • 9 Answers
I have a Dell E171FPB monitor that had the same problem with the Main Menu coming up and I thought I would tell you what I did to fix the problem.
1. I shut down the PC.
2. I removed the power cable and video cable from the back of the monitor.
3. I removed the four screws that hold the stand for the monitor and slid the stand off.
4. I then removed the 5 screws that hold the back cover on the monitor.
5. I took two flat blade screw drivers and carefully removed the back cover.
At the bottom of the monitor case, there is a small circuit board the holds the 6 switches for controlling the display.
6. I located the button that calls up the Main Menu. It is the second switch from the left as you are looking at the monitor from the rear.
7. I used a small solder iron and heated up the four prongs in sequence while holding the switch with a pair of needle nose pliers. I had to rotate this process from one prong to the other while all the time applying slight pulling pressure on the switch pulling it away from the circuit board.
8. Once the switch was removed, I put the cover back on and tightened up the five screws.
9. Then I slid the base back in the slot it came from and tightened the four screws.
10. I connected the video and power cable and turned on the PC.
With the switch removed the Main Menu never popped up again and I am so very happy.
Posted on May 30, 2008
I have connected to clips on the far left and far right menu buttons, so the buttons are pressed in all the time and it has worked. No more menu pop ups. Hope this helps.
Posted on Mar 24, 2008
  • 3 Answers
Ok i think i know how to get rid of it now, i did an ATX reset on it and it does go away HOWEVER as soon as you push the menu button again it comes back.
ATX Reset: unplug the main power lead then hold down the power button on the front of the monitor for about 10 seconds, plug the mains lead back in and then switch the monitor on.
The monitor keeps turning off for no rreason while in use
theinstall, The internal AC line to DC power supply will need to be investigated for bad solder joints and or bad aluminium "can" electrolytic filter capacitors. 12fixlouie
Jan 18, 2010 | Relisys TL 766 Monitor
Flickering and garbeled screen
Try to lower your screen display resolution: you might have to do it under 'Safe Mode' (eg. reboot your computer in 'Safe' mode normally done using the F8 key during the initial boot sequence) as your screen display appears to be unstable/unreadable.
Dec 29, 2009 | Relisys TL 766 Monitor
How do i reset monitor to original settings
There is a button on the front which will take you in the Menue option there you can press the recall option.This will reset the monitor.
Good luck
Oct 17, 2009 | Relisys TL 766 Monitor
Horizontal black lines across the screen
you can try contacting Lumaco they are a British monitor repair specialist.
www.lumaco.co.uk
It might even be cheaper to buy a new one.
Jun 19, 2009 | Relisys TL 766 Monitor
JM777 no receiving signal from CPU
when u power up the computer press F* key then go to enable vga mode then set disaply resolutin incotrol panel to 800*600 or 1024 *768
Nov 24, 2008 | Relisys TL 766 Monitor
Relisys TL766 monitor. OSD menu continually open, wont close. Standby button doesnt always function.
Here is a definite solution to all those having problems with OCS menu on Relisys TL 766 Monitor.
Having tried many of the posted solutions none of which worked. The only option was to visit my local PC repair shop who disconnected the OCD monitor for UK £15.00. Spare parts for this model are no longer available. Only down side was the power indicator light in middle of now redundant control buttons does not work. Otherwise a monitor works perfectly. NO MORE STRESS.
Oct 15, 2008 | Relisys TL 766 Monitor
RELISYS TL766 17" TFT MONITOR
Hi,I have same monitor and problem,still unable to resolve, I been told to try the monitor on other PC to see if the actual problem is in the monitor or originates from the PC.
Oct 03, 2008 | Relisys TL 766 Monitor
Relisys 17in tft monitor
hi everyone,
i have a relisys monitor and had this exact same problem where the menu screen comes on and then cycles through the various options until it gets stuck in a loop within the colours settings.
- the solution i found is to open the monitor itself. (make sure power supply is disconnected)
- opening the monitor should be fairly easy - i have 4 screws located at each corner of the monitor.
- i have 6 screws which locate and secure the stand.
- once the screws are removed you can prise open the monitor.
- to make this easier start where the monitor comes apart
the easiest and the use your fingers to slowly prise the
rest of the casing apart.
- now examine the circuit board which you will spot quickly as it is the only circuit board visible. The rest is hidden by a steel guard.
- the circuit board is secured with three screws before
removing them make sure your body is free of static
by touching something which is metal and grounded.
- once you have removed the board locate the white connecters which are inserted in to the board.
- the one i disconnected was the one which is concerned with the menu system, which is the small connecter.
- refit circuit board
- refit casing
- refit stand
and there you have it your monitor should now work but with no menu facility, however the monitor will still have the ability to auto reset the screen should it be misaligned.
notes
this is not a complete fix, even though it worked for me it may not work for you, however you could try removing other connections and reseating them. more connections are locating underneath the steel guard inside the monitor.
Mr Jag Singh
Nov 25, 2007 | Relisys TL 766 Monitor
Relisys TL 766 Monitor Logo
315 people viewed this question
Top Relisys Computers & Internet Experts
Marvin
Marvin
Samuel Konger
Samuel Konger
giarcnameloc
Level 1 Expert
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
