Question about Whirlpool ER6AHKXPQ Top Freezer Refrigerator
Roper refrigerator top freezer
There is a burning smell in the freezer. The back wall will actually melt any plastic freezer bags leaning up against it and produce an awful smell.
We have only noticed this only this week. We have been renting since August 2007. We had a maintenance man out who says that this is a common complaint with these refrigerators.
We dont feel safe with this going on, but the janitor assured us that they have had many complaints in the other units. He stated that it is the self defrost working and it is common an to keep any items from touching the back wall. (which is ridiculous!)
Could you confirm this? Is it safe?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 37 Answers
Moonpie,
Based on info given,possibly either a defrost timer or a defrost heater thermostat going bad.(depending on your model) Both tell the defrost heater when to deenergize and stop the defrost cycle. I suspect with the defrost heater getting this hot..over time it will burn out. Then the auto-defrost will not work. Then it will cause ice to accumulate on the evaporator coils cutting air flow and causing the refridgerator section to not cool properly. On the safety issue...many, many,complaints don't make the problem go away or ANY safer does it? Make another call to maintenance,maybe they will send someone else out with more expertise on the matter. I wouldn't feel comfortable letting it go. Hope this is of some assistance.
Good Luck
handiman518
Posted on Jan 16, 2008
  • 447 Answers
I can confirm that this is definately not normal. During a normal defrost cycle temperatures will rise to around 50-60deg F. But shouldnt get hot enough to melt anything. Something is wrong- have it checked by a professional. Demand that.
Posted on Jan 15, 2008
Excess water dripping into refrigerator from freezer. I am in the process of defrosting. Ice build up behind freezer back wall. Do I need a new heater or will clearing the ice from drains suffice?
Clearing the ice build up is a good start,the problem though is the drain pan under the coil in the freezer thats iced up is blocked so when the defrost heater comes on and melts the frost from that coil,it the water is collecting in the freezer and in many cases drips into the fresh food compartment,clearing the drain will resolve your leaking/ice build up issue.THE DEFROST HEATER IS GOOD melting the frost in the first place and hence forth that melted frost stays in the freezer and becomec ice.
Gene
Aug 09, 2011 | Roper RT16DKXK Top Freezer Refrigerator
My Roper refrigerator has water inside it at the bottom and on lower level shelves. How can I correct this?
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Aug 01, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
Heated the middle body it smells like a plastic burned
do you mean that the area of the outside cabinet where the door seal presses up against is warm? If this is what your describing then your compressor fan is not turning and causeing the lines to heat up unplug the machine until you are able to replace the fan if this is the issue you are seeing on your unit if not please clarify when you said heated middle body and where the smell of plastic is coming from. also is the freezer and fridgerator still getting cold? You may also want to check the light area I have seen many times where the lights will melt the plastic. If you have any further questions message me back I await your reply Thanks Rick
Jul 04, 2011 | Samsung RS2530B Side by Side Refrigerator
My whirlpool fridge similar looking to Whirlpool GR2FHMXV Top Freezer Refrigerator has been making a big bang noise many times in a day. Tonight it has a burning smells. Please advise?
the banging and crackle noise can be from the defrost element in the freezer side as it heats up it melts the ice on the evaporator it can be a bit nosy. there shouldn't have a burning smell tho get it checked out
Feb 04, 2011 | Whirlpool GR2FHMXV Top Freezer...
New fridge, freezer door left cracked open, looks ...
If new enough to still be under warranty, register and contact Whirlpool for repair.
Customer Care Service More Whirlpool
Feb 26, 2018 | Whirlpool ET1FTTXK Top Freezer...
Looks like water dripping from frezzer, but there isn't an ice maker hooked up in the freezer. top refridge shelf covered with water and ice
you have a blocked drain.i use a steamer to clear the drain,they cost around 50 bucks,take off the back wall.melt out ice with hair dryer,crack out as much ice that you can with plyers or hammer,gently hit it and it will crack out if the floor is a sheet of ice and a putty knife comes in handy,when you melt out and remove ice stick the tip of steamer in drain and clean the drain out,hit it for 10 seconds then stop wait a minute and hit it again,you don't want to damage the drain line it's plastic so take your time,pour hot water down drain to make sure it's clear you might have to use hair dryer and heat up the inside of ceiling in the fridge section in the middle of back wall and ceiling where the drain is, the air ducts are there also,whenwater stops dripping you'll know you melted all the ice,good luck
Jan 23, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Burned plastic part on refrigerator compressor
side by side refrigerator freezer, smelled melting plastic, found a plastic box connected to the compressor burned. What is this and how much does it cost to replace?
Dec 13, 2009 | KitchenAid Refrigerators
Top refrigeration portion smells like something is burning, warm temperature on top portion, bottom freezer appears to be working, unplugging and switching circuit breaker does not resolve problem, smell...
I need to let you know that your refrigerator may fall under a consumer alert. It is possible that the lights are remaining on while the doors are shut and can result in property damage. The issue is the light melt the plastic and damage the refrigerator, food and possibly smoke damage. If this is not the case please let me know and I will assist you if there is something other that this causing the problem. Thanks Sea Breeze
Oct 29, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Roper RT18SKXRD01 refrigerator not cooling the freezer is -10 degrees, but no cold air going into refrigerator; vacuumed back; fan blades are going around and motor humming away. just no cold air dropping...
Hi: When this happens it means that there is frost built up in the back of the refrigerator. You are having an issue with the defrost heater or the defrost timer. There is an off chance the refrigerator's freezer is over packed with food and there is no circulation. If you're handy empty the fridge and take a hair dryer to the back wall to melt away the frost from behind. You will have to remove the back metal wall. Look at the heater. It will be at the bottom of the freezer behind the back wall. A glass tube with a wire coil running through it. If the coil is broken, replace it. If not you will be looking at a defrost timer. Sometimes on a circuit board. Searspartsdirect will have the parts and schematics. I hope this helps, Jeff
Jun 07, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
My fridgidaire isn't level
On a top freezer t\it should be tilted skightly towards the wall.
Mar 13, 2009 | Frigidaire FRT21H8 Top Freezer...
Whirlpool ER6AHKXPQ Top Freezer Refrigerator Logo
114 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
