Question about HP PSC 2210 All-In-One InkJet Printer
Printing Printer will not print normally, but the next time the computer is turned on , it starts printing all documents in memory.
  • 53 Answers
Hi virmar,
The best solution is to go into control panel then printers and see if your printer is set as the default printer if everthing is ok then re-install your printer drivers as it looks like one of your printer files may have been deleted accidently.
Posted on Jan 15, 2008
How can I stop it from printing over and over again
you have clear the print buffer in the computer.
by clearing out the buffer, unplug the computer after ward and than also unplug the printer too, that should clean the memory in the printer itself.
GO TO START CLICK ON START GO TO DEVICES AND PRINTERS, OPEN THE FOLDER CLICK ON THE PRINT YOU ARE HAVING ISSUES WITH DOUBLE CLICK IT WILL SENT YOU TO CHECK LIST OF OPTIONS THE FIRST ONE.
1. SEE WHATS PRINTING, CLICK TO OPEN
2. HIGH LIGHT PRINTER THAN SCROLL DOWN TO CANCEL ALL DOCUMENTS.
YOU SHOULD BE DONE
BUT YOU STILL HAVE TO CLEAR THE MEMORY THAT STORE INFORMATION IN MEMORY INSIDE THE PRINTER
BY TURNING OFF MAY NOT BE ENOUGH YOU MITE HAVE STILL UNPLUG IT TO CLEAR ANY OR ALL MEMORY FILE
THANK YOU ROD
Mar 03, 2015 | HP Office Equipment & Supplies
Printer does not print computer documents
The queue is so choked with documents the printer gets confused and loses its sense of priority. Shut down the printer and disconnect power to clear its memory. Wait a few minutes and reconnect power. Start sending one document at a time to the printer and you should get results.
Mar 08, 2014 | Samsung Office Equipment & Supplies
Need to clear printer memory
It sounds like you have a problem with your network and or hub. I would look at that first, it's not the copier. Good Luck
Sep 24, 2012 | Canon imageRUNNER 2010F Copier
Prints PDF documents VERY slowly (4-5) per page
The actual issue you will find that its not so much the actual printing part of the process that is slow, its actually the spooling to the printer that takes the time.
Does your printer support PostScript printing ? (PostScript is a printing & imaging standard used by many printers) To find out if your printer does indeed support this either refer to your manufacturers documentation or perform a test page and look to see if you have a PostScript enabled option.
If your printer does support PostScript, make sure you are using its PostScript printer driver, most of the time we generally use PCL drivers, so simply change this.
Regards....
If you find your printer does not support PostScript there are a few other tweaks we can implement to increase printing speed.
Firstly we can force PDF files to be printed as graphics as opposed to text, to do this launch your chosen PDF viewer, select Print > Advanced > Print as image
Lower the print resolution, if we lower the print resolution most of the time the difference is very small, but it can reduce the actual print size of the document by up to 300%, which can greatly decrease printing times.
Make sure you are using the latest version of any print drivers or your chosen PDF printing program, normally Adobe Acrobat.
If the printer only has a small amount of memory if possible add more, if possible install a PostScript SIMM.
Check the amount of ram your computer currently has, check memory usage from task manager when printing to ascertain usage
May 19, 2010 | HP Color LaserJet 2600n Printer
Printer keeps printing same document so i can not delete it
You have to erase it from it's memory. If you have already tried to cancel it via your pc and it didn't work, try this: turn off the printer. Entirely, from the wall socket. Turn off your computer. Then turn them on again. Both the computer and your printer should erase the document from their memory, so it will stop the printing.
Feb 27, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Doesn't want to print
Try unplugging from the wall for 5 minutes / plug in and retry, cancels / resets printer memory.
Feb 17, 2010 | Canon BJC 3000 InkJet Printer
Trying to clear memory on HP #D1420
You need to clear the print queue in the printer properties.
go to start >printers and faxes > double click on your printer.
click on the word printer (on the upper left corner),when the window pops up. then scroll down to cancel all documents. This will clear the print queue.
Afterwards, power off the printer and the computer. wait 30 seconds, power up the printer, wait 30 seconds, then power on the computer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 19, 2009 | HP PSC 2410 All-In-One InkJet Printer
Printer printing documents again when computer restarted
go to the "computer" place at the start
then go to printer, or do whatever u have to do to go to printer
then click the button or icon
it should show the documents names
click it and press delete
there
Mar 05, 2009 | HP LaserJet 1012 Printer
Printing status frozen and won't delete or print
Have you tried unpluging your printer from the computer as well as unpluging the printer from the electrical? If that doesn't work you should start from scratch... that is remove the printer from the computer memory, delete it, turn off the computer, turn on the computer and go through the installation process as if you just purchased the printer. Barring any mechanical problems as in jams or the such, the printer should return to operational status.
Oct 07, 2008 | HP DeskJet 5150 InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
23 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
