Question about Liebherr K 255
Fishy smell My ice in my Liebherr icemaker smells of fish.
  • Anonymous Jan 16, 2008
    Same thing started to happen to me.
    The ice seriously smells like rotten fish sitting in an old rubber tire.
    I have already done a full clean out of fridge and freezer (including ice tray)
    My tap water taste is normal, so it's not the water.
KOakaKO
  • 135 Answers
SOURCE: Fridge Smell
Wash it out with bleach. Nearly always solves this problem.
Posted on Aug 02, 2007
xMadx
  • 64 Answers
SOURCE: Bad smell coming from fridge
Is there any chance that small food particles have simply fallen into the fan and now trapped near or behind the fan ?
If this is the case, the food may be lodged in such a way that either heat given off from the fan or the fact the food may not be getting cool/frozen any longer, may have sent the food bad and is now generating the smell you describe.
I don't know of any fridge gas that smells like fish or funk as you put it, most are fairly neutral smelling or odorless to a point and certainly would not smell the way you have described.
  • Make sure the area is well ventilated ( run a pedestal fan nearby or open a window ), fridge gas can be harmful, even in small amounts ( especially if you don't know you're breathing it ), and if the smell is as bad as you say, you may very well be gasping for air.
  • Always have someone nearby when you attempt to do your own repair work of this nature, you just never know when you might need their assistance.
  • If you plan on looking into the problem yourself, firstly ensure the fridge is off, and unplugged before sticking fingers anywhere near a fan - plastic or not, i have seen 4 inch biscuit fan take the tip off an index finger of in a fraction of a second, so don't think for a minute because it's plastic, it won't bite.
  • Do not use any sharp pointed or metal objects to remove the fan or it's plastic cover, use fingers or flat blunt objects that can not puncture the lining of the fridge itself.
  • ( trust me when i say i speak from experience on this )
  • Be extra careful when removing the shroud around the fan, it should simply either click in or there maybe small coverings, covering 3-4 screws around the unit.
  • Remove the fan cover, being again extra careful of the unit itself and check around with a flashlight and perhaps even a magnifying glass.
  • If you can not find any offending objects, it is probably best to replace the fan and shroud and call the repair guy.
Posted on Feb 04, 2008
IB4G2008
  • 3587 Answers
SOURCE: Dishwasher smells like fish
MILDEW...use arm and hammer baking soda in a few cycles, to see how that works for you
Posted on Mar 23, 2008
  • 184 Answers
SOURCE: frost free freezer smells like fish
IF THERE WAS A LAYER OF ICE ON THE BOTTOM OF THE FREEZER, THE DRAIN IS PROBABLY PLUGGED UP. IT WILL NEED TO BE CLEARED BEFORE PUTTING BACK INTO SERVICE OR IT WILL JUST DRAIN INTO THE FLOOR OF THE FREEZER AGAIN. AS FAR AS THE ODOR, TRY PUTTING CHARCOAL IN IT TO ABSORB THE ODORS. IT WILL HAVE TO BE LEFT IN THERE FOR QUITE A WHILE. WHEN THE FREEZER IS CHILLED, IT WILL LESSEN THE SEVERITY OF THE ODOR. IF THAT IS UNACCEPTABLE, THERE ARE COMMERCIAL ODOR NEUTALIZERS ON THE MARKET YOU CAN USE.
Posted on Apr 05, 2008
PegBox60965
  • 51 Answers
SOURCE: fishy, steam odor coming from AC vents
Forget the radiator tank. Your AC 'Condensate drain' hose is plugged up. This is a common problem. If you know where the hose comes out under the car you can ( carefully ) push a wire up it. If you're lucky it's plugged near the end by a mud-dauber wasp. If not, take it to your dealer and see if you can persuade the write-up guy to show you where the drain outlet is as a gesture of good faith. If they insist on charging you money, consider that when you buy your next car...
Posted on Dec 30, 2008
How do I get rid of this terrible fishy smell from my freezer/refrigerator?
Hello Heather.
Have you had anything wrong with fridge that caused the smell.
Try charcoal in both fridge and freezer.
Hope it will help.
Fish smell is hard to get read off
May 21, 2015 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frigidaire dryer smells fish odor
well then clean your fish in the sink... or check for a leak and you might find some mold
Dec 30, 2013 | Frigidaire Electric Dryer
SQD26VL side-by-side has a fishy odor. Where is drip pan?
The drip pan is outside the fridge I believe, sitting in the back panel.
Apr 27, 2012 | Amana 22.6 cu. ft. Side-By-Side...
My fridge smells fishy. It is perfectly clean and i have not had fish in there.
Bacteria will cause the smell. Make sure it is cold and put a box of baking soda open inside the fridge. It will absorb the odors. They sell baking soda with a mesh side specifically for your fridge.
Jun 06, 2011 | Samsung RS2530BSH (25 cu ft) Side by Side...
Fish odor in freezer and fridge
Unplug first. You will need to clean the inside of the refrigerator and the freezer with a good cleaner and warm water. After this you need to remove the rear panel in the back of the freezer and spray water with Clorox on the evaporator coil and pour some of the solution down the defrost condensate drain to disinfect and remove the odors that drain down that hole to be evaporated and returned to the air in your home. That should take care of the fish smell, Please rate my solution, Thanks, Sea Breeze
Aug 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore top freezer fishy smell
if it has an icemaker attached, this may cause your problem. to get rid of the fishy smell, get a box of baking soda, open it a little, and stick it somewhere in your freezer. this will help to filter the air and make it fresher. Also some vegetables can cause this noxious smell, especially if cooked then frozen or if a box or bag of bad frozen vegetables has been stored in the freezer. Our freezer recently had a problem with the icemaker making it smell musty, like after a rain, wet dirt, and I have yet to find a real solution to this problem other than baking soda.
Jun 15, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Fishy smell in frig
Change the filter. Depending on your water supply and where you are located, you will get a buildup of junk that smells like fish.
It should be changed about every 6 months.
Feb 17, 2009 | Jenn-Air JBL2086HES Bottom Freezer...
Frisdge/freezer and ice smell
I had a side by side refrigerator with an Ice maker from Sears. The ice it makes smell fishy so bad that I could not use to drink with anything else but throw away to the plants. So I unscrewed the ice maker . It is not that bad, but quite simple to take it out. I noticed rusted pieces of metal generating strong fishy smell. I could not get rid of rust with soap, detergent, oil so I wrap it in plastic bag then screw it back into the refrigerator. Screwing back the ice maker. Voila. The smell is going away. The ice is good. Pina Colada and Daiquiri here we go .
Jan 24, 2009 | Jenn-Air JBL2086HES Bottom Freezer...
Dishwasher smells like pond scum
I have the SAME problem with our dishwasher. It's disgusting. Between the fishy glasses and the garlicky ice cubes (NO, we don't have garlic in our refrigerator or freezer -- purchased ice doesn't smell), I'm embarrassed to pour our guests a glass of ice water!
Jun 05, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Fridge Smell
i have a whirlpool fridgefreezer and their is a very bad smell comming from the back of it what can it be
Aug 02, 2007 | Hotpoint FFM70 Bottom Freezer Refrigerator
Liebherr K 255 Logo
60 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
