Question about Lenoxx Electronics CD-102 Cassette/CD Boombox
The cassette spindles do not turn at all - Lenoxx Electronics CD-102 Cassette/CD Boombox
  • bjs509 Jan 24, 2009
    I have the same problem -- cassette spindles don't turn. Have NO idea how to find the belts, much less change them.
Check for broken or stretched rubber drive belts. Age is as bad an enemy as wear. If it has been sitting for a period of months they go bad faster. Even if you keep it indoors out of the heat, the A/C will dry out the oil the belts and they wil lose their elastisity. There are usuallyonly about 3 or 4 belts in the cassette player at most and they cost less than a dollar each. If you can find the belts, buy extras and keep the extras in a zip lock bag. Parts are harder to find as time goes on and most manufacturers will deliverately quit selling normal wear items like belts after a few years to force you to buy a new product.
Posted on Jan 21, 2008
  • 61 Answers
I do agree witht the expert above, you can order the belts on this site
http://www.studiosoundelectronics.com/cassette.htm
Posted on Sep 28, 2011
Tape spindles do not turn, but motor runs
Assume this is about either cassette or reel-to-reel tape and not DVD.
The symptoms you describe might be a clutch that is refusing to engage but is most commonly a worn or broken or contaminated drive belt.
Sep 09, 2015 | Televison & Video
Dura brand,why is the tape coming out of the cassette when I pay it?
Hi there
This is an answer which is general to all tape cassette decks. I think it probably applies to yours but this may or may not be the case.
The tape is transported past the "read" head by a pinch wheel and spindle that come up into the cassette on either side of the tape. The spindle runs at a very constant speed and with the tape between this and the (rubber) pinch wheel sounds are transferred fro the read head to the electronics for amplification etc. We are not concerned with that here but with what physically happens to the tape after the pinch wheel. Under normal circumstances a belt is driven from the electric motor to the take-up reel of the cassette. This usually runs slightly faster than the spindle/ pinch wheel so that the tape winds cleanly onto the take-up reel. If this belt is loose, has come off entirely or is otherwise not working properly, then the spindle/pinch wheel will continue to feed the tape but it has nowhere to go because it is not being wound onto the take-up reel, except out of the cassette into the tape desk mechanism. In this case it often gets wrapped around the spindle/pinch wheel assembly and gets into a very nasty tangle, causing serious damage to the tape and possible damage to the deck.
Hope this explains your problem.
Cheers
Nov 10, 2014 | Audio Players & Recorders
Only one spindle turns on cassette player
It is probably a loose or broken belt. I do not know the unit so this is just a starting point.
Aug 10, 2014 | Aiwa Audio Players & Recorders
Where is the rewind on this cassette player?
Cheap cassette players have no rewind feature. This allows the mechanism to be simpler and cheaper; they just 'pull' the tape forward constantly, without the pinch wheel for "fast" [sic] and with the pinch wheel for "play".
To work out if this is the problem with your cassette player, look inside with no cassette inserted. If one of the spindles is plain, without the "three-pronged" device to engage with the spool, then you have the cheap device with no rewind. Turn the tape over, and fast-forward.
Jan 19, 2011 | Audio Players & Recorders
Cannot seem to remove the ribbon cassette from IBM Selectric II. Would like to place it in another Selectric II that runs well but has no ribbon. I pulled the lever on the right but the right side of the...
Pulling the lever on the right of the cassette should move the ribbon drive spindle out of the cassette and leave it free to remove, but sometimes the ribbon can become twisted on to the drive spindle and it won't disengage. If that has happened you will have to break open the cassette to free the spindle.
May 01, 2010 | Office Equipment & Supplies
The power is on but the motor will not turn the tape drive. Does anyone know a good repair shop?
Hmm, when you press play, can you feel the motor turning, do the spindles turn on fast forward or rewind? If so you may have one of two problems. First check to see if the cue button is is depressed. If it is jammed, the deck will FF and RR but won't play. If it's not that, but the motor still spins, the motor is no longer making contact with the flywheel. If you have a repair manual, dismantle the deck and check out the motor contact
May 10, 2009 | Sony Walkman WM-D6C Personal Cassette...
Dictaphone indicates end of tape
The sensor that detects the tape movement is bad and will need to be replaced.
Nov 10, 2008 | Dictaphone 2741 Desktop Cassette Voice...
TEAC CX-370 Cassete Deck
Could be a worn out belt? The cassette loads it the drive down too much. Hence why it turns with no tape.
Jul 04, 2008 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Lenoxx Electronics CD-102 Cassette/CD Boombox Logo
440 people viewed this question
Top Lenoxx Electronics Audio Players & Recorders Experts
Tony Mitri
Are you a Lenoxx Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
