Question about Lexmark X6170 All-In-One InkJet Printer
LexMark 6170 Encoder strip came off
How do i get this back onto the printer?
    Sergeant:
  • 390 Answers
Unplug the unit. Move carrier to middle. Gently press down on either end of the carrier, you are moving it down and a bit forward then let it go back up, this will get it back going again. It should now be back in slot. cheers lilacgerry xxx If you get error 502 or similar, clean the roller and coating with a lint free cloth or unscented wipe.
Posted on Feb 10, 2008
What causes the error message oxc18a0001 for printer number c7280.
This message appears when there is ink system failure.. either the cartridges that you are using got damaged or are refilled and also happens when the memory of the printer goes bad
Nov 09, 2009 | HP Photosmart C7280 Laser Printer
I want to take off the old Ribon and put a new one i don't know how to do it
Lift the front cover take hold of the cassette at each end and pull upwards.
Before you do take note of the path that the ribbon takes across the print head (Make a sketch)
Take out and shipping strips on the new ribbon and pull some of the ribbon out of the cassette
Lay the cassette onto the printer and feed the ribbon back onto the head as per your sketch.
There is a small knob or turnkey on one end of the ribbon wind that slowly so that the ribbon is drawn back into the cassette until there is little or no slack
Place the cassette down onto the two spindles and press into place use the winder to tension the ribbon
A pair of powder free surgical gloves are recommended
Nov 05, 2009 | Epson LQ-2090 Matrix Printer
Printer does not print documents that are more then one page long. all I get is a blank sheet with a page no after the first page which prints ok
If you print out a Test Page (Start -> Control Panel -> Printers & Faxes -> Right Click on your printer entry -> Properties -> Print out a "Test page")
If that does not print please follow these steps: Remove the printer USB cable from your PC -> Restart your PC -> Log back onto your Profile -> Click on Start -> Control Panel -> Printers & Faxes -> Delete all printer entries -> Restart your PC -> Log back onto your profile -> Plug the printer USB cable into the back of your PC -> Go into Printers & Faxes -> Right Click on the Kodak AiO entry -> click "Set as Default" -> Now try to print.
Oct 20, 2009 | Office Equipment & Supplies
The printer does not respond to print order. I get a message saying camera is connected, it is not.
The Camera Detected message is your PC detecting the scanner on the Printer - What happens when you try and print?
Also, try the following:
Remove the printer USB cable from your PC -> Restart your PC -> Log back onto your Profile -> Click on Start -> Control Panel -> Printers & Faxes -> Delete all printer entries -> Restart your PC -> Log back onto your profile -> Plug the printer USB cable into the back of your PC -> Go into Printers & Faxes -> Right Click on the Kodak 5100 AiO entry -> click "Set as Default" -> Now try to print.
Oct 13, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Whenever I try and print to this printer it says it is offline. I have turned off and back on, unplugged and plugged back in... Nothing has changed on the computer.
Have you checked the printer driver itself, it might have knocked itself onto Offline and you might be able to change it back to Online.
If not, the other thing is to try uninstalling the printer driver and reinstalling again.
Aug 04, 2009 | Zebra Eltron P310 Thermal Printer
Can't print photos onto photo paper from computer
hii
you must check the setting of your printer and then restart the printer.
Jun 22, 2009 | Computers & Internet
Upon replacing a cartridge, the alignment page only appears with yellow ink and the alignment page will not print
Depending on your type of printer, this happens alot.
Take the colour cartridge out of the printer and also get a blank bit of paper, we need to bleed the cartridge.
Put on a flat surface, put paper covering surface and bang the inkspray end of the cartridge onto the paper 4 or 5 times, then you will see the colour bleeding onto the page.
Put back in printer, should work fine.
Nov 08, 2008 | Office Equipment & Supplies
Lexmark 73 offline
pull the power supply out then back in then do the same with the usb plug at the back of the printer
Jul 19, 2008 | Lexmark X73 All-In-One InkJet Printer
Lexmark X6170 All-In-One InkJet Printer Logo
59 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
