Question about Sony GDM-C520K (Dark Gray, Gray) 21" CRT Monitor
Fuzzy, unstable display
For a few weeks there was an occasional pop and the sound of static discharge on the CRT surface. Yesterday the sharpness softened for a few minutes but returned. Today the display has become almost too fuzzy to read writing, and unstable. Occasionally it comes into focus for a minute. This AM a tap on the left rear side brought it back, but didn't last. I tried de gaussing to no avail. Display is a little less than 3 yrs old.
Richard Ferrar & Yvonne Muller myrddn@optonline.net or bellvale@optonline on the fuzzy monitor
    Problem Solver:
  • 19 Answers
Sounds like internal arcing, if whacking the monitor had some effect it confirms a probable loose connection, check where the video board plugs into the back of the CRT. this board can become loose, also soldering joins around the flyback transformer may also cause this fault. a common problem in a lot of monitors.
Posted on Apr 26, 2008
    Novelist:
  • 139 Answers
This sounds like a high-voltage power supply problem, which would need to be diagnosed by an experienced computer or electronics technician.
Check to see if there is a small focus knob on the back. If so try turning it back and forth three or four times to "clean" it....then adjust for correct focus.
Symptoms like this can also be caused by accumulated dust inside the monitor.
Posted on Jan 15, 2008
Sharp 21inch slim crt tv..unstable channel....can i have the service factory adjustment of this unit.tnx
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 23, 2016 | Sharp Televison & Video
How do I replace a broken circuit board on a Sharp LC-60E78UN TV?
You can either remove the power supply and check and replace caps and most likely the transformer (pop sound). Or a replacement can be found on eBay, amazon, etc... One model TV can have numerous diff power supply models from revisions and improvements. If you replace the board make sure you look match serial numbers on board to the new board. The back of the TV will come off very easy. Lay TV face down on a flat surface(making sure nothing is touching the LCD) remove screws. (Make sure cable coax slides free, some have a retainer but to remove) once the back is off the layout should be so simple, you should have no problem identifying parts.
Sep 12, 2015 | Sharp AQUOS LC-60E78UN 60" LCD TV...
Loud static burst at random times
Bose is proprietary. It could be electronic parts that are called capacitors.
Dec 09, 2013 | Bose & Wave& Music System
Audio Static on Sharp 32SC26B
Chances are your main board is bad, its where all the sounds are producted, a new board should correct the issue, its something you can install yourself with a screw driver, have the set unplugged for about a day before replacing the board so all the capacitors are discharged..you can get a new board at shopjimmy.
TV Parts Universal TV Stands DLP Chips ShopJimmy
Feb 09, 2018 | Sharp 32SC26B 32" TV
Picture went completely fuzzy. What could the problem be?
The tv CRT( picture tube) have a radiaton posion infected in ur tv picture tube.This is how u discharge the CRT(picture tube) get the posion out.Take the tv back cover off.Take video board that connected to the CRT(picture tube) out.Plug it in,so u have a live current to the CRT(picture tube).Find a wire like an AV cable,should be find.One side of the metal,grounded to the metal frame somewhere.Take a long needle plier grab the other side of the AV cable wire,not the metal,(Caution high voltage live current).Come very close to the open CRT(picture tube).U will have a live current arc,than u,will hear a big "POP".U,just discharge the CRT(picture tube).The tv now the CRT(picture tube),now it good,it clear of posion infected in ur tv picture tube.Now,unplug ur tv.Put ur tv,back together.Hook up ur tv signal cable and plug in ur tv,now ur tv picture,will be clear,completely.I do this many times to dicharge fuzzy CRT(picture tube).When i was a tv Tech.for the SONY TV Corporation.
Oct 12, 2010 | Sanyo HT32546 TV
Our Sony TV started to display something that looked like interference, with sharp horizontal white streaks across the screen, accompanied by loud popping noises. It has nothing to do with the cable,...
According to the symptom the FBT Which is called "Fly Back" is popped, and it needs replacement. Details like Part No. and Description is given below:
145334611 FBT ASSY (NX-6000//J1J4)
Replace the FBT and your tv work fine again.
Nov 18, 2009 | Sony KV-36XBR450 36" TV
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
Picture goes bad when playing Verizon Fios DVR or On Demand
I had issues when I set an SD override for the box, it would sometimes display as bad input when switching to HD content(as well as display all menus in SD even with HD mode in settings.) Turning that off in settings (also turned off "modes" which has no description) stopped it and gave me guide/menus in HD.
Apr 04, 2009 | Sharp Televison & Video
I lose the sound on my 1 year old SHARP aquos Lc-42D62U tv??
There is a fix for this. Call a Sharp servicer or Sharp electronics the cost of repair is around 200.00 dollars.
Apr 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Sony GDM-C520K (Dark Gray, Gray) 21" CRT Monitor Logo
102 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
