Question about Copystar CS-1500 Copier
Making copies onto legal paper
I am trying to make copies onto legal size paper, I have the paper loaded into the machine, and when I make the copy, it only copies down as far as it would on a letter size. It's like it's not even scanning the rest of the way down. I've looked all over the darn thing and can't find a button that says anything about changing this. Can you tell me what I'm doing wrong?
  • Bob Wescott Jun 20, 2016
    You must find in the menus where you can tell the machine the ORIGINAL is legal, and then where you can tell the machine the PAPER is legal, and you'll be all-right. Better to tell the machine the Bypass (MPT) has legal size and leave the cassette as letter size. But when you are copying a legal-size original, you must still stipulate the original size as legal.
    Problem Solver:
  • 3 Answers
Press the paper select key for 3 secs.,a default paper size will be shown ,press the zoom keys + or - untill F12 is shown , press the recall %/enter key ,press the zoom keys again untill the correct size is shown , Lg should should be shown for legal,press the recall%/enter key again , the selection should flash and the copier will return to the ready state.
Posted on Jan 15, 2008
When i press to copy it makes print but not all the page..then says load correct paper. down says A4R PLAIN COPY
A4 paper is used in Europe but some documents may be in that size. Try feeding legal size paper into your printer. Your document should be fully printed. Good luck !
Aug 22, 2012 | Canon Office Equipment & Supplies
Copying legal size on a Brother MFC 7420
This is for a temporary, as needed solution: Press "Menu/Set" button. Select "General Setup". Scroll down and select "Paper Size", find and select "Legal" size. Press Menu/Set button again. Press "Stop/Exit" button.
Insert legal size paper to be copied on the feeder tray and put a legal size paper in the Manual slot. Hit "Print"
You need to do these same steps again to return the settings to Letter size again.
May 09, 2012 | Brother MFC 7420 All-In-One Laser Printer
Have a canon b95 faxphone machine. When receiving legal size documents, it receives and prints on 2 separate sheets. How do I correct so incoming only prints on 1 legal size paper
Use the settings to select LGL as the paper size. (But note that you have to have legal size paper in the machine)
1. Press the Function key (left side, lower right button)
2. Press the Start/Copy key (right side, lower center button). The display will show USER SETTINGS.
3. Press the Left or Right arrows (right side, upper row) until you see PRINTER SETTINGS in the LCD.
4. Press the Start/Copy key
5. Press the Left or Right arrows until you see PAPER SIZE in the LCD.
6. Press the Start/Copy key
7. Press the Left or Right arrows until you see LGL
8. Press the Start/Copy key
9. Press the Stop key (right side, lower right button).
May 18, 2010 | Canon FaxPhone B95 Plain Paper Inkjet
Legal size copies
Your printer doesn't support Legal size to Scan and Copy, you can scan/copy it by reducing the size of the paper from the menu. 10% will fit since the actual paper size supported by your printer is 8.5X11.7inch while the legal size is 8.5X14inch. Good luck. For more info check out here : http://h10010.www1.hp.com/wwpc/us/en/sm/WF06b/18972-18972-238444-12019-3328086-2511708-3643610-3643611.html
May 15, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Keeps saying add paper but paper is in legal and letter drawer
Check the display carefully, is it waiting for a different size to be supplied, or is it waiting for apaper to be loaded into the bypass tray
If you attempt to print/copy to a size not loaded into the machine, they will wait for the requested size. (depending on your optional menu settings)
This is especially a problem if you eg. try to print A4 size, and only have US legal or US letter loaded into the machine, and visa-versa.
Dec 09, 2009 | Toshiba e-Studio 232 Black and White...
How to scan legal documents on Canon MF5770?
This information is available on CANON WEBSITE
Unfortunately, they imbed the text in javascript, and there is no way to link or c/p the information here. Try THIS HYPERLINK to take you to the exact page.
Enter your model # in "search knowledgebase" at the above link.
Type PAPER SIZE
You will have a clickable link that says How do I specify paper Size and Type.
Instructions will appear.... starting like this... (i used C/P, and it may not come out slearly after I submit this answer)
Issue: How do I specify the paper size and type?
Solution: Specifying the Paper Size and Type
  • When making copies on LTR-size paper after having continuously copied on paper smaller than LTR-size paper, the copies may be dirty. To prevent copies from being dirty, wait about 1 minute before making copies.
  • The paper in the multi-purpose feeder is fed prior to the paper in the cassette.
  • The settings changed in the Menu do not return automatically to the settings you set previously. Change to the previous settings again if necessary.
  • When making copies of a small size or heavy paper*, etc., the copy speed may be slightly slower than usual.
    *The paper type should be selected in the Menu.
  • If you intend to make a copy and print with a thermal transfer printer using the same sheet of paper, make the copy first. Failure to do so may make copies dirty or cause a paper jam.
  • When copying onto transparencies, remove each transparency from the output tray as it is output.
Specifying the Paper Size At the factory, the paper size has already been set to [LTR]. Normally, you can make copies in this setting. When making copies on other sizes of paper, you need to specify the paper size according to the following.
  1. Press <Menu>.
  2. Press <la.gif> or <ra.gif> to select [COMMON SETTINGS], then press <Set>.
  3. Press <la.gif> or <ra.gif> to select [PAPER SETTINGS], then press <Set>.
  4. Press <la.gif> or <ra.gif> to select [PAPER SIZE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper size (LTR, LGL, EXECUTIV, A4, B5, ENVELOPE, or FREE SIZE), then press <Set>.
    black_dot.gif When [ENVELOPE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select the type of envelopes (COM10, MONARCH, DL, or ISO-C5), then press <Set>.
    black_dot.gif When [FREE SIZE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select [VERTICAL SIZE] or [HORIZONTAL SIZE], then press <Set>. white_square.gif Use the numeric keys, or press <la.gif> or <ra.gif> to specify vertical and horizontal sizes of the paper in millimeters (mm).
    Available range in [VERTICAL SIZE]: 127 mm to 356 mm (5" to 14")
    Available range in [HORIZONTAL SIZE]: 76 mm to 216 mm (3" to 8 1/2") white_square.gif Press <Set>. Repeat the steps above to specify both vertical and horizontal sizes of the paper.
  6. Press <Stop/Reset> to return to the standby display.
Specifying the Paper Type [PLAIN PAPER] is selected as the default paper type. When making copies on paper other than plain paper, you can specify the paper type according to the following. Specifying the paper type can prevent poor copy quality, or the printout not being printed correctly.
  1. Press <Menu>.
  4. Press <la.gif> or <ra.gif> to select [PAPER TYPE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper type, then press <Set>.
    You can select from the following paper types: - Plain paper (17 lb to 24 lb (64 g/m2 to 90 g/m2 )): [PLAIN PAPER] - Heavy paper (25 lb to 34 lb (91 g/m2 to 128 g/m2 )): [HEAVY PAPER], [HEAVY PAPER H]*1 - Transparency: [TRANSPARENCY] - Label*2 : [HEAVY PAPER], [HEAVY PAPER H]*1 - Envelope: [HEAVY PAPER], [HEAVY PAPER H]*1*1 If print fixing is not sufficient when printed with [HEAVY PAPER] selected, select [HEAVY PAPER H].
    *2 A label that can be loaded in the cassette is a standard type (label standard card) only.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | Canon imageCLASS MF5770 All-In-One Laser...
Problem printing on matte photo paper
no thats why it is not working the right way you have to use the semi gloss paper thats what it requiers
Jan 03, 2009 | Brother MFC-3240C All-In-One InkJet...
CANON IR2000 CANT PRINT MORE THAN 1 COPY
You just stated the problem yourself!!!!!!!!!!!!!!!!!!!!!
Are you using Letter or Legal?? then the tray need to be set to that particular size.
If using Legal set to Legal, otherwise the machine will automatically know you are using the wrong size.
Aug 14, 2008 | Office Equipment & Supplies
Canon LaserClass 7000 - Receiving problem
Make sure the rear guide is pushed up tight against the paper.
Remove all legal size paper and make a copy.
Dec 13, 2007 | Canon LaserClass 7000 Plain Paper Fax
Legal Sized 2-sided Copies through Automatic Feed
Does the copier print correctly when copying off the glass? I suspect that the document feeder has been set up to feed other paper sizes eg A4, A4R. Because of the conflict between sizes the copier adjust the image.
Oct 05, 2007 | Canon imageRUNNER 5000 Copier
Copystar CS-1500 Copier Logo
164 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
