bought a motherboard and all the fans work already had a 478 socket processor but dont know if it works put both togethr heatsink fan kicks in moniter light fleshes on and off but thats it does that mean that my any processor is not compatible or that the processor is naff also dvdrom drive will light up but wont open or close unless i unplug cable from motherboard. anyhelp much appreciated but hard to find compatible processors when Aopen web site dosent list my modle motherboard
Your not getting any video at boot up? I would be looking at your video card first. Remove & reinstall. Than try again to enter bios. Still no? Reset the bios on the motherboard. You'll have to remove the battery & check it for 3volt. Replace, got video enough to enter bios? Disconnect all non needed items. Like diconnect CD/DVD rom drives power cable & data cable. Got two Hard drives. Connect only one. Two banks of dimms. Use only one. 1PS2 mouse & keyboard. Try boot up again. Listen for post beep. (1 beep). Any other beeps, count how many and if long or short. Let me know. Lastly did you apply thermal grease between the cpu & heatsink?. The idea here is to get down to basic needs only. If it were your cpu it wouldn't even power up. Than again every board is a bit differant. Give this all a try & poat back. Good luck!
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS...
(More)
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS your views on these boards as to building your own computer etc?
jumper was blown off during maintence,i put it back to where i thought it was only to discover i...
(More)
jumper was blown off during maintence,i put it back to where i thought it was only to discover i NOW need a password.
Computer will not turn on. Get no response when on/off button pressed. Had power outage from ice...
(More)
Computer will not turn on. Get no response when on/off button pressed. Had power outage from ice storm. Possible power surge. Checked power supply and all voltages low. Replaced power supply but now only get voltage if pin 14 on ATX plug connected to motherboard grounded. Voltages are good and fans run when pin 14 grounded but computer does nothing. Bad motherboard??
I would appreciate forever any help on installing the bios update on my P5M3-A+. I do not know the...
(More)
I would appreciate forever any help on installing the bios update on my P5M3-A+. I do not know the version that I have but I suspect that it is not up to date as the system was built in 2000 on a K6 Processor. I have visited the tekram site and downloaded version 1.02 and 1.04. Before I make a mistake I thought it wise to ask the experts. Thanks in advance, for your input.
