Question about Mitsubishi WD-62525 62" Rear Projection HDTV
My wd 62525 has a blinking timer light and wont power on
My wd 62525 has a blinking timer light and wont power up what should i do?
    Champion:
  • 213 Answers
Do the timer come on at all whean you plug it in do you hear kind of noses? if not take it to a sevice shop
Posted on Nov 30, 2009
SOURCE:
Green blinking timer light on my WD 62525 tv
That symptom is almost always caused by bad capacitors that are known to fail through ou the five circuits boards within the chassis. Usually the DM board and The Power Board caps fail which can cause the non stop blinking timer led. You can get the V26 Chassis DM / Power repair kit from www.tvrepairworld.com which has the caps with repair instructions that will often repair that issue.
Oct 04, 2011 | Mitsubishi WD-62525 62" Rear Projection...
My mitsubishi wd-62528 has a constant rapid green blinking light on timer and wont go out. had lamp replaced and reset but wont even come on.
Thats a common problem most likley caused by failed capacitors on the DM and the power board. You can get the V26 Chassis DM / Power repair kit from www.tvrepairworld.com which contains the capacitors and the CD with instructions for the repair.
Jul 20, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Green blinking timer light, TV won't turn on
Common to mitsubishi dlp tv's,you have a bad signal ***'y (power supply,formater board) lots of bad electrolytic capacitors,
Mar 22, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Timer light blinking fast and is green, Tv will not turn on even after a reset, bulb is good
First mistake was buying Mitsubishi Model WD-62525
The DM capacitors need replacement contact a local Mitsubishi Model WD-62525repair center.
Jan 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
I have WD 62525 timer blinks very rapidl but wont turn on or off
HOwdy;
Try unplugging TV from a/c for 2- 3 minutes. Plug back in, turn TV on. If red light turns on (Lamp may light and go out) suspect bad lamp part # 915P020010.
Good Luck, Big Irish.
Nov 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Timer light keeps blinking
Have you done a re-set on the TV at all?
Jul 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi 62" dlp wd-62525
The lamp is either defective, not connected properly to the wiring or plugs (careful alignment required on the two connections), wrong type bulb, or the front panel is not replaced properly to trigger the panel sense switch (lower right side of panel)
Sep 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
412 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
