Unplu the unit
Locate the user service screw, the lamp door should be underneath the projector.
open the lamp door
the lamp is removed by undoing 2 or 3 screws and pulling out with the handle.
a genuine replacement lamp with cage will mean you won't have to worry about wiring the lamp.
put new one in push connectors in firmly
do up the 2 or 3 lamp screws close the lamp door and screw up
reset procedure usually plug in power while holding down up, left and power and the lamp will be reset.
Hope this helps you
Good luck
Hope this helps
