Question about Dell Inspiron 1150 Notebook
My Dell Inspiron 1150 PC Notebook Won't Turn On
If I push the power button without the charger plugged in the lights in the front will flash one time. If I push the power button with the charger plugged in the lights do not flash. I've tried a new battery with no luck. Any ideas? Thanks!
  • andylouroo Sep 08, 2008
    This problem just started. The three lights flash at the base of the computer. Won't start up, just a blank screen. I have tries plugging it in and get the same result. SHouldn't I be able to get power from having it plugged in?
    Scholar:
  • 163 Answers
Norm.. Suffice to say these are a problem. Is it a P35 Adapter? If so look for a replacement and retry. If this does not help Check the CMOS battery voltage as crazy as it may seem but the Dell adapters are a little more complicated than a standard 2 wire output adapter. They have a 19V Feeder or main supply, The Negative or Ground as some people/techs call it as well as a 3.3V data circuit thats related to the Embedded controller chipset, BIOS and other circuits on the board. Also see if you can find a friend local with a known good working battery/adapter if you cannot afford or dont want to spend money on it. If all else fails yell back weve repaired a ton of these and they should have been included in the 5150/5160 Dell Class settlement in my opinion as they have a ton of similar components/issues..
Good Luck! Ken
www.ikenfixit.com
Posted on Jan 15, 2008
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
Charging light is flashing
There are two possible causes for this issue:
1) Your dell 9400 charger is malfunction
2) Your laptop dc power jack is loose or dead
Possible troubleshooting step:
1) Borrow a compatible dell charger to plug in your laptop, if it works without any issue, it means your dell inspiron 9400 adapter need to be replaced.
2) If the compatible dell 9400 charger won't work normally, the problem may lie in your dc power jack.
Hope this will help.
Jan 07, 2013 | Dell Inspiron 9400 Notebook
Dell inspiron 1150 wont power up the power light flashes green and batery light flashes orange but the fans or any thing else wont work
You may have a burnt board or the input pin is bad, try wiggling the pin while it is plugged in to see if you can at least get the fans to start you obviously have a short of power in the power button area. You may want to try replacing the power button board for your model this may offer you a solution. If you take it in they can test it with a meter to make sure that this is the problem before a board issue is determined. It is difficult to diagnose this kind of things without the machine in front of me. My advice is to take it in and have the power investigated.
Just because the lighting on the battery is going and showing signs of life does not mean the power button is not bad or not getting the proper power to start the computer. It seems to me that the power button board is bad. Or the input cord pin may be shorted out and only supplying power to the mains but not the power button circuitry. Just a good guess!......John
May 11, 2012 | Dell Inspiron 1150 Notebook
I have a dell inspiron 1150 when i connect the charger the battery and the power light keeps on blinking and nothing happens oh turning the power button
Sounds like the adapter is being overloaded ... Dell is one of 2 or 3 manufacturers using a 3 wire adapter plug jack. And ... well ... lets say they can be problematic ... it's a great system but very sensitive to battery malfunctions. I suggest you remove the battery then pug the adapter in ... if all is OK then have the battery checked
Feb 23, 2011 | Dell Inspiron 1150 Notebook
My Dell Inspiron B130 will not turn on
The battery is critically low, indicating that it is not getting a charge from the AC adapter. If the system will not power on from the AC adapter, then the motherboard power connection is suspect.
Motherboards are about $100 on EBay
Feb 01, 2010 | Dell Inspiron B130 Notebook
Laptop will not turn on.
Bad motherboard. Black Christmas is around the corner. New laptops are running 200-300. Time to save up for one...sorry :(
Nov 21, 2009 | Dell Inspiron 1150 Notebook
Have an inspiron notebook 1150... hasnt been used in a while. Computer will not power on. Charging plug indicator shows it is working, but none of the lights on the front are illuminated. No power at all....
Try pulling the battery and powering it on - could be that. In response to your master reset button question - the answer is no, there is not one for this laptop. It also could be an issue w/ the connector between the power cable and the laptop - also, make sure you're using the proper AC adapter provided by dell when you purchased the laptop.
Hope this helps - good luck!
Sep 17, 2009 | Dell Inspiron 1150 Notebook
Dell Inspiron 1150 Wont Start Up
try taking out the memory.you can have the instructions by going to this link---http://support.dell.com/support/edocs/systems/ins1150/sm/upgrades.htm#1105389.Incase that does not work than i would suggest to get the motherboard replaced.You can contact the tech support incase you have the warranties and get it replaced
Dec 22, 2007 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Inspiron 1150 Notebook Logo
1,009 people viewed this question
Alun Cox
