Question about Sanyo DS20930 20" TV
Remote not working
Could it be the remote? Replaced batteries and doesn't work. Should I order a new remote or could there be something wrong with the TV? The TV works manually but not remotely.
  • 102 Answers
If you have a digital camera or a video camera you could have a look at the remote to see it it outputs any infrared signal.
Just point the remote at the lens from a foot away and look at the display of the camera while pressing any button on the remote.
You should be able to see the infrared led flickering. When it does flicker there might also be something wrong with the infrared reciever on the tv. If it does not chances are that the remote is really dead.
Make sure there is a clean line of sight from the remote to the tv
and nothing stands in front of where the reciever might be located
on the front panel of the tv. You could even get one of those cheap universal remotes and see if that works.
Posted on Jan 15, 2008
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 74 Answers
I would bring the remote back and let the place where you purchased the tv know of your problem. They will probably give you a new remote. Most likely there is no problem with the television itself. Let me know what happens.
Cynthia Charczenko
I changed the batteries but my remote won't work.
Check to see if the batteries are installed correctly (polarity + and - ). Are the new batteries alkaline but old or expired? General purpose batteries are too weak to use in a remote control. If all of these steps are good, then the remote control has to be replaced with a new one. It is possible that there is something wrong with the TV.
Jul 18, 2014 | Sanyo Televison & Video
Vizio remote works intermittantly for tv M550SV, now not working at all, new batteries.
You can get a rocu at your local Walmart and use it a lot cheaper than a new tv hope this helps Merry Christmas
Dec 09, 2017 | Televison & Video
My remote doesn't work
Have you tried replacing the batteries? If you spilled something on it, it might break it, or if you dropped it. Is something in the way of the TV Receiver thats blocking the signal?
Nov 19, 2011 | Televison & Video
THE T V WILL NOT POWER ON
plug the cord into the outlet. If the wall outlet doesn't work find a different one. If the tv doesn't turn on with the remote take the plastic off of the batteries in the remote. if this all doesn't work, then there's something wrong with the tv and you should return it and get a new one.
May 16, 2011 | Tatung LD30HL Television
My control remote doesn't work
Hi, first if remote doesn't work, try new batteries......
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
May 08, 2011 | LG 32LC7D Television
Remote doesn't work new batteries and tried different remote still not working
hello, usually if the remot control is ok, then the infrared receptor need to be replaced, he is placed near the stand by light.
in a rare case the problem is at the 5v voltage that goes to the receptor. more rare is the possibility
that something is wrong at the microprocessor circuit.
i hope it was helpful!! Let me know if you need further guidance
Dec 14, 2010 | Toshiba CZ32V61 32" TV
Remote does not work. I changed batteries. Nothing. New universal remote does not work either. Any way to do a reset of any sort?
Hello, you need to make sure what is broken, the remote control or the TV. To check the integrity of the remote control, you need to broadcast from the remote control while he aimed at the video camera. If you see a flicker of light through the camera it shows the integrity of the remote control. In this case the infrared receptor need to be replaced, he is placed near the stand by light.in a rare case the problem is at the 5v voltage that goes to the receptor. more rare is the possibility that something is wrong at the microprocessor circuit. . If the remote control out of order, can be opened carefully by a thin screwdriver, usually the causes to the error are loose components or contacts that are supposed to weld back into the board.
Sep 06, 2010 | Toshiba 27AF42 27" TV
My Toshiba will only turn on or off manually. It will not work with the remote. Tried putting new batteries in the remote...still does not control tv.
Jun 21, 2010 | Toshiba 36A43 36" TV
Toshiba model Cx36H60
Yes, I have been seeing a lot of those Toshiba IR receivers bad lately. Replacing it with a new one should take care of your remote problems. If you have never replaced small parts on PC boards then have a qualified tech handle it for you.
Aug 09, 2007 | Toshiba CX36H60 TV
Remote Won't Work! Problem with TV remote receptor?
Try unplugging the set for 12 to 24 hours. if that does not work, theres a problem in the remote sensor circuit or the microprocessor circuit. its going to need a pro to fix it as it meeds trouble shooting.
Sep 05, 2006 | Toshiba 32AF41 32" TV
Sanyo DS20930 20" TV Logo
95 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
