Front loader problem
The machine rocks violently at the beginning of the spin cycle.
  • 3 more comments
  • bpsstfixya May 28, 2008
    They forgot to take out the shipping stabilizers (washers)
  • rickc510 Oct 13, 2008
    My machine is level, with all four levelers firmly on the floor, when it goes into high speed spin the machine rocks and walks it also is mounted on a pedistal.
  • papagray Jan 19, 2009
    seems to level out during spin cycle, but on inial load of water when it soaks the clothes as it rocks back and forth suddenly violently spins the drum of course the load is uneven water heavy in some places and the drum actually hits the top of the cabinet. have checked no packing inside level on the floor it appears the dampeners are okay its the inial start of a spin wow its scary..
  • iluvsn May 11, 2010
    I think I have the same model. Just curious, but what is the capacity. It was a gift and I can't find it on the machine.
  • robert samples May 11, 2010
    what is the brand and model of it how old is it and did you install it yourself
Kenmore 417.42052100
01/02
Sears installed it
Posted on Jan 15, 2008
Washer rocks violently, how can I identify bad shock absorbers?
A washing machine with shock absorbers? Is this a front or top loader? Top loaders you pull the machine forward by grabbing the top of the back. This adjusts the self adjusters. Thanks
May 03, 2016 | Maytag MAH5500BWW Neptune Washer Boot...
My maytag washer is shaking violently on the rinse cycle
I am currently having the same issue with my Maytag A482. Not sure if you have found a fix yet, or if you have replaced your washer. My washer runs fine until it nears the end of the cycle, when it begins to spin and shake violently, enough to loosen the leveling feet and rock back and forth. I pulled the front panel of the machine off (two screws near the base in the front, and two clips at the top) and ran a load through it. It ran fine until the end, when the machine started shaking violently. I did notice a few small pieces of roundish felt looking material sitting on the bottom, which after some research looks like it may be the damper pad. I found these online:
Damper pad 203956
Replacement Damper 203725 for MAYTAG Laundry Appliances A482
I am hoping this will resolve the issue, I will order them this afternoon and install them once they arrive. I really hate to replace such a good washer with a new high efficiency unit, which all seem to have terrible reviews after a few months/year of use.
Aug 25, 2014 | Maytag Washing Machines
Samsung front loader rocks on spin cycle, sometimes, it is level
I assume you removed the transit packing!! or the technician did - but double check there are no bolts that need to be removed from the drum, or polystyrene blocks still underneath that were not removed. See the installation instructions.
If you are sure the machine is solid on the floor, it may be a suspension problem, or suspension dampers. But check again that the machine is sitting solid on its feet / wheels - grab the case and try and move the machine backwards and forwards, left and right. There must be NO MOVEMENT or rocking AT ALL when you try this - adjust the feet or pack as necessary
Feb 02, 2018 | Samsung Washing Machines
My washer is rocking back and forth very violently during the spin cycle (medium) to where it knocks everything off when I put sometighing on top. I have called a repairman out 3 times and he says there's...
Check that the machine is level and that the leveling feet are not screwed out too far. If necessary, screw them back in and restart to level the machine. With a front loader it is more important to have the machine standing completely completely firm on all four its feet than to have it exactly 100% level. You must not be able to rock the machine by hand at all and the floor on which it is standing must be solid with no give in it at all.
Mar 28, 2011 | LG WM1814CW Front Load Washer
Just bought the Bosche Axxis front loader. When the spin cycle kicks in, the machine wobbles/shakes/wanders VIOLENTLY from side to side. Is it the installation or the machine?
I bought the Bosch 8Kg washing machine on 8th Feb, I had the same problem.
Read installation instructions, you need to remove transport safety nuts from the back.
Feb 06, 2011 | Bosch Axxis WFL 2060 Front Load Washer
I replaced the base assembly and completely level the machine and it still is unbalanced at the 11 mi. mark.
Is your washer a front loader because if it is then one possible solution is by putting less close. I have a front loader and when I put 8 blue jeans along with some other close. The spin cycle is violent and by removing 4 jeans, the cycle spins better and it end up balancing its self. Usually jeans soak up a lot of water, so try to put in lee close and less heavy close.
If this does not help then you might have a problem with the damper shocks (leaking) or springs (broken) if it a front loader washer.
Jan 11, 2011 | Washing Machines
Shakes violently during spin cycle from back to
I had this problem with my front loader as well. It is probably the mounts or "level shocks" on the bottom of the unit under the tub. I have a Kenmore by Frigidaire and had to replace the "level shocks". I only paid about $43.00 and was not that hard to put on. Look under your machine and see if the shocks are connected to the tub. Check under the top panel also to see if that particular model has mounts up there too.
Mar 12, 2010 | Maytag NFW7200TW Front Load Washer
My washing machine spins violently and the ground
Possibly you still have the transport screws in. this causes havoc when load is in. or very unballanced load or possibly spring come loose . assuming you have a front loader. Definately one of those.
Sep 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
358 people viewed this question
Top Washing Machines Experts
