Question about Polaroid FLM-2632 Television
Buzz from back of the tv
My tv is less than a year old and it started buzzing from the back. I changed inputs and turned the volume off and that did not efect the buzzing
  • Anonymous Mar 16, 2014
    hi-sense tv will loose pic then loud buzzing racket, cut its self off then cut back on. Had it less in than 2yrs.
    Genius:
  • 1,554 Answers
It is likely that one of the transfomers is buzzing due to heat and laminations or wire is ringing.
It should not cause any issue except annoy you. it must be replaced. or glued back down which is usually very difficult as they are wrapped and/or sealed.
Only way to find out is to open the unit and trace it down.
If it is dust buildup then you should be hearing a crackling. zzzztt sound.
Posted on Jan 31, 2008
6ya staff
SOURCE:
NS-LDVD32Q-10A buzzing noise
Try another input and another source such as a DVD player. If you still get the buzzing sound, you could have a faulty power supply output or a fault in the audio circuit of the main board.
Jan 27, 2013 | Insignia NS-LDVD32Q-10A LCD TV
Hi, my problem with our Samsung HLP5063 WX / XAA is that ever so often it decides to buzz. The buzzing sound is coming from the back of the tv and happens at different times. Sometimes the buzzing starts...
Bryce.
My experiance with what you are talking about is sounding like the color wheel going bad. Same thing happened to mine and it was the color wheel. Right around 120.00 and is a easy do-it-yourself job.
Feb 06, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Hi, I have a Samsung DLP Model HL-P6163W, approximately 5 years old. We replaced the lamp one year ago with no problems. In fact, we have had no other problems at all with the TV except recently. About...
Ur tv have a colors wheel design in it.Tv have buzzing,squiling or loud motor noises.Have colors turn in Black&White or flashes white within pictures.All these causes and problems are the effect of the colors wheel is dying and require repacement of the colors wheel,because it is woring out and not spinning correctly on it motor axis anymore.Have no machanical experience taking things aparts and putting it back together again.Don't atempt to change the colors wheel by ur self,bacuse the colors wheel sit way back on the tv,must take out many machanicals parts before u can even come to it to change it.Hire a Tv Tech. to change the colors wheel ok best solutions and no complication taking out the old one and putting in the new colors wheel,for it to functions correctly.
Jan 07, 2011 | Samsung HL-P6163W 61" TV
37inch Vizio TV making buzzing sound from back
my tv is new too and also makes a buzzing sound and i turned the DCR off and it worked to thanks for the help!!
Jan 03, 2009 | Vizio L37 Television
Buzzing/humming sound from rear of TV unaffected by volume settin
Hi.
I think you have problem with the main digital PWB
You need change that part.
Nov 18, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Sanyo tv ds25390 buzzing sound
I had the same problem with the same model.
The solution was to replace a capacitor, C622, which is located near
a small blue rectangular plastic component.
This component is a relay that is controlled by C622. I paid $2.39 for
the part, $8.99 for S&H for a total of $11.38. This fixed my problem!
May 26, 2008 | Sanyo DS25390 TV
Polaroid lcd hdtv 27" buzzzz
thre are several components that can make a buzzing sound, especially a bad power component or capacitor. check the capacitors to make sure they are installed in the board correctly. the stripe on the cap must line up with the white mark on the board under it. remove the back panel lay the tv down on a blanket turn it on and see if you can isolate the noise component by ear up close. and visually check for swollen capacitors the top will be pushed up round if bad if good it will be flat on top. warning if tv is less than a year old make the place you bought it replace it. so you dont void the warranty.
Jan 15, 2008 | Polaroid FLM-3232 Television
RCA 56 projection
Does the buzzing come from the speakers or the back...turn the volume down.. is it still there?
Nov 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitachi VCR F361
You need to change the Audio / Control Head, as well as the Pinch Roller of the machine. A worn out Audio cum Control Head will reflect in poor tracking and so will cause the above problems.
Sep 29, 2007 | Hitachi VTFX631A VCR
Polaroid FLM-2632 Television Logo
75 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
