Question about Amana 24 in. ADB2200AW Built-In Dishwasher
Amena soft sound II
My Amana dishwasher leaves a black residue on all dishes. The residue does not adhere to the dishes as much as detergent or food would, and is fairly easy to rinse off in the sink. It originally looks like coffee grounds at the bottom of a cup, but upon closer inspection it appears to be small particles of black rubber or plastic.
When I put clean glasses in and just run them through the rinse cycle, the problem is the same. I have repeated this several times with clean glasses and the amount of black residue is the same each time.
This dishwasher is 2 years old and I believe the problem has always existed and is getting worse. My guess is that something is slowly breaking apart, but I don't know what it might be...
2 Suggested Answers
  • 15 Answers
SOURCE: black residue
The black residue is possibly rust from iron pipes. I have an old house with iron pipes and when the washer opened the valve that lets water in from the supply hose it did so suddenly and created a "water hammer" that shook the pipe. The hose supplied with the washer became clogged with this black rust material and needed to be replaced. I replaced it with a different type that did not have a spill proof valve and added an "air cushion". An air cushion is a short 6" vertical pipe teed before the valve. It fills with air bubbles and cushions the shock of that valve turning on thus stopping the pipes from shaking and the loosing of interior pipe corrosion. If the black residue is hard and gritty it is rust not rubber. Wipe the inside of the washer clean of it. Disconnect the supply line and fill a five gallon bucket with it. If rust is coming from the inlet you will see it in the bucket. If you don't have a shut off valve at the washer you'll want to put one on now as turning off the main releases quite a lot of material from the pipes as they drain.
Posted on Mar 08, 2010
Danby counter top dishwasher leaves residue on dishes
Make sure It's not a soap issue by running a load or three without any detergent.
Jan 11, 2015 | Danby Dishwashers
My amana softsound III Model DWA63AL doesn't seem to get dishes clean. I have cleaned filters and everthing seems to operate ok. Water temp good. any advice?
Many people are having trouble with poor performance due to recent EPA changes required in dish washing detergent.
If it makes as much water splashing noise as it used to but it still leaves residue and undissolved food behind...then it's probably the detergent. That's what does the work.
Mar 08, 2011 | Amana DWA63A Dishwasher
We bought a new dishwasher because we were finding a hardened residue was being left on our dishes, it was ruining our dishes. Although we have a brand new dishwasher this problem is still occurring and...
My best advise is to reduce the amount of detergent to the least amount that you can use, and still get the dishes clean. We do rinse the dishes a bit, as the soft food disposer isn't made to act like a garbage disposer, but rather, to catch incidental food residues. We no longer fill the closed detergent dispenser. We sprinkle about 1/2 of the normal amount (that goes in the open cup) on the inside door and close it up. Our dishes get very clean, with no residue. Also, use a good drying agent as this will help sheet the water off of the dishes. It may take several cycles to see improvements, but you should see improvements nonetheless.
Best regards, --W/D--
Jan 23, 2011 | Dishwashers
I have a kenmore dishwasher. I had it checked out by service and there is nothing wrong with it however it leaves a white film on my dishes. What can i do to stop this?
You may try a different detergent, and this may give you some relief. What works best, in my opinion, is to use the least amount of detergent that you can, and still get the dishes clean. Cut the added detergent in half, and go downwards from there. We are currently using ~25% of the recommended amount, and the dishes clean up very well, with no residue.
Rinsing excess food off of the dishes prevents the soft food disposer in most new models from being overwhelmed, and will increase the overall performance of your machine over several cycles.
Also, using a good rinse agent will help, as will opening the cabinet door after the drying cycle (while still warm), allowing the dishes to continue to air dry.
Hope that this gives you some relief.
Best regards,
--W/D--
Jan 20, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Leaves food residue on dishes, mostly glasses and only on top shelf after every wash.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jan 16, 2011 | Whirlpool 24 in. GU1200XT Built-in...
Soap (?) residue on dishes; also not getting them clean--food on
heatman101
Jul 26, 2010 | GE Nautilus 24" Built-in Dishwasher
It is leaving an enormous amount of white residue on our dishes and is causing all of our metal dishes to come out dark.
The white residue could be from one of two sources.
Detergent Residue:
Using too much detergent or poor circulation of water can leave a white residue on the dishes. If the residue is easily rinsed off with warm water then it is detergent. Use less soap, especially if you pre-rinse the dishes or have soft water. Use a hi temperature wash to help dissolve the soap better.
Hard water deposits:
See this link where I put together some information on this.
http://www.fixya.com/support/r4666624-hard_water_calcium_white_powder_build_up
May 01, 2010 | Whirlpool Dishwashers
The dishwasher is leaving residue on the lower rack dishes...everything except plates.
heatman101
Dec 29, 2009 | Amana 24 in. ADB1500AWS Stainless Steel...
Does not clean well and leaves detergent residue even after several cycles. Tried changing from detergent tabs to gel, no real change.
heatman101
Dec 21, 2009 | Amana 24 in. ADB1500AW Built-in Dishwasher
Black residue
Maybe a ruber washer is breaking apart, But my advise is take the inside apart clean and inspect it and then test it.
Dec 17, 2007 | Amana 24 in. ADB2200AW Built-In Dishwasher
Amana 24 in. ADB2200AW Built-In Dishwasher Logo
83 people viewed this question
Top Amana Dishwashers Experts
Oloyede Monsuru
Kolbrun...
Mike
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
