Konica 7030 There is an error code F-35-3, is there anything I can do to reset the machine? Thanks, Jonny Green 828-777-8392
  • Anonymous Mar 26, 2014
    How to reset
    Problem Solver:
  • 5 Answers
The problem is a fixing unit abnormality code, could be caused by a bad temp. sensor, build up on sensor or maybe the machine experienced a voltage spike. Power the machine off using main power switch and sub power switch, unplug IP (Image Processor) and any phone lines that may be hooked up.
1) turn on power (both) sub and main while holding down the 2 and 5 buttons on op. panel. a screen will come up.
2) Select 1) software switch setting
3) using the arrows on the screen select dip switch 3-1
4) touch the off key on the LCD to change the data to 0.
5) press return and power equipment off and back on again.
Good luck.
Posted on Jan 18, 2008
Error F-35-9 code
Power off the machine. Now hold down the 2 and the 5 and power on. Mode 25 screen appears. Touch the Soft switch tab in the first box on your left you will put a 3 in the middle box you will put a "1" the third box you will change the "1" to a "0". Close out to original screen and power off the machine. Wait 10 second power on should get your ready to copy, if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
Mar 03, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Error code c3905 in konica minolta bizhub 950
When C-35**,C-38** or C-39**(fusing temperature related
abnormality) occurs, be sure to repair defective parts before
setting DIPSW3-1 to 0. Setting DIPSW3-1 to 0 with defective
parts not repaired results in a fire.
Dec 21, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
Can't print to Konica 7030 via Parallel
You do not have the print/scan option installed on your copier. If you did you would have an ethernet port on the machine for network access and when you press the print/scan button on the control panel you would be able to access those functions. The fact that you can not means that the machine can not see that option because it is not installed. The parallel port is common and is used for uploading of firmware into the machine.
Thank You for using Fixya.
Apr 30, 2010 | Office Equipment & Supplies
F 35 7 on a Konica 7030
F35-7 is fuser error on a konica 7030. Resetting the fuser error might just fix your problem. First turn your copier on while holding down the 2 and 5 key. Next press 1 for soft switch setting, then press the left up arrow key to 3 and the right up arrow key to 1, now press the OFF key to change the data to 0 (it should read 3-1 :0)press return. Power the machine OFF/ON. If the problem persist then you most likely have a bad thermistor, however it can also be a bad heat lamp or thermistat.
May 11, 2009 | Office Equipment & Supplies
error f 35 is fixing error,try to reset on 25 mode
Jan 08, 2009 | Toshiba E-Studio 3511 Color Copier
Konica 7030 copier/printer - service codes
Are you sure it's not 34-2.I don't see or know of a 32-4 in my service manual.If it's a 34-2 write back and I'll reset it for you.
Jul 24, 2008 | Office Equipment & Supplies
Konica 7050 error code f-35
F-35 is a fixing unit related problem... resetting wont do you any good if there is a thermistor/heater lamp/thermal fuse related problem. make sure all these are good. otherwise you wont be able to reset that code...
May 31, 2008 | Office Equipment & Supplies
Konica 7030 F-34-1 code
try to change the thermistor, if u confirm both the heater lamps is working.
the fuser unit from 7022 is not compatible with the 7020 machine.
May 29, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
KONICA 7030 F-35-7 CODE
F35-7 is a low temp abnormality in the fixer.
To reset you need to enter the '25' mode and go to dip switch 3 - 1 and reset this to 0.
This should reset the code. ( dip switch 3, 1 to 7 control the high/low temps for the fixing unit i believe they should all be 0)
Hope this helps.
Apr 24, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
389 people viewed this question
